Pioneer SD-P5057 Rear Projection Television
My Television has worked great for its entire life so far, now to day I moved out away from the wall to dust and clean the mirror and now it either works fine or it will shut off after 20 minutes or so. The only way I can get it to even power up is to unplug it and plug it back how ever sometime it will only power up for 1 or 2 seconds then shut off or it may stay on for 20 minutes or so.
5 Suggested Answers
  • 150 Answers
SOURCE: Location of MIrrors in projection tv
wd-52525 This is a DLP, I dont suggest taking it apart to clean anything, this is what we call a MICRO display, the imaging device is about 1" square and blown up 50X to the size of the pix you watch, anytime anyone I know has taken stuff appart where the mirror is at has ended up worse off, you say that there is dust on the mirror, what does it look like in your picture? If the spots are quarter size or so and fuzzy edges the dust is inside the lightengine and you want a factory cleanroom to service the LE, the one thing I think you can safely do is pull the lamp and check for dust on it as it can cause issues in pix, other than that I dunno what to tell you, hope this info helps.
Posted on Jul 09, 2007
  • 1153 Answers
SOURCE: Pioneer Elite PRO 710HD 64" rear projection tv
You could get the old one and have them match it up. If not try www.pioneerservice.com
Posted on Sep 17, 2007
  • 1694 Answers
SOURCE: replacing rear projection glass on Pioneer Pro-620HD
1)Pioneer entry is through the front,as you already found out.
The service manual will show you.......
2)Remove lower front speaker grill
3)Remove screen frame only
4)Choose left or right side to remove rail to access screens
5)CAREFULLY slide screens out to expose interior
6)Replace mirror and wipe off RGB lens caps
7)Reassemble .......................go slow,.............T.
Posted on Jan 25, 2008
  • 3 Answers
SOURCE: Pioneer elite Projection TV PRO-98
Need to replace the convergence board. Cost through Pioneer is $350.
Posted on Feb 07, 2009
I HAVE A SD-532HD5 RED LIGHT STAY ON....IT USE TO TURN OFF BY ITSELF ONE DAY IT WENT OFF AND NEVER CAME BACK ON ......THERE IS A RED LIGHT ON THE POWER BOARD
This model and others close to it have all sorts of soldering problems on the power board----fixed a lot of them by removal of power board and aside from fuses solder the ENTIRE board--every connection---bad connections develop with age and heat.
Oct 14, 2012 | Pioneer SD-532HD5 53" Rear Projection...
My pioneer sd-533hd5 is 8-9 years old. how do i clean the lanses?
You should be able to access it from the back panel. After you remove the panel, the lenses should be mounted on a platform. If you are careful, you can manuever yourself in far enough to clean the inside of the display screen. Good luck!
Nov 02, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
How to remove front screen
The screen comes off from the front. First take off the speaker grill and you can access the frame screws they are right below the screen. This only takes off the frame with the filter. After the screws are out swing the bottom out a bit and lift straight up on the frame then pull it out away from the set. I have found these to be very stubborn somtimes, but you should be able to get the frame to move then work it up and off. I hope this helps you. let me know if you have any more quesitons.
Apr 28, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-p5073-K Shuts off
it is the power supply board an know problem with pioneer. If you have any soldering experience you can remove the powersupply board and resolder the tracks and as many parts as you can. I had the same problem and not the power supply works great. You will soon have other problems like pic and sound going intermittant where you have to hit the tv to get it back on. more solder problems on video main board. best of luck
Aug 22, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer 58" SD-582HD5 1080i -Rear Proj TV
Like most problems with this model, check and re-solder the connections on the power supply board on the right rear of the tv, just behind where the main power cord goes in. Most problems are around the upper left corner where the white connectors E-12 and others. Check all of them from loose and cold solder solder connections on the board. Hope this helps.
Jun 02, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer SD-P4683
You may need the power supply board resoldered as I had the same problem. The guy listed below can do it for you as I shipped mine from Illinois to him in California... Piece of cake getting the board out of the back and it's not too fraigile... Just pack in bubble wrap and it will be fine. My TV is now working great.
BUT DON'T DELAY AS SOONER LATER TV WILL NOT RESTART..
http://www.avsforum.com/avs-vb/showthread.php?t=402397&pp=30&page=38
Good luck.
cell
Oct 15, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Picture on my rear projection TV
Your set will one day soon not come on at all. theres several capacitors on the PIP board if your set has PIP or the capacitors in the power supply. A good tech should know where to check as this set some say is hard to work on but i quess its like anything you work on for a bit gets easyer. Call an authorized repair center for pioneer. Good Luck
Aug 13, 2006 | Pioneer SD-P50A5-K 50" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
