I get a bust message when i pick up a second phone and did not receive this message before.
If you get a busy signal when you pick up your second phone to participate in a call in progress, make sure privacy mode is set to off. Enter the menu, then scroll to initial setting, then scroll to privacy mode, set to off, then click save. You can also go directly there by entering menu, then #194, set privacy mode to off, and save. Make sure to do this on all handsets connected to the line.
SOURCE: Panasonic KX-T7730-when receiver on hook plays on hold music
walk up to the phone and without touching anything else, press "1".
No music.
Carl
SOURCE: Where can I find the Business Telephone System for the Panasonic
Although it doesn't look like a lot of information in their guide, heres a link to Panasonic's manual:
http://service.us.panasonic.com/OPERMANPDF/KXT7630.PDF
Hope it helps.
SOURCE: I need help setting speed dials on a Panasonic KX-T7730!!
Hello, from the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
PLEASE rate this answer if it was helpful.
Thank you.
SOURCE: panasonic KX-TG1855AL envelope and speech bubble symbol
Hi, you probably won't get this anymore, but here is the fix (I had the same problem and couldn't get rid of it. Had no messages or calls that I hadn't viewed). You will laugh but press the Clear / Mute button for a few seconds. That is the bottom right button out of the four that are around the big round one. It has a C on it, a line under the C and the mute symbol underneath... Good Luck. Julia
SOURCE: Panasonic KX- TGA652 -- Accidentally put in wron
To erase:
menu #331 press and hold clear until all digits are erased.
To enter number:
menu #331 enter up to 24 digits SAVE then OFF
You may need to add pauses between the number and your pass codes.
