Question about GE Microwave Ovens
GE JEBC200W not working
Microwave, convection oven and clock do not work. Has power because you can punch in numbers but start does not work and clock is blank and cannot be reset.
MicrowaveSvc
  • 9085 Answers
SOURCE: Some buttons work, some don't.
The keypad may be bad. Most often they go bad due to moisture from cleaners being sprayed directly on them or steam from the cooktop when the vent fan is not used.
They can also go bad when the unit is stored in an unheated environment where there's a lot of air temperature change (hot during the day, cold at night, etc.)
It may also be some residue on the connections where the keypad plugs into the control board. Unplugging then replugging the keypad can sometimes clean them.
In other cases, a new keypad is needed.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 18, 2007
MicrowaveSvc
  • 9085 Answers
SOURCE: GE microwave oven - just stopped stopped working
A microwave can be dead for many reasons.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave stops after about 2 seconds, also have to reset the clock each time
TO mdambros
You have a bad magnetron. We see this over and over.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
You'll save a lot by taking it in yourself.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
TO guest (Panasonic oven)
The door switch you suspected is bad, and it must be replaced. They normally cannot be cleaned or burnished and be reliable.
See http://www.microwavedisplay.com/doorsw.txt
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
prototech@usa.net
Posted on Jul 01, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: GE SPACEMAKER XL MICROWAVE OVEN JVM1440
Assuming that your internal cooling fan is working, I would suspect that your magnetron is failing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
I would check the cooling fan, then suspect the magnetron.
Posted on Nov 16, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: My GE Profile Microwave/Convection Oven stopped working.
Chances are that the thermostat / thermal cutout / T.C.O. (whichever it uses) has opened.
This can happen when the magnetron overheats, either due to it's failing, or if the internal cooling fan is not working.
It may also that be the 15- or 20A ceramic line fuse or the oven cavity thermostat / thermal cutout / T.C.O. (whichever it uses) has opened.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You should be able to get the fuse from a home center or local appliance parts store.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Jun 08, 2009
The convection part of my GE Microwave/Convection Oven doesn't work. The Microwave part still works fine.
To help you with free DIY or other info, we would need your full model number as shown on the tag in the cooking cavity or elsewhere on the oven.
The FCC ID number from the same tag might be helpful for diagnosis, too.
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 10, 2017 | GE Microwave Ovens
GE JVM1790WK convection microwave
I assume you've referred to your owner's manual to be sure you are operating the convection properly?
If for some reason you don't still have your owner's manual, you can get it here. See the tips on page page 30.
You can also do a hard reset by unplugging the oven for a couple of minutes, plugging it back in, then setting the clock and trying again.
If it's still not working, you may have a bad sensor or other problem.
Sep 04, 2012 | GE JE1590 Convection / Microwave Oven
Lost power and when power came back on the clock would not reset.
Try disconnecting power for 5min.then plug back in,The microprossor may have locked up this happens a lot with uprocessor controlled equipment.
Jan 27, 2011 | GE Advantium 120 Convection/Microwave Oven
My microwave/convection oven (a GE unit model JES1290SK) started beeping every few seconds and displaying F6 on the control panel. I unplugged it and waited several minutes and when plugged in it displays...
The technical sheets in my files do not list F6 on the error code chart for GE microwaves.
Generally, these are the error codes possible on GE microwaves:
F1 open thermal sensor (convection models)
F2 shorted thermal sensor (convection models)
F3 key panel shorted for more than 60 seconds
F4 open humidity sensor
F5 shorted humidity sensor
There should be a "mini-manual" (technical sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 15, 2011 | GE JES1290 Convection/Microwave Oven
Microwave part of my GE Sensor Convection Microwave doesn't work
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Dec 22, 2008 | GE Advantium 120 Convection/Microwave Oven
My GE Profile Convection Microwave Oven - Convection not working
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
uijjf
Dec 02, 2008 | GE JVM1790SK Convection/Microwave Oven
Convection oven problem
Most of the time the magnetron is defective if the food is not heating up.
In some cases there is a defective low power transformer or other componenents associated with the magnetron.
I would suggest to check the owners manual under the warranty section. Sometimes the magnetron has 5 years warranty.
Good Luck.
Feb 15, 2008 | GE JVM1490 Convection/Microwave Oven
Microwave Ovens Logo
42 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
