Question about DeLonghi KG79 Grinder
Delonghi K79 grinder won't make crema coffee - DeLonghi KG79 Grinder
3 Suggested Answers
SOURCE: Delonghi DCG49 is suddenly quieter and will not release coffee
Had this problem with my burr grinder, coffee (or something else) is clogged between the burrs and the output chute, so new coffee can't feed in from above. You can try a few things:
1. Unplug and try to dislodge the blockage from underneath with a toothpick.
2. Disassemble and remove the blockage.
3. I've had luck with drizzling a little bit of cooking oil on to the burrs,letting it soak in a while, then running it, the clumped coffee came loose. It made a terrible mess in the bin, but I ran a couple cups of beans through and it cleaned up the oil.
Good luck~
Posted on Feb 12, 2010
Testimonial: "You were right about the clog. I tried the white rice fix seen elsewhere and it's grinding perfectly again. Thanks."
SOURCE: My DeLonghi KG79 coffee grinder
I should imagine one of the safety switches are not closed. The lid of the maker must be on and the filler has to have its cap on and inserted in the machine.
Posted on Aug 08, 2011
My Coffee machine Delonghi doing expresso without foam today. Before doing good expresso with foam. help please.
Espresso should have crema not foam, foam is air added to coffee, like Starbucks does. Issue lays in the grinder and coffee quality. Recommend using Italian espresso bean like Miscela d Oro
Apr 14, 2014 | DeLonghi Coffee Makers & Espresso Machines
Poured water in my delonghi magnifica beans hopper.
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
Dec 31, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi Magnifica 3500.. error message says "grind too fine, adjust grinder, insert water spout, press ok" message never goes away. I called the Customer service.. she said try again.. to...
Try removing the beans from the hopper and use a vacuum to CLEAR/REMOVE any grounds and then adjust the grinder 4 clicks clockwise. If this works Re-adjust grinder to where you get nice crema.
You can try using all ready ground coffee by following the instructions in your manual (if you don't have a manual let me know) to test it.
Jan 12, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Good luck~
Feb 09, 2010 | DeLonghi DCG49 Electric Burr Grinder
How do I adjust the grinder to make the coffee grind finer? ie. the coffee is pouring way too fast and giving no crema.
Depending on the model and make on the grinder you just have to turn the adjustment collar clockwise for finer, that is the case with most grinders.
Nov 11, 2009 | Coffee Makers & Espresso Machines
I bought a portafilter without the pressurizing ring, now I can't get a crema, what's the problem
HI
Crema is created by pressurizing the grounds. The basket with the ring can create the pressure in the basket. If you don't have a pressurized basket, you have to make the grounds fine enough when compacted in the basket, to create the pressure. This is an art that can be mastered, but you need a real good grinder, and fresh coffee beans. Old beans won't give good crema.
Oct 15, 2009 | Solis Crema SL-70 Espresso Machine
My Delonghi Magnifica (manual not digital) won't start the grinder, could this be the circuit board?
Delonghi Magnifica comes up with waste tray full light when there is nothing in the tray. It doesn't make coffee, the grinder is rotating and appears to be clear. Could there be a blockage below the grinder, if so how do I access it.
Aug 21, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
DeLongi coffee mill #DCG-4TB
DeLonghi PARTS AND ACCESSORIES
1 (800) 865-6330.
8:30 a.m. – 5:00 p.m. (EST) Monday through Friday.
Oct 24, 2008 | DeLonghi Electric Coffee Mill Grinder
DeLonghi EC140 Espresso filter
Why is the coffee not flowing aas fast and why is the crema not consistant?
Mar 27, 2008 | DeLonghi EC140 Espresso Machine
Sempre Crema
before changing the filter, try cleaning it following the instructions in the manual(page 9, i'll attach it to my post). The Delonghi web site also offers the following solution: "The coffee may have been ground too coarsely or the grounds may not have been pressed with a tamper. Also check to make sure that the coffee is not old or stale." Parts are supposed to be available from the delonghi website(www.delonghi.com), but i couldn't find where they hid it. but there's an option on the site to go to local sevice centers, lets say you live in canada, then you pick the canadian website from the pull down menu on the top, the customer support tab, then service center on the left. Good luck
Jan 29, 2006 | DeLonghi EC140 Espresso Machine
DeLonghi KG79 Grinder Logo
143 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
