Question about VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA)
Why is the verifone vx570 not printing ink
No ink beign printed onto reciept
5 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: Problem with the VeriFone VX570 Credit Card
You can get the Installation Guide HERE.
You need To Install/Replace MSAMs where all previous information is stored:
1 Remove the power cord and/or battery (see Smart Battery) from the terminal.
2 Place the terminal upside down on a soft, clean surface to protect the lens
from scratches
3 Remove the MSAM compartment door screw and rotate the door up and back
to access the MSAM cardholders (see Figure 11).
4 Remove any previously installed MSAM card by sliding the card from the
MSAM cardholder.
5 Install an MSAM card by aligning the card and carefully sliding it within the
guides on the cover until it is fully inserted (see Figure 12).
Contact: VeriFone Systems, Inc.
2099 Gateway Place, Suite 600
San Jose, CA 95110
USA
Tel: 1-800-VeriFone (837-4366)
Main Tel: (408) 232-7800
Main Fax: (408) 232-7811
Posted on Jan 18, 2011
  • 42 Answers
SOURCE: TAMPER DEFAULT CERTIFICATE ON VERIFONE
Hi,you need to remove TAMPER through TAMPER recovery tool.
psoftware109@gmail.com
Posted on Mar 12, 2011
  • 42 Answers
SOURCE: I need to unlock a
Hi,yopu need to password reset tool then you can clear then memory of your device.
Posted on Mar 23, 2011
Matrix12
  • 370 Answers
SOURCE: Verifone VX570 TAMPER DISPLAY
Welcome to FixYa!
It seems that you are having problem with the display of the Verifone. Please try to follow these steps for you to be able to fix the problem.
When the Vx5xx/Vx6xx terminal display screen does not show correct or clearly readable information:
• Check terminal power connection.
• Remove and reapply power to the terminal.
• Check all cable connections and verify that the telephone line is properly connected.
• If the problem persists, contact your local VeriFone service provider.
Hope this information will help.
Your response is very much appreciated. Thank you for using FixYa!
Posted on Jun 24, 2011
Ink is light, how do you replace the ink
the terminal you have does not use ink, it is a thermal printer, it literally burns an image onto paper. you should check the paper to make sure you are loading it correctly, scratch the paper if you see a line where you scratched that goes down in the paper loader. make sure paper is thermal
Jun 05, 2014 | VeriFone VX570 Credit Card Terminal (Dual...
Verifone vx570 ink cartridge
there is no ink in this terminal it is thermal so it burns the image on the paper. make sure you buy thermal credit card paper. scratch the paper if a faint black line appears it is thermal this should be the side of the paper that is load to the bottom of the tray
Apr 08, 2014 | VeriFone VX570 Credit Card Terminal (Dual...
Need to clean print heads on verifone vx570
To clean print head, just use denatured alcohol on a cotton pad. lift the paper cover and clean all you can see, dry and test print. If this problem continues call Frank @ 775-338-6634
Oct 25, 2013 | VeriFone VX570 Credit Card Terminal (Dual...
How do I reset a Verifone vx570
You need to reset your Vx570 through Reset Software.
Apr 26, 2012 | VeriFone VX570 Credit Card Terminal (Dual...
MY Vx570 only prints on the left side of paper.
I think your Paper Feed Roller is bad. . If still needs help, casll (775)358-2922 ask for Randy. Thank You
Apr 17, 2012 | VeriFone VX570 Credit Card Terminal (Dual...
Verifone Vx570 given an error Modem Profile Not Set?
error modem profile not set appears when your Verifone VX 570 modem profile is not properly loaded or has been errased due to Tamper error or Bad RTC. Reloading back the modem profile will sometimes fix the error, but there is also a chance that your I/O module (form where you connect the power and telephone wire) is also bad, thats needs to be repaired or replaced. Call (775)358-2922 ask for Randy. Thanks.
Backside of the I/O module of VX 570
Jan 18, 2012 | VeriFone VX570 Credit Card Terminal (Dual...
I don't know how to load a new roll of paper! I'm a temp. Help!!!
Ensure thermal paper is being fed from underneath the roll, as it will only print on one side of the paper.
Jul 08, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
How do I change the ink in the verifone vx570 model
You don't. They have thermal printers. The whole printer needs to be replaced.
Apr 11, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
How can I get the detail report print out with the settlement report when the batch closes?
Hi,after close the batch then all information flashed in your pos device so your are unable to reprint it.
Feb 28, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA) Logo
43 people viewed this question
Top VeriFone Computers & Internet Experts
lolthepcman
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
