Question about Samsung LN-S4051D 40 in. LCD Television
Wall mounting tv. How do I get the base Off?
I have removed the base of the tv. I'm left with a piece on the bottom that I can't figure out how to get off. I removed two screws but it's still solid. Any ideas how to get it off?
There is a metal part that the TV sits on. To remove base you need to remove I believe it was 4 screws center lower back of TV, then pull off base. Hope this helps.
Posted on Mar 24, 2009
Are you wanting to sell the base? My base is broken and I am trying to buy one.
Posted on Jan 12, 2009
  • Gloria Miller
    Gloria Miller Oct 29, 2014
    I have a base, what I am looking for is the cover that goes on the end that sticks out once you remove the base, do you have that?
How do I remove the base stand to wall mount a Samsung model T24C55OND flat screen TV
The wall mount attaches to the top 1/3 portion of the TVs rear panel. The bottom of the back of the TV should not interfere with your wall mount if it's the correct size. Full instructions are listed starting at page 39 of the manual.
http://downloadcenter.samsung.com/content/UM/201404/20140426112621559/[X13_NA]BN46-00319C-04ENG-0312.pdf
Jan 08, 2015 | Samsung Televison & Video
I have wall mount and now I need remove the pedestal stand from the TV. But I have lost the manual and can some body explain the steps to remove the stand? Thank you
Without knowing the model of your TV, it may be tough, but typically it's 1 or 3 types:
- the whole base is a single piece that slots into the bottom of the TV, with a clip release.
- the base removes from the stand, and the stand removes from a slot in the TV. This may be fastened with clips or screws.
- the base is screwed into the TV, and you'll have to remove these to remove the stand.
If that doesn't help, please provide more details, like the make and model of your TV.
Dec 18, 2014 | Televison & Video
I need to know how to remove the bottom from my Toshiba Regza TV so that I can put it on a wall mount.
What you need to do is with the model number GOOGLE to see if you can find a service manual or even a owners manual.
Most of these sets you carefully lay the set on a padded surface face down and look at back-----should be four or more recessed holes with bolts that secure the base to the back/bottom of the set.
Most of these also you have to remove that base to get the back off which is a hint---usually no small screws but bolts.
Hope this helps you
Mar 17, 2012 | Televison & Video
Remove base to wall mount
Place the TV face down on cushioning. There are four short hex head screws that hold the TV to the stand. There are two on each side of the mounting point (close to the bottom of the TV). (Turn counter-clockwise to loosen.) Next slide the base down from the bottom of the TV. The appropriate sized hex key was supplied with the TV (and the base was installed). If you want to, you can unscrew the support post from the base - it has 4 long hex head screws. This will let you put the base parts into an appropriate container for storage.
For a clear picture, see the manual for installing the base and work the steps in reverse. See here for a copy of the manual: http://www.managemylife.com/mmh/owner_manuals/search?query=LC46SB54U+ .
To put on the wall mount, you will need to remove the covers from the 4 mounting locations on the back of the TV and use the screws from the wall mount bracket kit.
I hope this helps.
Sep 16, 2010 | Sharp LC46SB54U 46 in. LCD TV
How to remove base on samsung 2333hd. The base comes un mounted butcan't figure out how to remove the stub sticking out of the bottom of the tv for wall mounting
We had the same problem, we just wiggled it back and forth, gave it a good tug, and hey presto! We got it out. I'm not sure whether this is the "official" method of doing it, as nothing is mentioned in the instruction manuals.
Dec 26, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
Remove the base for wall mount
just spoke with a Coby technician. Where the base connects to the TV you can literally just squeeze in those the plastic pieces and they come right off. After that just unscrew the screws underneath. Just did it and it was very easy.
Nov 14, 2008 | Coby TF-TV2608 26 in. LCD Television
Dynex TV
You have to take the back off.
Sep 06, 2008 | CTL Nexus NX3200 Television
Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Jun 29, 2008 | Insignia LCDTV26 26 in. Television
Akai PDP42Z5TA 42 in. Plasma base removal
If you ever get the base off, I'd like to buy one.
Apr 13, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Olevia 227V LCD
I just repaired a 26" in which the stand came off after I took the primary panel off in the middle of the back then the screws were visible that Olevia is talking about. You might have a different style but it does come off.
Feb 12, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Samsung LN-S4051D 40 in. LCD Television Logo
798 people viewed this question
Henry  Thomas
Henry Thomas
