Question about Canon i 320 InkJet Printer
Canon i320 printer is busy
I just installed a Canon i320 printer, and although the computer reconginzes it, it is always flashing green/orange and trying to print brings up the message printer is busy.
    President:
  • 8,637 Answers
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
Light flashes orange/green, orange/green continuously
Does it have a cancel button? If so press it, check the ink and paper and stuff, good luck.
May 22, 2011 | Canon BubbleJet i320 Printer
Light kee flashing orange/green and says computer is busy when there is nothing in print queue
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
Mar 29, 2010 | Canon BubbleJet i320 Printer
Canon Pixma ip1000 dismantle
Hi there you can try
Temporary Fix
This always works in case you need your printer for Emergency ^_^.
  1. Turn off the printer
  2. And unplug the printer power cable
  3. Press and Hold the POWER button
  4. Plug the power cable again
  5. The indicator (LED) should be green
  6. Press and Release the RESUME button, the indicator (L.E.D.) should be orange
  7. Press and Release the RESUME button again, the indicator (L.E.D.) should be green
  8. Release POWER button
  9. Windows will detect new printer and you just have to install it again.
  10. It will create a copy of Canon i320 printer. Just delete the old one and rename the copy.
  11. You are done.
Jul 09, 2009 | Cannon Canon i960 Photo Printer
Will not print. says printer not responding
Canon i320 does not want to print light flashes green and orange alternatively. Please help. I tried the above, but nothing works
Apr 20, 2009 | Canon BubbleJet i320 Printer
Waste ink absorber is full-canon pixma ip1000
Temporary Fix
  11. You are done.
Feb 03, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
I have a canon i320. the light flashes green, orange. does not print. I tried resetting the printer but to no avail. What is the next step?
it means that waste ink is full,
do this:
How To: Reset Canon Printer
I have try to find out how to reset many canon printer in my office. I
was try to googling to find the best way and quickly how to reset it.
And in google I was found two way how to do it. With Manual Reset and
with Software reset. I will give some advice how to do that with first
method, yes manual reset.
On this point we will do this with my Office printer, Canon i255, i320, ip1000.
For i255, i320
Waste Ink Counter Reset.
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
or Step This Step
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.) should
be orange.
5. Press and release the RESUME button again, the indicator (L.E.D.)
should be green.
6. Release both buttons.
Canon PIXMA iP1000
Waste Ink Counter Reset Manual for Service mode
be orange.
should be green.
Nov 30, 2008 | Canon BubbleJet i320 Printer
Canon i320 amber light flashing will not print
I believe that 7 amber flashes refer to a cartridge error. Check that the cartridge is seated correctly.
Nov 05, 2008 | Canon i80 InkJet Printer
Waste ink basket full Canon iP1000
Temporary Fix
  11. You are done.
Sep 01, 2008 | Canon PIXMA iP1600 Printer
On/off button & restore button blink green & orange; printer doesn't work
the problems are :-
  • cartridges are not recognised or installed
  • there is a paper jam.
May 22, 2008 | Canon BubbleJet i320 Printer
Canon i320
Try unticking ENABLE BIDIRECTIONAL SUPPORT on the Ports Tab under Printer Properties accessed through control panel / Printers and Faxes. Try to print - get error message Enable Bidirectional Support. Reverse back into Ports Tab and re-enable Bidirectional Support and try printing again.
Jan 13, 2008 | Canon BubbleJet i320 Printer
Canon i 320 InkJet Printer Logo
615 people viewed this question
old marine
old marine
Corne Viljoen
