Question about Craftsman 550 Torque 22 in Deck 2n1 Side Discharge Front Propelled Lawn
What kind of oil do you put in a craftsman 550 silver edition
I need to purchase oil for my craftsman 550 silver edition lawn mower
  • 22 Answers
SOURCE: oil change
hi,the engine uses sae 30 oil,takes about 1 litre of oil,you can get this from most garages or mower centres,hope this helps
Posted on Apr 08, 2009
wadembly
  • 448 Answers
SOURCE: I need a manual for a Craftsman LTX 1000 year 2001
it takes sae 30 oil & if i can get the model# of the unit i can see if i have a manuel for it thanks wade
Posted on Jul 04, 2009
lasvegasrich
  • 65 Answers
SOURCE: Looking for a manual on a Craftsman Eager-1 .
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=131.90300&productCategoryId=1503700&brandId=0247&modelName=ROTARY-LAWN-MOWER&diagramPageId=00001&documentId=00035640&pop=flush
PARTS LIST AND PICTURE.. WHAT DO YOU NEED TO KNOW OR DO??
Posted on Aug 22, 2009
bargainbin2
  • 123 Answers
SOURCE: 13.5 hp Craftsman lawn mower 5-speed
Here is a picture to help you place it on right. There are two deck designs pick yours.
Posted on Aug 29, 2009
  • 16 Answers
SOURCE: craftsman eager-1 lawnmower will not start
Hi, The first thing I always check for is fresh fuel (less than a couple of months old) old unleaded may well be fine in your car but low compression engines fitted to garden equipment need fresh fuel. next thing to check is that the choke flap is closing fully, dont rely on the position of the control lever, remove the airfilter cover and see that the flap is fully closed, if it's cracked open just a little bit it will stop engine starting ( unless the filter is really dirty) another thing to check is that the blade is tightly secured, on direct drive mowers the blade acts as a flywheel. did you hit an obstruction the last time you used it, if you did you may have sheared the flywheel key(poor spark on points ignition or good spark but timing out of sync on electronic ignition. hope this helps, regards Tony (England UK)
Posted on Aug 31, 2009
What is the spark plug gap for a craftsman 5.5 silver edition lawn mower. model # 247.385100
The spk gap for a 3.5 horse power single position engine is around 18th thousandth on the feelerguage for a 4 :-P no real difference but 15_20 thou works fine 5 :-P or higher engines 25 thou max gap
Jul 03, 2016 | Craftsman Garden
WHERE IS THE PLUG TO DRAIN OIL FROM A CRAFTSMAN 550 SILVER EDITION LAWN MOWER?
Almost all drain plugs are under the deck. Some are a 4 sided nut sticking out and some are an inner plug (looks like an allen shape plug)
Oct 14, 2014 | Garden
What type of oil do I use on my craftsman 550 push
Use a detergent type oil, with an A.P.I. service classification of SG-SL. I'm thinking you will be operating the mower above 32 degrees F so use a 10W30 weight of oil. Hope this helps. Mike
Oct 10, 2014 | Garden
Too much smoke coming out of my lawn mower
ether to much oil are you have bad rings if rings get a snapper lawnmower
Jul 01, 2014 | Craftsman 550 Torque 22 in Deck 2n1 Side...
What kind of oil can I put in my Craftsman lawn mower
it is best to use what in recommended in your climate hotter climate lighter oil uasally the main oil to use is called 10w-30 no weight rateing just 10w-30 its a light oil made specifcally for lawn mowers engines
Apr 19, 2014 | Garden
Craftsman 550 oil plug concealed under the debris shield. How do I remove the debris shield?
on push mower i run them out of gas turn it on its side and drain it from the dip stick tube
Jun 06, 2012 | Craftsman 550 Torque 22 in Deck 2n1 Side...
I have a push lawn mower (Cratsman 550 series Silver Edition), but I dont know how to change the oil on it. Could you help me with this.Thank you
There are a couple of ways. One, if you can elevate the mower, is to loosen the plug underneath the engine. It takes a 3/8" square drive, like for a socket. Loosen and drain to a catch. I don't do this, everyone I tried was too stuck to risk putting extra force one, but yours may be a lot newer. The one I use on a regular basis is to run out the fuel, or empty the fuel and then I remove the oil dipstick and I turn the mower on its side to drain into a catch. This is the one I have found to be the easiest for me. If you do not want to do that, I was at BigLots last weekend and they had a pump that would have worked for that back by the automotive section. You could look at an auto parts store or some other store for such a pump with tubing, this would mean not having to tip it at all.
I hope this is helpful for you.
Sep 01, 2011 | Craftsman Garden
I have a craftsman briggs and stratton 550 series silver edition lawn mower and when i turn my lawn mower on the engine revs and then lets of over and over again like it is about to die but dont... what...
i have a brand new craftsman briggs &stratton silver engine series 5.50 158cc it will start but will not run unless i keep pushing the prime button to give it gas once i stop so does the engine
Oct 22, 2010 | Garden
Need to put oil in and don't know what kind of oil to put in or if it's gas oil mix????
ADD SAE 30 SMALL ENGINE OIL. 18oz TO 20oz
SEARS SALES A 20oz BOTTLE OF CRAFTSMAN SAE 30 OIL FOR $2.59
Oct 12, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
Brand new 550! push red pump button 3-4 times... pull handle..mower starts up then dies. Will not continue to run..
Sounds like wet fuel! The priming puts enough gas in to start it but the running circuit does not.
Check your gas can for a layer of water on the bottom of it. If it has a lot of water in it you should dispose of this fuel at a gas station that collects used oil and gas. Drain the mower and take that gas away too.
Put in fresh gas from a known clean and dry source.
Let me know what you find ok?
Good luck and be careful!
Jun 29, 2010 | Craftsman 550 Torque 22 in Deck 2n1 Side...
Craftsman 550 Torque 22 in Deck 2n1 Side Discharge Front Propelled Lawn Logo
51 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
