Check your transmission fluid level with the engine running and your shifter in Park. When was the last time you had your fluid and filter changed? Could be a plugged filter.
This is a safety feature for the motor. It is called a rev limiter. This is meant to prevent the motor from reving at high rpms when at idle. This is completely normal
sounds like the throttle plate is stuck try cleaning is out do not push on the throttle plate will damage it. have some one sit in the vehicle with their foot on the pedal take a tooth brush and some carb cleaner clean both side of the plate and inside the housing the best you can and see if the stops it.
Check the fluid while the engine is on in park..
If fluid is not low - it could be a vacume or modulator issue.. (the modular tells the trani when to shift via vacume presure)
Some shops give free estimates.
