Question about Garden
Poulan pro PBV 200 fuel line diagram
Plastic linek in tank broke
5 Suggested Answers
bulldogchief
  • 388 Answers
SOURCE: what type spark plug for the Poulan Pro PBV 200 LE
RCJ6Y is the plug number, you can get them at any home improvement store for about $3
Posted on Sep 11, 2009
taran_2005
  • 10515 Answers
SOURCE: what is the gap setting on coil for poulan pro pbv
It should be 0.010.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 05, 2009
2strokeguy
  • 183 Answers
SOURCE: trying to get my poulan
How do you know that the coil is bad? Have you checked it with an inline spark tester? It is very rare for this model to burn up an ignition module.
Please check for spark with an inline tester. If there is no spark with that tester, then disconnect the on/off switch and retest. If there is no spark with the switch disconnected, then indeed the module is faulty.
To access the module, the engine has to be removed from the case. Start on the right side and remove the muffler cover and muffler. This is a good time to visually inspect the cylinder. Look into the exhaust port with a flashlight and look at the piston. If there are scratches/scoring on the side of the piston or cylinder walls, then the blower is probably not worth repairing.
On the left side, remove the air filter cover, then remove the filter base (carb cover). This will expose the carburetor. Remove the 2 fuel lines leading to the carb, and then the throttle linkage and remove the carb. Next, remove the carb mount.
Now, remove the 15 or 20 screws that hold the plastic case halves together. The lower hinged cover will have to be releases before the case will seperate. Once you have the case apart, the engine can be removed. The ignition module is now exposed and can easily be replaced.
To set the proper gap of the new module to the flywheel, use a clean and dry business card. Lay the card across the magnet of the flywheel and place the module against it, then install the screws and tighten up the module. Remove the business card.
While you have the blower down this far, check to make sure the cylinder is tight against the crankcase. This model is prone to having the cylinder come loose and will effect compression.
Reassemble in reverse order. Take pictures as you go to aid in reassembly. If the blower is more than a couple of years old, I would recommend to replace the fuel lines at this time. It will save a repair down the line.
You will need allen wrenches, phillips screwdriver, T15, T20, & T20 torx, a large, clean workspace. This is not a repair for the beginning mechanic, but with patience, it is not too difficult.
Good Luck !
Posted on Nov 18, 2010
bcharais
  • 278 Answers
SOURCE: how to change fuel lines in poulan pbv 200 blower/vac
im not familiar with those but donyboy73 on Youtube may be able to help. he does a lot of small engine work
Posted on Aug 07, 2012
Need diagram on how to route gas lines from carb to gas tank
As a rule you will need to put the smaller line in the smaller hole in the tank and the larger one in the larger hole. Cut the line on a 45 degree angle to get it started through the hole and then from the inside of the tank pull the line through. Be sure to put the fuel filter back on the line to the carb. in the tank.
Sep 10, 2015 | Poulan Pro Bvm200vs 25cc 2-stroke Gas...
Fuel line diagram poulan wild thing 40cc
I can't give you an actual diagram but a I can try to explain how it should go. There is a line with the filter in the tank that goes to the bottom of the carb, there is another line from the carb that goes to the in port of the primer bulb, the out side of the primer bulb will go back down into the fuel tank. The primer will pull gas from the tank through the carb into the bulb then return the gas from the bulb to the tank
Feb 01, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How to change fuel lines in poulan pbv 200 blower/vac
Aug 07, 2012 | Poulan Garden
Poulan Pro blower PBV 200 when it runs will only keep running on half-choke. I have had the carb serviced every year by a shop who said its the ethanol thats gumming it up. I switched to Ace synthetic...
I have never used, nor heard recommended Ace synthetic fuel. I do believe in synthetic lubricants, and the fuel may be part of the problem. See if you access the H and L mixture screws on the carburetor and adjust them. Here is how that is done:
http://www.zamacarb.com/tipspage.html
Sep 02, 2011 | Poulan Pro 25CC 2Cycle Gas Blower
What is the gap setting on coil for poulan pro pbv 200 le
It should be 0.010.
Hope i helped you.
Oct 05, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
What type spark plug for the Poulan Pro PBV 200 LE
Sep 05, 2009 | Poulan Garden
On weedeater blower and vac gas line is broke from carb into tank does it just connect to fuel filter in tank model 1925
Yes if your asking about the fuel line yes it hooks to the filter out thru the wall of the gas tank straight into the carb. if it broke out side the tank you can try a smaller plastic hose to stick inside to reconnect the two parts. if it broke inside the tank try to replace as one hose.
Jul 12, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
299 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
