Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Quicken 2008 printing vista 64
All other programs print - this one does nothing - no error message, no form feed just total no response I have the same problem. It looks like the print gets stuck being "Spooled" Vista 64, Quicken 2008, HP L7780.
  • 5 more comments
  • Tom Carson Jan 03, 2009
    This keeps happening.
    My printer worked great when I was using XP and Quicken 2007. Quicken 2007 didn't work when I upgraded to Vista 64 so I upgraded to Quicken 2008. Everything works fine except printing. I start a print job and nothing happens.
    The spooler is already set to automatic
    I upgraded to Quicken 2008 specifically because it will run on Vista 64.
    For some reason I can't print from the application. It appears there are a lot of other people with the same problem.
    Just tried to run as suggested as an older version of windows. Still the same problem.
    Gosh, the printer works fine with all the other programs. Just does not print from Quicken.
    Quicken works fine with Vista 64.
    I can print from other applications. Word, Notepad, ect... I've cleared the spooler...
    Just keeps not printing from Quicken 2008.
    Nothing to do with the firewall.
    I found this solution on the Quicken Web Site.
    Be sure you have the latest printer driver for your printer's operating system
    Check your printer manufacturer?s Web site to ensure you have downloaded and installed the latest 64-Bit driver for your printer. If necessary, contact your printer manufacturer for assistance.
    NOTE: We have partnered with HP to find a resolution to this issue, and HP will be releasing updated drivers for many of their supported printers in January. Until this has been completed, please use the workaround below for using an emulation printer depending on your Operating System.
    Use an emulation printer
    If you have the latest printer driver for your printer and are still unable to print, try emulating your printer driver.
    Windows Vista
    Click the Vista logo (Start button) and select Control Panel.
    Under Hardware and Sound, click Printer.
    Click Add a printer.
    Select Add a local printer.
    Select Use an existing port, select the same printer port as your current printer (found by checking the properties of your currently installed printer) from the list of ports, and click Next.
    In the Install the printer driver window:
    From the list of manufacturers, select HP.
    From the list of printers, select HP DeskJet 990c.
    Change the name of the printer to "Quicken - HP Deskjet 990c.
    Remove the check mark to from "Set as Default Printer", and click Next.
    Do not click the "Print a test page?" button.
    Click Finish.
    Yep, that works great!
    the solution is to use an emulation printer until HP releases an update driver.
    This is from the Quicken Web Site........................................
    • Windows Vista
      1. Click the Vista logo (Start button) and select Control Panel.
      2. Under Hardware and Sound, click Printer.
      3. Click Add a printer.
      4. Select Add a local printer.
      5. Select Use an existing port, select the same printer port as your current printer (found by checking the properties of your currently installed printer) from the list of ports, and click Next.
      6. In the Install the printer driver window:
        1. From the list of manufacturers, select HP.
        2. From the list of printers, select HP DeskJet 990c.
        3. Change the name of the printer to "Quicken - HP Deskjet 990c.
        4. Remove the check mark to from "Set as Default Printer", and clickNext.
        5. Do not click the "Print a test page?" button.
        6. Click Finish.
    President:
  • 1,257 Answers
    Genius:
  • 1,239 Answers
Hi
Open HP Solution Center, Click Settings ---> Print Settings.
Click Features tab, select the Paper Type as Plain Paper.
Select appropriate Paper Size under Size. Click Ok.
Now Print Cheques from Quicken.
If the issue still persists, Navigate to Printers folder, right click on the printer icon and click Properties. click Advanced tab, enable Print directly to printer. Click Apply.
This should now Print the Cheques.
If the issue still persists, install alternate drivers in Vista.
Here are the steps:
Click Windows logo ---> Control Panel ---> Printers.
1) Click Add Printer
2) Select local printer
3) Choose Port as LPT1
4) Choose HP and then select HP Deskjet 6500
After the driver is installed, perform below steps:
1) Right click on HP Deskjet 6500 printer icon in Printers folder
2) Click on Properties
3) Click on Ports tab
4) Choose USB001
5) Click Apply and click Ok
Now try to print.
Posted on Jan 03, 2009
  • ABHISHEK.C
    ABHISHEK.C Jan 03, 2009
    this solution is from form.
    I had this problem after I had fixed a problem printing from Quicken. I was able to print from Quicken by changing the print option in Windows -- mine was set to "Spool documents" and I changed it to "Print directly from printer" -- the advice I was given was to change it from whatever it was set at to the other option. For printing a PDF file, I changed it back to "Spool documents" and it allowed me to print the PDF file. Try this and see if it works for you -- click the Windows Start button and select Settings, then Printers and Faxes. Right click on the selected printer and select Properties. In the properties window look for a setting to print directly to printer or spool documents -- mine was under the Advanced option. Try the option not currently selected -- in my case, I changed it back to Spool documents with Begin printing immediately -- and then try to print a PDF file. It looks like I will have to toggle back and forth when I am printing from Quicken and when I am printing a PDF file. Hope this works for you.
    Genius:
  • 1,011 Answers
Sir,
Updates the OS. Also check the firewall is blocking the program. Uninstall the quicken2008 and install the other drive (Not in C:\). Open control panel->click windows firewall-> go to exceptions tab and add the program you want to run the program from blocking firewall.
thanks
good luck
  • Asfiya Ahamed
    Asfiya Ahamed Jan 03, 2009
    problem is solved?
    Brigadier General:
  • 5,158 Answers
It may very well have not installed the proper print spooler... you can go to the start menu... control panel ... programs and click on that... under programs and features select "Use and older program with this version of windows" i do realize it's not an older program but you can change the compatability of the program here and run it that way... it should fix the issue
  • Roberta Smith
    Roberta Smith Jan 03, 2009
    please go to this page... there are numerous patches available for that program
    https://quicken.custhelp.com/cgi-bin/qui...
    Robert
  • Roberta Smith
    I did steer you in the proper direction then
  • HP Master
  • 2,386 Answers
It shows printer is fine, the application may not compatible with vista, try to find the aspplication (Quiken) for vista.
otherwise use it with xp.
    Genius:
  • 1,550 Answers
Control Panel->Admin tools->Services-> find the print spooler service and Start it & set it to automatic
  • SAM ANDERSON Jan 03, 2009
    This problem is due to bug in VISTA 64.
    • Try this move the program (quicken 2008) from Program Files (x86) folder to C:\, Make sure you update the icon (link)to show this new location.
    • Take away all the administration rights. (clear the check boxes)
      Right click on the icon, click on Properties. Click on Advance tab,
      clear the check box 'Run as Admistrator. Click on the Compatibilty Tab,
      do the same. Now your printer should work
    Source :quickenforum.com
    President:
  • 2,110 Answers
Go to command prompt and type : net stop spooler
then open start>run>type spool and delete the containts of the printer folder..
then
go to command prompt and type : net start spooler
  • Sibananda Jena
    Sibananda Jena Jan 03, 2009
  • Sibananda Jena
    Solution
    - Go to Control Panel, add a new printer selecting HP Deskjet 990c.
    - I selected the same USB port as the c7820 is connected to.
    - Under advanced Tab, select Print Directly to the printer.
    - In Quicken, under File > Printer setup, select the new printer.
    (To remind me, I had named this printer Quicken - HP Deskjet 990c, but
    this is not important to the function).
Quicken reports & reconciliations wont print
If your printer prints other documents properly then it is a problem with the driver for your Quicken program. Go to the Quicken site and upload the latest driver for your operating system.
http://support.intuit.ca/quicken/en-ca/index.jsp
Jan 19, 2010 | Intuit Quicken Starter Edition 2008:...
I have an HP deskjet D1560 printer. I'm using Vista 64 bit operating system. I can print from my e-mail file as well as off the internet but when I'm in Quicken 2008 program nothing prints. I've...
There is piece of software which is causing this problem you need to contact Quicken 2008 and get the setting changed to print , as the printer prints in other application ....
Jul 30, 2008 | Computers & Internet
Have 2001 quicken running on windows vista. when i try to print the check register, it says cannot open printer. i bought 2009 quicken and started to install, but it said it cannot save old register. it...
Dear Sir/Madam,
To resolve this issue:
  1. From the Quicken File menu, choose Printer Setup, and then select the form that you are trying to print.
  2. Make sure that all selections and settings in the Printer Setup window are correct, especially the selection in the Printer drop-down list.
  3. If all information is correct, click Cancel and proceed to step 4. Otherwise, click OK after making the necessary corrections, and then try printing again.
  4. If the message persists, exit Quicken.
  5. Click the Microsoft® Windows® Start button, choose Settings, and then choose Printers.
  6. Right-click your printer and choose Properties.
  7. Click the Advanced tab, clear the Enable advanced printing features checkbox, and then click OK. Restart Quicken and try printing again.
  8. If the message persists, exit Quicken.
  9. Double-click Add Printer and proceed through the Add Printer wizard until you reach the window that asks for the printer manufacturer and model.
  10. Select the manufacturer for ex. HP, and then select the printer HP DeskJet 550C (or any other HP DeskJet 500 series printer). Follow the onscreen directions in the wizard to finish adding the printer.
  11. Restart Quicken. From the File menu, choose Printer Setup, and then select the form that you are trying to print.
  12. Select the printer you added in step 10 from the Printer drop-down list and then click OK.
Completely uninstall the old version and install the new version. Before install clear registry and temp files. Update the latest driver for printer.
Thanks
Good Luck
Sep 24, 2009 | Microsoft Computers & Internet
I have Quicken 2009 and Windows Vista, HP Printer
I've tried off and on for a year to try to get assistance from Quicken and HP because my Quicken reports would not print. Everything else printed just fine. It was so frustrating because nothing worked. I needed to get reports to my accountant and thought I was just going to have to hand write the reports. In the end, I took a photo of the screen (with the report showing), downloaded the photo to the computer, tweeked it a bit with my photo software, then prrinted it. How goofy is this to get a report from a program that is supposed to make my life easier???!!!
Aug 19, 2009 | Computers & Internet
Quicken 2009 Deluxe will not print on Vista 64 system on HP 5610 All-in-one printer - ran all the usual suspects about drivers, rebooting, selecting right printer, etc. etc. no luck. Seems Quicken does...
Me too. None of my printers worked and each time I tried Quicken crashed. But only quicken had this problem. Then I read this super simple fix:
  • Click Edit from the menu bar, and choose Preferences > Quicken Program.
  • Go to Register > Notify, and remove the check mark from “Warn if a check number is re-used”
  • Click OK.
  • Print checks.
At this location: http://tinyurl.com/moehn3
Worked like a charm. Go figure. Wasn't even a duplicate check number.
Aug 18, 2009 | Computers & Internet
Cannot open printer from Quicken 2001 Deluxe
Check intiut's website. There have been some problems with 64-bit Windows Vista. You didn't specify whether you have 32-bit or 64-bit operating system.
Aug 09, 2009 | Intuit Quicken 2001 Deluxe (256101) for PC
Inabilityy to print from QUicken 2008 under Vista 64-bit OS
I can only speak for my situation, which is Windows Vista Home Premium 64 bit with a HP7590 all in one printer. I had all the problems I read about, note I was only interested in printing "reports" from QUICKEN 2008 DELUXE.
I was able to use the Quicken PDF printer, but I just installed the HP 990C printer drive and found that report printing now works. I did delete the PDF printer before I installed the 990C, but I would guess that's not necessary.
HP considers the 990C a "generic" printer.
Hope this helps.
Aug 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Basic Quicken on Windows Vista will not print to HP psc 2410
Symptoms:
This issue occurs after updating to Release (R6). Quicken is attempting to display a duplicate check number message, when the error occurs. We have identified this issue to be caused by one or more duplicate check numbers in the checking register.
Solution 1
  1. When clicking Print Checks, the next Check # to be printed is displayed. Take note of the check #, and then click Cancel.
  2. From the Checking register, click Find and search for the check number.
  3. Edit the transaction(s) to include the correct check number, or remove the check # from the transaction.
  4. Print checks.
Solution 2
  1. Click Edit from the menu bar, and choose Preferences > Quicken Program.
  2. Go to Register > Notify, and remove the check mark from “Warn if a check number is re-used”
  3. Click OK.
  4. Print checks.
May 01, 2009 | HP PSC 2410 All-In-One InkJet Printer
There is an issue with Quicken 2007 and 2008 printing to many HP printers. Workarounds: 1) print to the Quicken PDF virtual printer, then print the resulting PDF file. or 2) Install a Deskjet 990 driver (using the add printer command) using the same port as the Officejet 7410 is installed.
Regards,
Bob HEadrick, MS MVP Printing/Imaging
Nov 02, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
104 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
