This idea may be worth a try. Look at the buttons on your remote. If you see a button that is marked "TV" give that button a push and then give the "Power" button a push. Wait for a while! sometimes this takes a while to turn the TV on or off. You may have to do this a couple of times depending if the power was off or on when you started doing this. If you started with the set off, sometimes it takes a while for the set to turn on.
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced. If you need any information or other assistance let me know. Thanks, Lee
I am having this exact problem. The TV turned off by itself and now when I try to turn it on, the power light stays on for a sec and goes of with a click sound.
i have seen this before and it may be the front power button being stuck and when your remote turns it on the stuck button turns it back off again. I have an older mitsubishi that will not boot up right sometimes and i have to unplug it and plug it back in fot it to come on. I used to pick up broken tv and fix the power buton and resell them
HLP, HCN HL-S The Start-up Problem or/and 3 LEDs in the front blinking. Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in. Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
