Water is pooling in my floor board on the passenger side.
  • Ken Bledsoe May 11, 2010
    The heater core is going out. When ever the heater core goes out the only thing that is a for sure tip off is the water on the passenger floor. Heater core is straight up from there. ken
  • 82 Answers
This could also be condesation coming from the A/C evaporator coil if the drain line is clogged up.
Posted on Jan 10, 2009
Toyota 2008 highlander water on rear center passenger floor. A/C drain outside passenger side draining.Seems to puddle on rear floor when A/C is on high and recirculating fresh air. Any clue? problem?
For water to pool on the floor with AC on should indicate a plugged evap drain tube. The tube will have to be inspected for kinks and debris lodged in it. It may be draining some of the water but not enough.
Jul 09, 2015 | Toyota Cars & Trucks
Why do I have cold ac on driver side and stale air on passenger side. what could itbe? and notice water and antifreeze on passenger side floor board well at least that what it smells like like to me.
antifreeze anywhere inside the cabin is a sign of a leaking heater core. Rub the liquid between two fingers. If it feels oily, it's coolant.
Sep 26, 2017 | Cars & Trucks
Hearing water noises behind dash in 2009 Chevy cobalt
your heater core is behind the dash on the passenger side. The antifreeze travels through it as its cycle through the engine. Thats what gives you hot air when you turn your heater on. If you find that there is water dripping or pooling in the floor board of the passenger side then your heater core needs to be replaced and its not an easy task.
Aug 18, 2012 | Chevrolet Cobalt Cars & Trucks
A/c leaking water passenger floor
Usually a sign of a plugged drain tube.
The HVAC box has a tube that drains the water onto the ground.
The tube should be at the bottom of the firewall near the passenger floor.
Jul 24, 2012 | 2002 Nissan Sentra
My passenger side floor is saturated with water when it rains. When I make right turn I hear what seems like water sloshing.
If you can smell a little bit of a sweet smell from the water on the passenger side floor, or if it has an oily film to it, you may have a leaking heater core.
They usually leak on the passenger side floor, and that might explain why you hear water sloshing around.
If you can run the engine for about 5 minutes and then turn your heater on. Look under the dash in the area where the dash meets the floor board and see if you can see anything leaking.
I hope this helps you.
Feb 16, 2011 | 1997 Dodge Caravan
Water leaking onto paaenger floor board when a/c
There is a drain to the hvac box under the hood passenger side. It's most likely stopped up.
May 26, 2010 | 1995 Jeep Grand Cherokee
1999 Jeep Wrangler 4 cylinder (manual tran). I noticed a large pool of water in the floorboard on the passenger side of my Jeep. This was after driving for about an hour with the a/c on in Texas at about...
My dad has a 2004 Dodge Dakota with the exact same problem, the passengers side floor board is soaked with water after running the AC. Also there is a pool of water that collects under the truck.
We are getting a mechanic to look at it, I will post what the problem is when we find out.
Jun 25, 2009 | 1999 Jeep Wrangler
Water on floor board on passenger side of 1991 Buick Century
Engine coolant will feel oily and the windshield will fog up and the car will stink. If it is just water it could be coming from the passenger door weatherstrip at top. The ac drain tube , if stopped up will also leak water in the floorboard.
Jun 17, 2009 | 1991 Buick Century
Heating & Cooling Logo
115 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
