Question about Tec RadiantWave Grill
TEC grill I have a TEC Radiantwave grill; pilot light works, and everything is fine, but about 10 minutes into grilling, a loud pop sound happens and the burners go out,,,and you hear the propane blowing, the pilot light is on, and the bruners are out,,,has been occurring everytime i grill..Dennis
  • Dennis McKnight May 16, 2007
    when i spoke with a TEC rep., she said the problem is due to a cracked ceramic tile, causing the burners to go out. ???
  • Anonymous Jun 23, 2008
    My TEC Sterling just developed the same problem. Cannot find anyone who seems to know anything about it, and no one knows how to repair. This is a very expensive grill, hate to think that I am going to have to junk it and buy another grill. I have called TEC and do not get much from them in terms of repair.
I have the same problem...just spent $1,000 on new parts and install two months ago...problem is back...they say liquids from meats, sauces and marinades contribute to problem clogging up pores in ceramic...
i am trashing it and going for new model
Posted on Sep 01, 2008
    Problem Solver:
  • 6 Answers
I have a TEC Pattio II. I have owned the grill for almost 10 years and TEC grills have a ten year warranty on many of the parts including the burners. The burners on my grill have a ceramic inserts. The pop and loud whooshing noises indicate the ceramic insert or the seal on the burner is "cracked". I have replaced both of the inserts and burners on my grill once about 5 years ago under warranty. I have one burner now that will not stay burning and I contacted TEC today regarding the problem, and I will replace the ceramic insert only under warranty. .
The newest TEC grills like yours have the TEC Radiant Glass Infra-red Cooking System with stainless steel burners with glass surfaces. Confirm with TEC customer service that your grill has has this burner system and not the ceramic one. I assumed this burner system had eliminated the problem of the burners going out with a loud boom.
YOUR ONLY OPTION IS TO CONTACT THE CUSTOMER SERVICE GROUP AT TEC. THE TELEPHONE NUMBER IS 1-800-331-0097. TEC IS LOCATED IN COLUMBIA SC. TEC HAS A USEFUL WEBSITE. I WOULD NOT LET TEC OFF THE HOOK IF YOUR GRILL IS LESS THAN TEN YEARS OLD.
I noticed the skills of the customer service reps are lacking. You may need to talk with the manager. I love my grill and would not have any other brand or type. It is imperative to follow the cleaning instructions in you user manual.
Posted on Jun 24, 2008
I have an old Tec Searmaster II 1 burner. The burner (screen) got a long crack line and the burner shield got some holes. When I open the grill, I heard a pop noise and some fires are up. Should I change...
Some parts are still available for your discontinued model Tec Grill. The burner less the screen varies in price from $329.00 to $399.00. The Heat Plates start at $153.99. For more information go to
http://www.appliancefactoryparts.com/gasgrillparts/brands/tec/tec-burners.html
Hope this helps you.
Jul 03, 2011 | Tec RadiantWave Grill
I have a Char-Broil Tec grill everything works fine but after about 2 minutes into grilling, a loud popping sound and the tec-radiant burner goes out, this happens everytime I use the radiant burners
The radient burner most likely has a crack in the top. This will make the pop and the burner will go out. Inspect the top of the burner for any cracks, if you find one, the only solution is to replace the burner. Since these burners get very hot, I do not recommend having the grill lid closed when these burners are being used, this can cause them to overheat and crack the top surface.
Is it harmful to the TEC grill components to throw a match in after turning the left and right gas on ... to ignite it. The ignition and the pilot do not work.
No!
I light mine with a flexible extended lighter. The lighter gives you better control then just tossing a match in. If the ignition and pilot aren't working you probably have a bad flame sensor, or thermocouple, or more than likely you have a spider web or other blockage in the line for the pilot.
Feb 20, 2011 | Tec Sterling II Grill
Right side burner failure on TEC Patio II
the mesh could be split or blocked burner needs cleaning .
May 17, 2010 | Tec Patio II Grill
Minutes after lighting the grill I hear a loud pop and both infrared grills are blown out.
probably air and fuel mixure problem.. first clean all air passages and venturi's (primary oxygen source) of all spider webs and try again.
Jan 21, 2010 | Tec RadiantWave Grill
Screws have sheered off at the heads on the TEC burner. Do I need a new burner, or can I simply replace the screws with new, better ones?
Call TEC tell them your problem! they have a warranty on there grills for 8 or 10 years depends on which one you have!
Aug 01, 2009 | Tec RadiantWave Grill
Tec Grill Sterling Model won't stay lit
The dealer is right. The ceramic burner is cracked. It will need to be replaced -- pretty pricey. I have the same problem on my Sterling III. This DOES happen too often. My opinion is that this IS a manufacturing defect. I have called the company about it (they are in South Carolina) and they try to blame the user -- that would be us. Very unfortunate company chooses to act this way. You hear about this problem again and again and again -- it's their problem but sadly, they are making it ours. Remember that when you go grill shopping next time -- I know I won't buy a Sterling grill again. Ever.
Feb 15, 2009 | Tec Patio II Grill
Expensive TEC Grill Problem with Blowout After Ignition
HI nabber8391,
The newest TEC grills like yours have the TEC Radiant Glass Infra-red Cooking System with stainless steel burners with glass surfaces. I assumed this burner system had eliminated the problem of the burners going out with a loud boom.
By the way, I paid $1400 for my TEC grill in 1999, but I believe the new TEC grills are better. I know I would not buy any other brand. One other thought, it is imperative that cleaning instructions are followed.
Jun 23, 2008 | Tec RadiantWave Grill
Sputtering grill
The newest TEC grills like yours have the TEC Radiant Glass Infra-red Cooking System with stainless steel burners with glass surfaces. I assumed this burner system had eliminated the problem of the burners going out with a loud boom or sputtering.
May 01, 2008 | Tec RadiantWave Grill
Tec grill problem
If mositure gets into the ceramic burners, then yes it is time for new ones. Was your grill also converted over to accept the new gas? Or another thing it could be that spiders are clogging the burner orifice.. If you contact a local dealer on Tec gas grills or someone that can service gas grills. Might be able to help you.
Fireplacegirl
Apr 23, 2008 | Tec RadiantWave Grill
Open Questions:
TEC grill went BOOM and caught our house on fire. On Sunday, Sept 27, our TEC grill failed. We didn't know about the breaking screws. It had apparently flared up quite a few times, but we thought that it was just the meat catching when we opened the top up. On Sunday we were cooking a pork loin at about 33% gas levels across all burners. This should've taken about 30 minutes but we checked it after ten and found the loin was completely burnt on the outside and raw in the middle. We've been having bad luck with BBQ and couldn't figure out why. So we were going to put some steaks on but before that we looked and noticed the temp gauge on the lid was showing over 800 degrees!!! It was off the charts! My friend also noticed some flames leaking out the lid on the right side of the grill. He quickly turned all the knobs off and BOOM! Something blew and propane started venting freely from the tank. It shot a column of fire about 4 feet wide that engulfed the grill and rose to about 10 feet hitting the bottom of our back porch. It blew nearby floodlights and our porch started to burn. Extinguishers couldn't put it out. I screamed for him to call 911 and get the fire department. I told him to run inside in case the propane tank exploded. The flames were intense! I ran to a hose to try to put out the fire and was finally able to get it under control. What was left was a twisted, mangled grill and a LOT of fire damage to our home. I'm talking with an attorney today after she sees the damage. Luckily, no one was hurt or killed. Just a LOT of singed hair. I'm very angry that TEC isn't correcting this problem that's been plaguing homeowners for two years and the information that people have had did not bring some kind of recall at Lowe's. Needless to say, I can't repair the grill nor would I want to. I now need to rebuild one side of my back porch and re-run electrical and cable connections to melted flood lights. Yes, they actually melted in the heat. It appears to be the same issue I've read about in the 9 pages of this forum. Thank you so much for having this thread running. I hope that this helps others out there.
Sep 29, 2009 | Tec RadiantWave Grill
Tec RadiantWave Grill Logo
986 people viewed this question
Top Tec Grilling Experts
Paul Carew
Marvin
Marvin
Tom Chichester
Are you a Tec Grilling Expert? Answer questions, earn points and help others
