Question about Logitech Z-2300 Computer Speakers
Hot to replace 3.5 mm jack
The system has a wired remote which allows one to adjust the volume. My problem comes from a wire that comes out of the remote. The wire goes from the remote to the to a female splitter. The male end or the 3.5 mm jack whichever you wish to say has shorted out after years of usage. I need a replace and/or some advice on how to replace the jack. Thanks.
5 Suggested Answers
Open SKy
  • 620 Answers
SOURCE: X-230 Xbox 360/Computer Problem.
Frist Things first!
1) CHange the input cables for Spks, for another with cooper or gold conductivity.
2) clean ends for dust on inputs.
3) try to reconnect the speakers carefully and test sound.
you can figure out when some sound are bad in any connection on this way.
Good Luck
Posted on Feb 25, 2008
  • 38 Answers
SOURCE: Using Without WIRED REMOTE
All I could suggest is run the decoder off the line-out of your soundcard, then regardless of what the volume or power setting is to your speakers, the signal will still come through?
Tony
Posted on Mar 04, 2008
Benimur
  • 6966 Answers
SOURCE: logitech speakers :(
Hi and welcome to FixYa,
Initially, I feel uncomfortable cutting the 3 plugs, splicing them together and soldering to just one plug. What I have in mind is to use 3 barrel jacks (use stereo, the image is for a mono), splice them together and connect a single 3.5 mm plug, homemade splitter.
Pls post back result(s). Good luck and Thank you for using FixYa.
Posted on Jan 17, 2009
SOURCE: I need a circuit diagram for My Logitech Z-640 Computer Speakers
i have 2.1 channel speaker set it was not working what is the solution
Posted on Mar 08, 2011
Where can I find a replacement 4-wire jack that plugs into the score-keeper of my Halex 50616 air hockey table?
What you are seeking is a 3.5 mm plug to fit the connector on your Halex table. Some video cameras and DVD players use such a plug.
Nov 23, 2013 | Halex Air Hockey Table
93 accord timing belt installation
  • Car jack
  • Jack stands
  • Torque wrench
  • Chain wrench
  • 3/8 inch drive ratchet
  • 1/2 inch drive ratchet
  • 10 mm wrench
  • 12 mm wrench
  • 10 mm socket (3/8 inch)
  • 14 mm socket (3/8 inch)
  • 17 mm socket (1/2 inch)
  • 19 mm socket (1/2 inch)
  • Timing belt
  • Balancer belt
  • Bottle of Liquid Paper
  • Disconnect the negative battery terminal. Using a ½-inch-drive ratchet and the 19 mm socket, turn the center bolt on the crankshaft so that number-one cylinder piston is at top dead center (TDC). You will know you ware at TDC when the mark on the crank is in alignment with the arrow on the timing cover.
  • Disconnect the cruise control connector and remove the cruise control actuator. Loosen the upper mounting bolt with the 14 mm socket. Use a 12 mm socket to loosen the lower nut then use a 10 mm socket to loosen the adjuster from the power steering pump and remove the belt.
  • Loosen the upper air conditioner mounting bolt using the 14 mm socket. Use the 12 mm socket to loosen the lower nut and adjusting bolt on the alternator and remove the alternator/AC belt. Remove the valve cover using a 10 mm socket.
  • Place the jack behind the left front wheel where the arrow is located indicating the jack location, and raise the vehicle. Put the jack stand under the subframe behind the jack, then lower the jack. Remove the left front wheel for easy access to the crank pulley. Using a block of wood atop the jack, place the jack under the oil pan and lift with slight pressure to hold the engine in place. Remove the side engine mount using a 17 mm deep socket.
  • Take off the dipstick, pipe tube and upper timing cover using a 10 mm socket.
    Then remove the timing belt adjuster rubber seal without loosening the adjuster nut. Take off the crankshaft pulley bolt. Use the chain wrench to hold the the crankshaft pulley while turning the crankshaft pulley bolt with a 19 mm socket. Use the 10 mm wrench and 10 mm socket to remove the bolts on the lower cover. Remove the lower cover and mark the location of the cam, crank and balancer shaft with Liquid Paper. Remove the balancer shaft belt and timing belt. Install the timing belt and the balancer shaft belt in the reverse order of removing them. During Installation of the crank pulley, coat the threads of the crank pulley bolt with engine oil and tighten it to 159 foot-pounds. Finally, adjust the tension of the power steering and alternator belts as well.
    Feb 03, 2011 | 1993 Honda Accord
    Black cables loose
    Does the jack have any wires connected to it? Can you tell where the disconnected wires originate? Typically, the wire from the middle ear of the volume pot should go to the tip of the jack, and the wire from the back of the tone pot goes to the sleeve of the output jack. You will get no output if either of these wires are disconnected. Also, the next question is "why" did they come loose? That's usually because one of the pots is not tightened down, and is allowed to spin when the volume or tone knob is turned, breaking the wire's contact. Pull the knob off the pot, and tighten the nut down so the pot can't turn. This will assure you won't have the same problem again.
    May 26, 2010 | Dean Vendetta XM Electric Guitar
    Replacement instructions for a starter on a
    1. Raise the front of the car and support on jack stands.
    2. Remove negative battery cable.
    3. Crawl under the car and locate the starter.
    4. Remove 13 mm nut securing power cable to the starter and pull cable to the side.
    5. Remove 10 mm nut securing the ignition wire to the solenoid and pull wire to the side.
    6. Using a ratchet with a 13 mm socket and 6" extension, remove the 2 bolts securing the starter to the transmission.
    7. Remove starter.
    Installation is reverse of removal.
    Oct 01, 2009 | 1993 Saturn SL1
    I have a Boss OL5KD Class D Monoblock Amplifier and I set it up but is no sound coming up from the speakers, can anyone tell me how to higher the volumen? where is located the volumen??I need to higher the...
    Hello maydude01,
    The Boss OL5KD does not have a volume control. It has an "Input Level" adjustment which is used to match the output from your head unit preamp output to the amp. It is the first rotary control just to the right of the input jacks.
    If you have no sound at all, I'd suspect that something is incorrectly connected or there is no input to the amp. First make sure that the amp power light (green LED) is coming on when you turn on the receiver and that the protection light (red LED) stays off. Then check all of your wiring, especially the RCA output cables.
    Initially set the controls like this: MASTER/SLAVE switch in MASTER position (left). INPUT SENSITIVITY 2v-8v (right). INPUT LEVEL, SUBSONIC FILTER, BASS BOOST, and LOW PASS FILTER; midrange. PHASE SHIFT "0" (left). Leave the remote level control disconnected.
    After you've checked all wiring and initially set the switches and controls, turn the receiver on to about 3/4 volume. Now adjust the INPUT LEVEL to the left just until you begin to hear distortion, then turn it back right just a little. Adjust the other controls for best sound. Plug in the remote level control and make sure that it adjusts the bass up and down. You're finished!
    If there's still no output from the unit after checking all of the wiring, either the unit is defective, it's not getting an input from the receiver, or the sub(s) are defective.
    Hope this helps.
    Aug 14, 2009 | Boss Car Audio & Video
    2005 toyota highlander - temp control knob not working to adjust temp hot or cold - by tapping on the wheel/knob it will adjust at times. wiring concern? knob concern? dealer wants $800 for new control...
    Just repair a panel for one of these, They use a 3-wire ribon 1/8 space between wire. The one I fix had the two outer wire broke loose at the heat/cool switch it had become loose from the panel which gave it enought wiggle room which allowed the wires to break I fixed buy replace all three wire from the main panel to heat/cool switch. With all 3 wire be seperate. They should not break ago.
    Jul 08, 2009 | Heating & Cooling
    Speaker wiring
    the audio out cable (green ended wire sometimes) goes into the audio out socket of your pc. (both are green some in cases with older computers then it will be the middle on of the 3 sockets) if you have more than 3 audio sockets then they will indefinetly be colour coded. if you have a sub and/or remote, plug the left speaker jack into the white socket and the right speaker jack into the red socket of either the remote or sometimes the sub. then just plug it into the wall and adjust the volume control via the start menu and the remote if you have one.
    hope this helps
    kev
    Dec 01, 2008 | Compaq MV 540 15" CRT Monitor
    Creative Inspire 5.1 5200 Remote Wiring
    Hi glopher
    pin 1 (starting from far left when LED is facing up) = green
    pin 2 = light blue/lime blue
    pin 3 = black
    pin 4 = yellow
    pin 5 = pink
    pin 6 = red
    pin 7 = violet
    pin 8 (far right) = blue
    I hope this helps
    Open345
    May 18, 2008 | Audio Players & Recorders
    Deck
    connect all of the speaker wires and remote antenna and amp turn on leads first. connect the antenna coax and ground wire. then apply the memory and hot wires. if you experience ignition noise at low volumes cut the ground wire and let the headunit ground through the antenna jack (providing you don't have a floating ground system (i.e., if all speaker grounds are tied together)).
    Jan 01, 2008 | Car Audio & Video
    Volume
    I had this problem and checked the main wire going from console to bass unit, it was loose from where I had moved the unit to insert another device (RCA Jacks). Apparently if the wire from the unit is loose, it over - rides the volume and by default adjusts it to 30. Additionally, I reset the system console and bass unit console, during this process. Try this, it might fix your problem.
    Dec 03, 2007 | Bose Lifestyle 28 System
    Logitech Z-2300 Computer Speakers Logo
    63 people viewed this question
    Top Logitech Audio Players & Recorders Experts
    Michial Gueffroy
    William Covington
    Level 1 Expert
    Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
