User manual of PN51T router wi-fi - Computers & Internet
5 Suggested Answers
smeago1
  • 136 Answers
SOURCE: laptops do not recieve IP address from the router
Carlos
I think the problem lies within the dhcp of your router. Make sure dhcp is on and change the lease time to 1440 minutes or higher that way once you have the ip address it will stay with your laptop longer. alternatively allocate the ip address on your laptop manually.
good luck
smeags
Posted on Jan 03, 2008
anandg27
  • 1272 Answers
SOURCE: connecting my ipod touch to my wireless router through wi fi
Check for the password on the router configuration page to make sure tat you are using the correct one:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router (User Name = admin Password = password unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the Key that has a black dot before it.
This is the code required for connecting the wireless computer to the routers' wireless network.
Enter the same password on IPOD to connect to the wireless network.
Rate it,if it helps.
Posted on Jun 26, 2009
ragufiles
  • 108 Answers
SOURCE: unstable wi-fi connection to D-link DIR-825
check the connectivity again by assigning static IP Address to your DELL.. if problem occurs, clean install the drivers and dell Wifi software to your laptop.. Virus problem also results in this type of problem..
Posted on Jun 17, 2010
Re5cue911
  • 94 Answers
SOURCE: setting up secure wi-fi
You need to log into the wireless router either by a computer that successfully connects wirelessly or by physically connecting with an ethernet cable. Once connected, log into the router by open a web browser (Internet Explorer, Mozilla Firefox, Google Chrome, Apple Safari), and typing the router's address (usually 192.168.1.1 or 192.168.0.1) into the Address (or URL) line. The default usernameand password is usually "admin" & "admin" or "admin" & "password". Once successfully logged in, look for a tab or link that says "Wireless" or "Security". You'll be able to change whether security is enabled or disabled, and the password associated with it. Your security options are WEP or WPA (or WPA-PSK). WPA-PSK is the most secure, but WEP is also an acceptable choice. Select the security option of your choice and either enter text into the passphrase generator or choose your own password and type it into one of the security key text fields. If you use a password that is not a plain english combination of letters and numbers, be sure to write it down so that you can enter it as needed on other wireless devices that need to access your router (ie-pda phones, game consoles, laptops, desktops, etc). Be sure to save changes so that the security settings and password is saved.
Let me know how you make out.
Posted on Sep 06, 2010
Thermostat recognizes wifi but remains off-line
f your thermostat either displays a no Wi-Fi icon on its screen or shows up as offline on the Lyric or Total Connect Comfort app, it is missing the connection to the Wi-Fi network.
A few preliminary things to check:
  1. Does your thermostat have power? If not, check to make sure your C wire (common wire) is connected to your Honeywell thermostat. All Wi-Fi and connected thermostats (except the Lyric Round model, which can operate using Phantom Power/Power Stealing) requires a C wire to power your thermostat. Regardless of model, if you use Apple HomeKit with the thermostat, a C wire is required. If you are not sure that you have a C wire, please reference our Thermostat Wiring Compatibility page for more information.
  2. Honeywell Wi-Fi thermostats are only compatible on the 2.4 GHz frequency. Newer routers can operate on multiple bands, usually 2.4 GHz and 5.0 GHz. Please check that your router is emitting on the 2.4 GHz frequency.
  3. Check the distance between the thermostat and the router to ensure that the thermostat is in range of a Wi-Fi signal. A simple way to check this is by looking at the Wi-Fi signal range on a mobile device when standing near your thermostat, but note that most mobile devices usually pick up 2.4 GHz & 5.0 GHz Wi-Fi signals. In extreme cases a Wi-Fi range extender or repeater may be needed to ensure you have sufficient 2.4 GHz Wi-Fi coverage throughout your house or business.
  4. Check that your router's firewall doesn't block the thermostat.
In addition, please follow the next steps:
  1. Make sure your Wi-Fi router is powered and broadcasting. Restart your router by pressing the OFF/ON button or by unplugging the device from the socket for approximately 5 seconds and plugging it back in.
  2. If the problem persists, please reset your thermostat. Reference your user manual for instructions on how to reset your thermostat. The manual or quick start guide will have come inside your thermostat's packaging.
Feb 20, 2018 | Computers & Internet
NetGear router WGR614 v9. No manual, don't know user name and password so can't login to your site. Need an encryption key for this router. Cannot get a wireless connection to internet otherwise.
plug computer into ethernet port of router
Via blue ethernet cat5 patch cable
try user name admin
and password as password
try 192.168.1.1 ( later version of router ) or 192.168.0.1 for router ip address in an internet browser.
then look at the wi fi settings for wi fi security encrption key or add one if not set .
https://www.lifewire.com/netgear-wgr614-default-password-2624841
Oct 16, 2017 | NetGear Computers & Internet
Where do I find the IP adress so I may connect manually.
https://wwwimg.roku.com/static/oldlib/roku_player_documents/rokuplayerug.pdf
page 23 change network settings
then page 14 on wi fi settings
if new service provider gave you the encyrption key and has dhcp on then this should start Roku working on Wi FI.
New service provider would have installed a wi fi router this is most likely on 192.168.0.1 or 10.0.0.1 go to cmd prompt type in
ipconfig
then press enter key
Not the default ip address
the router should have a wi fi security option that tells you if the wi fi is encrypted and what ssid is being broadcasted.
DCHP should be enabled Roku will use this to assign itself an ip address once connected to Wi FI.
you need to know routers admin user name and password as well
Apr 18, 2016 | Roku 1
I need to knowhow to put wifi password to my iptimen704m
go to browser and type in 192.168.0.1 while computer is plugged into the router directly via blue cat 5 ethernet cable. Not sure if router has an access password. Or alternatively you may be able to use the WI Fi wizard in the software that you installed on your pc although the manual does not show any information about using the Wi Fi Wizard. Once in the router go to Wi Fi and Security and set it up to do WPA encryption and set up a password.for the encyrption.
The appendix 3 of your user manual has a extremely brief mention of using web browser and it is really brief !
Jan 23, 2015 | Computers & Internet
How to put wifi in that phone??
Thanks for visiting FixYa!
The Mototola Droid Cell Phone has WLAN from the factory. That is, it has Wi-Fi 802.11b,g. So, you don't need to install it. Wi-Fi is already in the phone.
Here is a link to your owner's manual in case you don't have one handy. http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/DROID-by-Motorola/US-EN/Documents/Static-Files/DROID_UG_Verizon_68000202474a.pdf
To connect to Wi-Fi see page 4 of your user guide for instructions.
Wi-Fi connect
To connect to an available Wi-Fi router, touch Menu Key (bottom of the phone and just left of the center of the phone) > Settings > Wireless & networks > Wi-Fi settings. (And turn Wi-Fi on.)
Feb 19, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
I purchased a new IPOD and I can not access the wifi from my Linksys wireless router.. I reset my Linksys router to try to solve this problem. And at first when the light was amber I was able to have...
Resolution If you know there is a nearby Wi-Fi network, but you are unable to locate it on the Settings > Wi-Fi screen:
  • Move closer to the Wi-Fi router or hotspot.
  • If you are using a personal Wi-Fi network, verify the Wi-Fi router is connected to power and turned on.
  • Wi-Fi networks configured as "closed" or "private" do not broadcast the network name to Wi-Fi devices.
    • Join a "closed" or "private" network by tapping Settings > Wi-Fi > Other and entering the Wi-Fi network name, security, and password.
After joining a Wi-Fi network, if you notice the signal strength is low or intermittent
  • Check for any sources of potential interference.
  • Remove any cases or attachments on your device that could interfere with a Wi-Fi signal.
If you are unable to access the Internet while connected
  • If you are using a commercial Wi-Fi network that requires a special login or subscription, see this article for more information.
  • If you are in a location with multiple Wi-Fi networks, verify that you are selecting the correct network.
  • Verify that the Wi-Fi network settings are correct:
    • Tap Settings > Wi-Fi.
  • You can configure network-specific settings, including IP address, DNS, and Search Domain settings.
  • Use "Forget this Network" to reset settings for this particular Wi-Fi network, including the password. This is also useful if you identify a network issue and want to prevent the device from automatically using this network in the future.
  • Use "Renew Lease" to acquire new IP address, DNS, and Search Domain information from the Wi-Fi network.
  • Note: If the Wi-Fi network uses MAC address filtering, you will need to add the MAC address to the access list for the Wi-Fi router. The MAC address for your device is listed as the Wi-Fi Address in Settings > General > About.
If you are still unable to join a Wi-Fi network, or are unable to access the Internet while connected, try the following
  • Restart the device
    • Hold the power button until "slide to power off" appears. Slide to power off your device. When it is off, press the power button to turn it back on.
  • Reset network settings by selecting Settings > General > Reset > Reset Network Settings. Note: This will reset all network settings, including passwords, VPN, and APN settings.
  • iPhone only: If you continue to experience issues, consider turning off Wi-Fi and using the cellular data connection instead of Wi-Fi.
Additional Information If using a Wi-Fi router at home, refer to your user manual/documentation to assist you with some of these suggestions.
  • Check the manufacturer's website for your Wi-Fi router for firmware or software updates.
  • Verify the Wi-Fi router can broadcast an 802.11b/g signal. If using a 802.11n Wi-Fi router, consult the manual/documentation for how to configure the Wi-Fi router for 802.11b/g compatibility.
  • If you are using multiple WEP keys on your Wi-Fi router, try configuring your Wi-Fi router to use only a single WEP key.
  • Try or resetting (or turning off and then on again) your Wi-Fi router. Note: If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
  • Disable wireless encryption or security on the Wi-Fi router to rule out encryption issues. If this resolves the issue, try using a different encryption or security protocol.
Mar 22, 2010 | Linksys Wireless-G WRT54G Router
I have wireless - router with built in dsl modem DGN2000. Working fine with my desktop but I have just purchased a laptop and have not been able to connect signal to it.
1. Dear! Check your notebook wireless settings and correct it if it is necessory.
2. Chekc your wireless router settings may it need to update for your notebook.
Good Luck
Sep 28, 2009 | Computers & Internet
WIRLESS NOT WORKING
First turn on your wi fi switch on laptop.
Then go to my netowkr places proeprty and make sure your wi fi network adapter driver is installed and enabled.
Then click on view available wi fi networks then check you get signal form wi fi router.Then it works.
Let me know if you need more assistanse.
Aslo you can check in router that wireles is enabled in router?
For that connect your wi fi router to computer with ethernet cable then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
typoe user as "admin' and password as "admin" or blank or "password"
then check in wireless settings that it is enabled.
Thanks.
Sep 24, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
How can i ins tall my rangemax dual band wireless-n router wndr3300 to my laptop to setup wifi in my house
Connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1 or
http://1921.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then configure your router as WEP.
Then go to wireless and check that wi fi is enabled.
Then go to wi fi security and add WEP key it is your password to connect your wi fi.
Also enable dhcp if you want get ip auto to computers.
configure your wan settings as your internet service provider like dns ip addrses.
Then save settings and restart the router.
Now go on your laptop first turn the wi fi switch on your laptop .
Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
Then double click on wi fi icon and click on "View wi fi networks."
then connect then enter password which you set in router wep key.
Thanks.
Aug 31, 2009 | Computers & Internet
Password
The user manual of your router has instructions on how to do it.
Here is also a good video on the subject, made by GetConnected.
How To - Secure Wireless Router Set Up
Aug 27, 2009 | Zhone (6218-I2-200) Router
Computers & Internet Logo
690 people viewed this question
David Payne
David Payne
