Question about Hansgrohe 10129 Axor Starck Tall Single Hole Bathroom Faucet Without Pop-Up
How to install Axor starck replacement cartridge
2 Suggested Answers
HANSGROHE US
  • 7 Answers
SOURCE: What tool is needed to
This is a pretty difficult model to work on because the bonnet nut is so slim. The way I do it is to dismantle the faucet from the sink. Remove the cap and handle (2mm set screw) and lay the faucet on it's side. Protect the finish by putting it on a towel and lay it on a firm surface such as a table or work bench. Leaving the body and spout on the table, hang the top of the faucet over the edge of the work surface. Carefully lock vice grips onto the nut. Be careful to use just enough tension to secure it to the nut. Dont go too hard, or you will just chew up the nut. Then lightly tap the channel locks with a small hammer or mallet to turn the nut counter clockwise. Do this while pressing down on the faucet body to keep it from jumping. Lots of little taps will loosen the nut which is locked in by mineral deposits from leaking. Once the nut is moving you no longer need to tap it, as it can then be turned by using your hand to turn the vise grip pliars.
Look for an old o-ring in the nut where it meets the top of the cartridge and replace it with the supplied new one. Also replace the two seat washers that sit in the faucet body at the base of the cartridge with the supplied new ones. The newer cartridge will be smaller diameter, but you will see that the height is the same and it works perfectly.
Lastly, if this is all too difficult, Hansgrohe will allow you to send your faucet in under the warranty. We will repair, test, and send it back to you. You can call us at 800-334-0455 for service in USA, or contact us through the web site www.hansgrohe-usa.com
Posted on Sep 02, 2011
Installation Guide for Axor 10010001 Starck
This site will not allow me to post a link or instructions. You can contact Hansgrohe Tech at 1-800-334-0455 press 2 for Tech and we can send you the link or instructions for your model. You can also find them on the Hangrohe Pro-Site.
Apr 12, 2013 | Grohe Plumbing
I have a brand new Axor Starck X 1007001 that is leaking from the bottom of the control lever. Is there an adjustment that needs to be made or is the faucet defective?
There are two possible causes for this. It could be the cartridge leaking around the top or it could have a damaged or missing o-ring between the spout and top of the faucet. Either of these could cause a leak to show only when the faucet is run. If you contact Hansgrohe Technical we can get you the parts to repair the faucet or you can send it in and we can repair it for you. 1-800-334-0455. press 2 for Tech and ask for David Scarborough. I'd be happy to help.
Apr 07, 2013 | Plumbing
How to remove starck shower pole from wall
The first thing to do would be to identify the unit in question. If you have a model number we can provide the instruction manual for the wall bar. If no model number you can call me at Hansgrohe 1-800-334-0455. Press 2 for tech and ask for David Scarborough. I'll be happy to help you identify the unit and provide instructions on the unit.
Dec 12, 2012 | Hansgrohe Axor Hansgrohe Starck Shower...
How to clean Axor Terrano Showerpipe - hot water part of mixer seems blocked
There are filter screens on the thermostatic cartridge inside this unit. You will need to remove the thermostatic cartridge and clean the filter screens. If cleaning the thermostat cartridge does not resolve the issue you may need to replace the cartridge. If you need further assistance feel free to contact me at Hansgrohe Technical services. 1-800-334-0455. prees 2 for tech and ask for David Scarborough.
Aug 30, 2012 | Home
What tool is needed to unscrew/dismantle the Hans Grohe Axor Starck joystick tap; and to stop dripping is there a washer to replace or does one have to replace the whole joystick cartridge? Thanks Craig
Sep 02, 2011 | Hansgrohe 10129 Axor Starck Tall Single...
Want to buy a thermostatic shower column which I believe was made in china--it looks beautiful but only has a 1 year warranty --sold only by Rona--will i have problems with it?
One year warranty is just good enough. Verify from Rona
if it will really honor the warranty. Nowadays, Chinese
product are now better than before. They learn it from the
American companies having facilities in China for lower
labor cost, and no strikes. You may buy the Thermostatic Shower.
Nov 22, 2009 | Hansgrohe Axor Hansgrohe Starck Shower...
Insufficient hot water from Gledhill pulsacoil 2000
changing the shower head will not do anything.to do what you want,you would need more BTU's or a bigger unit to supply more water,someone may be hogging the water also.
Feb 25, 2009 | Hansgrohe Axor Hansgrohe Starck Shower...
Hansgrohe 10129 Axor Starck Tall Single Hole Bathroom Faucet Without Pop-Up Logo
207 people viewed this question
Top Hansgrohe Plumbing Experts
GCcontractor
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Hansgrohe Plumbing Expert? Answer questions, earn points and help others
