Printer setup Did you get your HP setup figured out? I'm having the exact same issue.
    President:
  • 8,637 Answers
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
Printer is too slow to print once the command is given from PC
Hi
While printing from the USB Port sometimes slow printout/data transfer will result in slow printing of print jobs. or The printer might be printing slow , pausing in between print jobs , or intermittent printing. The symptom solution is mention below, read and follow the instruction.
Solution 1
After the printer is installed on the USB Port, check the description under the Ports Tab what is selected. Please refer to the figure below : c00873625.jpg Using the USB/ Virtual Printer Port and DOT4/ HP Laserjet 2420, under the Port/Description Tab printer speed will be as per the standard. Whereas using the DOT4/ Generic IEEE 1284 under Port/Description Tab, Printer speed will be very slow. If DOT4/ Generic IEEE 1284 is selected by default, then you have to uninstall the USB driver from the Device manager and plug in the USB cable again. Then it will detect the printer and USB port with respect to the printer model. Insert the Driver CD as prompted and by default it will select the DOT4 HP LaserJet2420 Port.
Solution 2
  1. Insert the HP LaserJet 2400 print series CD-ROM.
    NOTE: If the HP Software does not automatically start, click Start , Run , and then Browse . Browse to the CD-ROM drive at the top of the window under look in and select Setup.exe .
  2. Select Modify Installation . Figure 1: Modify Installation c00369540.gif
    NOTE: If Modify Installation is not available See Modify Installation is not Available.
  3. Select the Language of your choice. Figure 2: Select Language c00369541.gif
  4. Click Next. Figure 3: Setup Wizard c00369542.gif
  5. Verify Reinstalling an existing printer is selected. Under Select the port for this printer , choose USB001 or Dot4_00x and click Next . Figure 4: Choose Port c00369543.gif
  6. Select desired Features and click Next . Figure 5: Select Next c00369544.gif
  7. Click Finish . Figure 6: Select Finish c00369545.gif
Uninstall options
  • First verify if an uninstall options is available. If an uninstall option is available under Start, Programs, HP LaserJet 2410 2420 2430 , use this method to uninstall the printer.
God Luck
Sep 09, 2011 | HP LaserJet 2420 Printer
Why does my printer print only emails, but nothing off the internet?
You probably have an issue with the Smart Web Printing. Go into your add remove programs in control panel (sorry , you didn't specify the OS, so I am quoting XP here) and remove smart web printing.
Ya, that software has caused many an HP tech support specialist no end of trouble.
I eventually told people to start removing it (not exactly company policy) and go figure, everything would start working perfectly!
(But don't tell HP that, it's an "undocumented" solution!)
Feb 24, 2011 | HP Photosmart C6180 All-In-One InkJet...
Printing error occurs when printing off internet. It will print my emails.
If your printer is an HP, here's your fix...
Feb 24, 2011 | Office Equipment & Supplies
Hp photosmart 7200 and hp laptop are not communicating. wierless signal strengh is excellent. cancelled , documents cancelled and error message appears.
Click on the link to resolve printing issue on wireless network -> Link
Click on the link to find out if the HP Printer is on wireless network on not -> Link
To Setup the printer on wireless network, follow the steps below
1. Press the SETUP Button printer front panel
2. Scroll to Network - Press OK
3. Scroll to Wireless Setup Wizard - Press Ok
The printer will start searching for wireless router.
Choose the SSID ( Network ) and enter SSID ( network key if setup ) and Press OK
You should get a message as Printer Wireless Setup complete.
Run the HP Printer Software Disk and Choose Add a printer and Choose Wireless Installation and follow the instructions on the screen to complete the setup
You are ready to Print and Scan
Oct 12, 2010 | HP Photosmart C4580 All-in-One InkJet...
My printer is a HP officejet Pro 8500 wireless.\r\nIt is 7 months old message keeps saying "pump motor stalled." What should I do?
This could possibly be Hardware issue.
Solution
Follow these steps in the order presented to resolve the issue.
Step one: Perform a semifull reset
1. Press the Power button to turn off the HP product.
2. Unplug the power cord from the wall outlet.
3. Unplug the power cord from the back of the HP product.
4. Wait for 20 seconds.
5. Plug the power cord into the wall outlet.
6. Press and hold # and 6 while plugging the power cord back into the HP product.
7. Press the Power button ( ) to turn on the product.
8. Follow the instructions that display on the HP product to select the settings.
Step two:
1. On the product control panel display, touch the Setup icon, and then touch Tools .
2. Touch Clean Printhead .
If these steps resolved the issue , there is no need to continue troubleshooting.
If these steps do not resolve the issue, Call HP support since your printer is in warranty as you said its only 7 months you purchased the printer
Call the # 1-800-474-6836 for HP Support ( US )
* Please rate this solution with thumbs up and comment if answered to your satisfaction
Sep 29, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Which driver do I select in printer setup?
h41140.www4.hp.com/mac_connect/.../Mac_OS_launch_special.pdf
h20000.www2.hp.com/bizsupport/.../Document.jsp?objectID... -
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=72897&lang=en&cc=us&prodTypeId=18972&prodSeriesId=72895&taskId=135
These above website will give you all the advice you need on this issue.
Jun 25, 2010 | HP PhotoSmart 130 InkJet Printer
Do not have setup disk, hooks to computer through
Go to next support site and select the exact type of All-In-One printer you have:
http://h20180.www2.hp.com/apps/Lookup?h_pagetype=s-001&h_client=S-A-R163-1&h_page=hpcom&lang=en&cc=us&h_lang=en&h_cc=us&h_query=psc2210
Disconnect the printer.
Install the matching drivers and software.
Do not connect the printer until installation has completed or if during setup you are told to do so.
Apr 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
Can i install hp deskjet 3600 software for hp printer hp deskjet 3650?
No, you have to install the exact software for HP Deskjet 3650 Printer model. HP Deskjet 3600 Printer model software doesn't support for HP Deskjet 3650 Printer model
For technical support call us toll free 1-888-249-8496 or visit 123 hp com Quick HP Printers Setup Easy Installation Guidelines
Oct 08, 2009 | HP DeskJet 3650 InkJet Printer
HP printer cannot find access point and I'm not sure what to do.
You must first connect your printer to the pc using usb cable, then run installation wizard that is on the CD that came with the printer.
Wizard will guide you through the setup orcess where you will provider your routers ssid (linksys) to your printer, and your printer will use that ssid to connect to your router.
After the Wizard setup is done, it will tell you to disconnect the usb cable and only then your printer will work on wireless.
Good luck,
Milan
Jun 01, 2009 | HP Office Equipment & Supplies
24 people viewed this question
k24674
jasbo
jasbo
