Question about Guardian Electrical Supplies
Generac guardian 13kw suddenly showed error code overrun / no RPM detected after an electrical. Contractor did some work on repairing some bedroom outlets
How to reset error code
CarlGehrke
  • 169 Answers
SOURCE: Generac Guardian 17.5KW Generator dies
If this is one of the big "taco cart" portables you need to check that the vent on the gas cap is open when you're running the engine. In the center of the gage on the gas cap is a little knurled knob, turn it counter clockwise (lefty loosey), about a half turn or so and run the generator.
If that doesn't solve your problem add to it here, otherwise please give me a rating I'm trying to build a little credibility here and could use the help.
Carl
Posted on Dec 02, 2008
  • 384 Answers
SOURCE: 10kw Generac Guardian not cranking, shows rpm sense loss
Sounds like Generator mode switch should be "ON".
Posted on Sep 08, 2009
  • 37 Answers
SOURCE: How can the battery charger be changed?
Yes this is a very simple job to do. there are only 2 small bolts holding it in. Make sure the generator is in the off position and removed the 2- 5amp fuses in the transfer switch for N1 and N2 Use a fuse puller designed for this (you can get at home depot or lowes for around $9-$10) not a pair of pliers or screwdriver, etc... there is 240VAC on these fuses.. N1 and N2 are what ultimately feed the transformer in the generator which steps the voltage down to 24-26 VAC and feeds the battery charger. Other than that its fairly simple, let me know if you have any more questions.
Posted on Dec 03, 2009
  • 905 Answers
SOURCE: Installed a generac 10k guardian standby generator
If you installed this 2 months ago, then you are still under warranty. You need to contact Generac directly before you try to fix yourself and void warranty. Not trying to offend, just being practical.
Posted on Jun 12, 2010
SOURCE: RPM/voltage fluctuation on Guardian Primepact 50G
The voltage regulator board on this unit is notorious for failing. If you are handy, you can replace it yourself with basic tools and a voltmeter to set the output. The part is about 200 dollars. Good luck
Posted on Sep 06, 2010
When I start my 15000 watt generac generator I have to excite the field to get voltage? It is a ultra source guardian when I first start it. The rpm is erratic until I get voltage.?
That may be normal. Some generators have to have the magnetic field excited in order to increase the magnetic lines of force for the armature to cut through.
Nov 02, 2017 | Generac Electrical Supplies
I need a rectifier or avr for generac 3500 xl genarator
Ebay and various places including the maker..
  • VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR-GENERATORS ... www.ebay.com/sch/sis.html?_nkw=VOLTAGE-REGULATOR-3000-3500-WATT... VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR ... New listing 3500 Watt Generator AVR Automatic ... 3500W Generator AVR Automatic Voltage Rectifier ...
  • 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator ... https://sites.google.com/site/kltthtyz0i04cd/3500-w-3500-watt... Generac Guardian 22kW Standby Generator NG ... Previously Pay for Shop 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator Rectifier 3.5KW Generator AVR ...
  • How to test your Electricity Generator's AVR, Brushes and ... www.youtube.com/watch?v=tC_LrrZcx38
    • BY GENERATOR GURU
    • 9 MIN
    • 454K VIEWS
    2011-10-21 · Video embedded · When your electricity Generator stops producing power, ... How to test your Electricity Generator's AVR, ... Generac iQ: The Quietest Generator ...
  • Generac Power Systems - Home www.generac.com Generac manufactures the widest range of power products in the marketplace including portable, RV, residential, commercial and industrial generators.
  • Generac Guardian Generator Voltage Regulator Rectifier ... www.ebay.com/sch/sis.html?_nkw=Generac+Guardian+Generator+Voltage... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator ...
  • Automatic Voltage Regulator (AVR) for Generators portable.generatorguide.net/avr.html How automatic voltage regulator (AVR) works in portable generators: ... here you can see a reverse engineered Generac regulator that uses SCRs and UJT.
  • Diagnosing A Generator That Has No Power Output. - YouTube Youtube
    • BY THEDIYGUYDOTNET
    • 3 MIN
    • 150K VIEWS
    2012-11-12 · Video embedded · Diagnosing A Generator That Has No Power Output. ... How to test your Electricity Generator's AVR, ... Generac Portable Generator ...
  • GENERATOR Diagram & Parts List for Model 3500xl Generac ... www.searspartsdirect.com > ... > 3500XL GENERAC Generator-Parts GENERATOR Diagram and Parts List for GENERAC Generator-Parts model # 3500XL ... Generator rectifier Part #: ... Generator voltage regulator Part #: ...
  • Jun 28, 2016 | Generac Electrical Supplies
    Generator hard to start and sputters like its missing
    About 15,000 results (0.73 seconds) Search Results
      2 - Generac : Questions, Answers, How To, FAQs, Tips ...
      answers.generac.com/answers/1506-en_us/searchquestions.htm?...
      Can I run an 8kw standby generator on a 100 lb propane tank? 2 answers ... What am I getting for the extra cost of the Guardian unit? ... The engine starts hard and runs rough. 1. Air ... On auto start, unit sputters and I smell gas. ... Does the gas and electrical feed into the unit from the back as previous air cooled units?
      2 - Generac Questions and Answers
      answers.generac.com/answers/1506.../generac.../questions.htm?...
      On auto start, unit sputters and I smell gas. .... The 20kW automatic standby generator has the option to delay start up during an ... This is for a guardian 20kw. ....has been designed to make the battery installation and removal so difficult? ... The air cooled generators are designed to allow for the smallest footprint while still ...
      3 - Generac Questions and Answers
      Generac's Guardian Series 17kw automatic standby generator does not come with a.... The automatic response features of our air-cooled units initiates the unit's startup,.... This week I tried the same and it tries to start but just sputters and fails until .... A C delayed start still chocks 17kw generator would a hard start kit help?
      On auto start, unit sputters and I smell gas. On manual start ...
    Feb 08, 2016 | Generac Guardian Air-Cooled Standby...
    Why does it crank and almost start on 1st try?
    Generac Generator Troubleshooting - YouTube
    ? 1:39
    https://www.youtube.com/watch?v=AKN2dc59cxY
    Dec 20, 2013 - Uploaded by Appliance Princess
    I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
    Generac Power Systems - ConsumerAffairs.com
    www.consumeraffairs.com > Homeowners > Utilities
    Rating: 1.3 - ‎26 votes
    Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
    Generac standby generator - Propane - wont start?? - DoItYourself ...
    www.doityourself.com/.../487838-generac-standby-generator-propane-w...
    Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
    141 GENERAC complaints and reviews @ P'ed Consumer
    Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
    I need to obtain an owner's manual for a guardian elite 25K gen.
    A good electrician should know exactly how to wire a ats system. If he/she doesn't just ask where a real electrical contractor is hanging out!
    Apr 02, 2009 | Generac Guardian 200 Amp Transfer Switch...
    Electrical Supplies Logo
    111 people viewed this question
    Top Guardian Electrical Supplies Experts
    Matt Olenzek
    Matt Olenzek
    richie46
    Are you a Guardian Electrical Supply Expert? Answer questions, earn points and help others
