Refill ink cartrige with wrong color in wrong hole color cannon 211
SOURCE: Cannon Pixma MP500 - Waste Ink Reset
I don't belive there is a reset device for the MP500 tanks. However, when you get the empty error message, just follow the instructions about pressing OK as many times as it asks for (I think it is four time). At that point, you can continue to use the cartridges. The printer will no longer keep track of the ink level. You will have to do that yourself. But, you can continue to use the printer with all colors.
Posted on Jan 03, 2008
map9966
  • 2351 Answers
SOURCE: refill colored ink, what holes, lexmark x5470
To open the printer, just above the front control panel you use both hands & pull upwards. The whole top of the printer will open up. The ink cartrifges will be close to the center of the opening. The printer should be on for this. There are two ink cartrages. The one with the black lid is for your black ink. There is a small tab in front of the cartridge lid. Push down on the tab & the lid will open. Remove the old ink. Remove the tape that is protecting the the bottom & copper back side of the new ink. Place the ink into the printer. The copper back that runs from the bottom & up the back side about 3/4" goes into the printer cartridge. The colored ink goes into the other cartridge holder, it's lid is blue. Again press the tab just in front of the lid & it will pop open. Repeat the above removing the protective tape & install the ink.
The ptinter will want to run either a test page or allignment page or both. You will need your manual. If you do not have your manual you can download it from this site. Click the link below.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=f7f0a21c03aee016b79da0cdbb74cf9f&q=Lexmark+X5470
Click "Start download" & save it to your Pc.
Have fun!
please vote...
Posted on Feb 07, 2008
Idaho_Biker
  • 32 Answers
SOURCE: ''low ink'' message with newly refilled tank
Well I did some Research and came up with this "Link" that MAY Help You (Both) about this issue, this is by no means "My Expertise" area, Just decided to go out and "Look" around....seems like a Great Place to start.
http://forums.afterdawn.com/thread_view.cfm/682547
Posted on Apr 10, 2009
SOURCE: how to reset printer to recognize refilled cartridges
Reset is not needed. Just turn off your printer power supply and turn it on. It will automatically detect the newly installed cartridge, provided the original compactible cartridge is installed.
Posted on Aug 03, 2009
SOURCE: refilling a dell 948 color ink cart #11
Alright, I gave in and busted open my Series 11 KX703 color cartridge to figure out how to refill it. As Inksaver pointed out there are six columns which ultimately lead into three ink wells the bottom two (next to the cartridge head) are magenta, the upper right two are yellow and upper left two are cyan. Each well has one sponge in it that soaks up the ink. Each of the six columns has a hole predrilled in the center of it just below the top layer of plastic (about 5/16" from the left and right edge and 1/4" from the top and bottom and 1 3/16" (midway) from the top and bottom for the center two holes).
When I do it again (with a new cartridge since this one is busted), I'd drill three holes, one lower right and the two center holes, push the metal syringe down into the foam about midway and inject each of the foams with new blood. If someone else tries let me know how it goes. Hope this helps.
Posted on Feb 27, 2010
Canon mx330 how to change ink cartridges
Use the thumb drill to literally drill a hole into the side of the old cartridge. Make sure to chose a location that's closer to the top of the ink cartridge to avoid over spillage when you add the new ink. Once you have the hole just squeeze in some ink of corresponding color into the hole. Not a huge amount, but enough to get some use out of it before the next refill. I highly recommend covering the hole afterward with a sticker or something so that you don't dry out the cartride. Reinsert the cartridge into the printer and use. (: All set!
*Note: You may have to reset the count on the cartridge to avoid getting messages that the ink need to be changed. From here on in, use your eyes to determine if the cartridge needs a refill (:
Dec 07, 2014 | Apple Nano 69472169 4X130Ml Premium Refill...
I bought a new Cannon PIXMA MX320 with no ink cartridge, the manual says that it requires PG-210 & CL-211, while the cannon site says it works with the PG-510 and CL-511. so my question is do they both...
Cannon cartidge numbers are quite confusing to say the least, but your printer requires PG-510 and CL-511, PG is black and CL colour.
The 210/211 is a non european number, but they are the same as CL-511 and PG-510.
Hope this helps.
Jul 01, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
What ink can i refil my my series 11 ink cartrige ??? or another cartrige thats a hp or cannon or epson that will fit in my dell 948 printer
Hello. You can refill the existing cartridge without a problem. Other brand cartridges will not work as they are all programmed only to use DELL model cartridges.
To Refill the cartridge you simply need to pull the label off, Drill the Air holes out, test what colour is behind the hole by sticking a toothpick into it and inject the correct colour.
If the cartridge leaks from the print head then the cartridge has been overfilled and you need to **** out ink (half ml at a time) until the dripping stops.
The only issue with this is that the printer may not accept a cartridge that it thinks is empty, and even though you fill it, the in-built counter in the cartridge will still read "0"
Some models will print with a empty cartridge, constantly reminding you that it is empty. if you simply ignore or click continue you can keep on printing, but some models will not print at all if it thinks the cartridge is empty.
I hope this helps Regards GM
Jun 06, 2011 | Dell 948 All-In-One InkJet Printer
Have replaced cartridge with one of my refilled cartridges in a canon PIXMA MP830, and am getting an alarm U071,that reads "more than one ink tank of the following color is installed". This is of course...
Printers have a mechanism to detect refilled cartridges. By default it does not accept refilled ones. But there's a work around. Have a set of two (preferably 3) cartridges , refill and cycle them. This way the printer wont be able to detect that you have inserted a refilled cartridge.
Dec 03, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Just had my color cartridge refilled, and reinstalled correctly. However, the printer will not print with the color cartridge in, but will print with the black cartridge only.
your newly installed cartrige which is the colored one is not detected or mybe damage....may i ask if how many times did you refill already your cartrige?refilling a cartrige can cause damage to its circuit i suggest purchase a new colored cartrige and see if it works.
Oct 09, 2009 | HP DeskJet 845c Printer
How do i refill my cannon mx300?
Go to this link. In the search window in the center of the screen, type "replace ink" and click on the Search button. Now select "how do I install the ink cartridges". You will have an illustrated guide (removing cartridges is shown at the bottom).
Aug 20, 2009 | Canon MX300 Office All-In-One Printer
Mar 06, 2009 | Office Equipment & Supplies
Refilling Cannon 106 cartrige streaks on page.
when you start using refill kits they messup you machine you will need to use the oem toner for the canon good luck canon sr tech
Jan 22, 2009 | Office Equipment & Supplies
Refilling ink cartrige 22
black on the right color on the left
Jun 05, 2008 | HP Deskjet F335 All-In-One InkJet Printer
Cannon IP1800 Ink Refill
need to know how to refill the cartridges. I don't see a place to refill them. It is cheaper for me to buy a brand new printer than it is to buy the new cartridges when the ink runs out. Thats crazy.
Nov 27, 2007 | Canon PIXMA iP1800 InkJet Photo Printer
16 people viewed this question
jasbo
jasbo
