Question about HP Photosmart C6280 Printer
HP C6280 shows Insert memory card?
Just trying to print, as usual. Shows need to change cartridge. Did that and now keeps telling me to "insert memory card." I don't have a memory card and have never had one in order to print
sagarjd
  • 95 Answers
SOURCE: hp photosmart C5250 all in one
Thank you for the information
Please check if you have inserted any Memory Card into the All-in-One.
Please perform the following steps:
1) Connect the printer directly to the wall outlet and
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
Please perform the following steps to reset the printer to factory settings.
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord
Regards,
Sagarjd
Posted on Jul 27, 2008
rakeshpramod
  • 234 Answers
SOURCE: Printer keeps saying insert memory card
The message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product. For more information please check the link bellow: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01436439&cc=us&lc=en&dlc=en&product=3194498 Good Luck
Posted on Sep 28, 2008
  • 298 Answers
SOURCE: HP C6280 says out of black ink
Something is wrong with your Blach carrier or connections. Use a bit of alcohol and clean the array of gold contacts where the Ink cartridge plugs in. Most of the pins are shutter and piezo control (get the ink on paper) but a few do other stuff like check ink level, # of hours runtime, etc. This is very common problem with inkjet printers. Hope this helps.
Also... rub the contacts on the printhead with a pencil eraser to make them shiny and bright.
Cheers!
Posted on Mar 26, 2009
komguy
  • 2306 Answers
SOURCE: Align Cartridge Always Shows Up
The message won't go away until it completes the alignment. If any colors are not printing it won't pass the alignment. you can bypass the message but it will keep coming up until the alignment is satisfactory.
Posted on Aug 07, 2009
SOURCE: my scaner is not working . Error Scan.Msi file missing
I have reinstalled software for my HP Officejet 7310 printer and in the final stages I get a 1706 error indicating I am missing a file called "scan.msi". Any suggestions?
Posted on Oct 26, 2010
My printer says insert memory card
Welcome to FixYa...
I assume the message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product.
  1. Locate the memory card slot on the front of the product that is compatible with the memory card to be printed from. Each type of memory card slot accepts only one type of memory card, and only one memory card can be inserted at a time.
  2. Insert the memory card into the appropriate memory card slot.
Some times you may be trying to print Some Data may be from Memory card , you Choose already-But actually your MMC not in/Not Properly in...Hope you find it.....Thanks for Contacting FixYa...
Jul 03, 2010 | HP Photosmart C6280 Printer
What is insert card
This printer can print photos that are stored on a flash memory card.
Insert card means to insert the flash memory card into the printer so you can select the photos you want to print.
Apr 01, 2010 | HP Photosmart C6280 Printer
Hp c6280 error code 0xc055d0381.. need defenintion of error
This error codes indicate that the product has an internal error condition. We need to reset the printer to fix it.
  1. Without turning OFF the printer disconnect the USB cable from the rear of the product.
  2. Removed the ink cartrigdes and wait for "insert cartridge message to display.
  3. Disconnect the power cord from the back and wait for 60 seconds.
  4. Reconnect the power cord. If the product does not automatically turn on, press the Power button
  5. Reinsert the cartridges, and then close any open doors on the product.
  6. If you receive a prompt to print a calibration page, do so.
  7. Reconnect the USB cable to the rear of the product, and then try printing again.
Regards,
Riztech
Mar 04, 2010 | HP C6280 All-in-One Printer
HP PHOTOSMART C6280 ALLINONE PRINTER HAS A OUT OF PAPER ERROR BUT THERE IS PAPER IN IT
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Jan 26, 2010 | HP Photosmart C6280 Printer
We've got an HP C6280 printer and ever since we changed out the light Cycan ink cartridge, we've been getting the error message 0xc18a0401. It's telling us to shut it downa and when we do, it won't and...
Hello there ok I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 11, 2010 | HP Photosmart C6280 Printer
I am trying to print a document from my computer, but the guide says I have to insert a memory card, so my printing request just waits in cue.
The photo button on the printer will always say that, you need to go back to the normal mode on the printer and just send the print job from the computer.
Dec 22, 2009 | HP Photosmart C6280 Printer
HP C6280 Error: Ink Cartridges Empty
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
Aug 20, 2009 | HP Photosmart C6280 Printer
HP C6280 Error Oxc18a0305
Step one: Remove the cartridges
  1. Make sure that the product is turned on and then disconnect the USB cable from the back of the product.
  2. Open the product cover and remove the cartridges.
  3. Close the cover and wait for a message to insert the cartridges to appear on the control panel display.
  5. Disconnect the power cord from the wall outlet and wait for one minute.
Step two: Reinstall the cartridges
  1. Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on.
  2. Open the product cover and reinstall the cartridges.
  3. Close the cover and print a calibration page, if prompted.
  4. Print a self test report to make sure that the product can print.
  5. Reconnect the USB cable between the product and the computer.
  6. Try to print a document from an application on the computer.
This should work
Jun 16, 2009 | HP Photosmart C6280 Printer
Aug 21, 2008 | HP Photosmart C6280 Printer
Printer formating the printer
how do i open the printer to change my cartridge?
Jan 23, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C6280 Printer Logo
18 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
