Question about Zebra S4M Thermal Label Printer
Loftware printing to zebra only data light flashes
  • 10 Answers
SOURCE: Zebra S600, Recieves data, but does not print
Go into the printer driver and select print a test page, does it print out?
If so then try printing from your label software, it should work, if not then it is your software that is at fault.
If the test page does not print out then check all the settings in the print driver, so they are the same as the physical label.
If non of this helps then go to www.lancerlabels.co.uk and do a live chat to Michael.
Posted on Feb 17, 2009
bartech9
  • 155 Answers
SOURCE: Zebra Z4m+ won't print from Bartender 9.01
BarTender uses its own drivers for each model of printer you must install the correct driver, because there are differences in some commands a printer to another.
Posted on Mar 10, 2009
bartech9
  • 155 Answers
SOURCE: Zebra S500 no print
You can find the manual in www.zebra.com, and try reset, pressing FEED and PAUSE keys and turn on printer, release keys until move labels.
Posted on Mar 17, 2009
  • 185 Answers
SOURCE: Loftware labels printing off staggered.
Most reasons for this is a slight adjustment problem with page length. You can recalibrate the printer via the menu system, doing it this way will adjust the sensors with new settings
Posted on Apr 13, 2010
  • 185 Answers
SOURCE: Increase Speed on Zebra 105SL
In the driver there are settings for print speed, you will aslo need to access the menu on the printer and set the speed
Posted on May 04, 2010
Why wont my zebra printer print
You can avoid the issues just downloading for free a driver pack for your printer at www.nicelabel.cl (you will just need to enter an email and will get it free at downloads)
Oct 15, 2012 | Zebra S Series 160S Thermal Printer
Power light lit Pause light lit data light flashing and display saying printer idle , ribbon out
Press the pause button to take the printer off pause...
The data light is flashing because it has labels to print...
Check to be sure your ribbon is loaded properly.
Jun 20, 2010 | Zebra 203DPI Printer
Increasing Speed on Zebra 105sl
If you are refering to print speed, from the label format, press F5 to bring up the LABEL & SETUP PROPERTIES. Click on LABEL OPTIONS and print speed will be the first choice.
If you are refering to how fast data is sent to the printer, then that depends on the connection to the PC and whether you are using true-type fonts or not.
Hope that helps !
Apr 27, 2010 | Zebra 105SL Thermal Label Printer
Apr 27, 2010 | Zebra Eltron TLP 2844 Thermal Label...
Mar 11, 2010 | Zebra Eltron TLP 2844 Thermal Label...
Running two Zebra's through Easylabel Platinum
When connecting Easylabel to a Zebra through the RS232 port, it's very important that the serial settings match between Easylabel and the printer. Easylabel defaults to 9600 baud, 8 data bits, none parity. The Zebra defaults to 9600 baud, 7 data bits, and even parity. This mismatch causes the data light to flash but no print.
Change the printer setting to 8 data bits and none for parity and the baud rate can be whatever but make sure they match from Easylabel to the printer.
Hope that helps !
Sep 18, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Zebra S500 no print
Mar 12, 2009 | Zebra Stripe S600 Thermal Label Printer
Part of the tag does NOT print out.
DID YOU CLEAN THE PRINT HEAD AND BRY IT GOOD, CHECK THE SOFTWARE.
MAKE SURE THE MATTERAIL IS THE SAME FOR EACH TAG, DIFFERANT TYPE OF MATERAIL WILL GIVE DIFFERENT TYPE OF PRINT AND THE FINAL PRODUCE WILL BE TOTALY DIFFERENT.
SEE IF THE PRINT HEADS HAVE THE SAME CLEAR-INES, SEE IF THE HEADS HAVE APART THAT CAN MAKE THE PRINT A BETTER PICTURE OR BETTER QUILITY OF PRINT.
SEE IT THE PRINT HEAD HAS ANY TYPE OF HEAD ADJUSTMENT, REQUEST A SERVICE MANUAL FOR THIS TYPE OF ADJUSTMENT AND YOU WILL NEED SOME FILLER GIUDGES TO MAKE THAT SDJUSTMENT THE SAME ONES YOU USED TO FIX THE OLD CAR WITH THE FLAT SILER ONES
ROD GANDY
Feb 17, 2009 | Zebra Printer 140-751-00000
Printing Bar Code Labels from Intermec 3400
I am using Smartforms with Intermec printer 3400-e and it works in the correct way.
What is the software that you use to build the layout of the label? In my case Loftware.
What is the code to print the Barcodes.
In my case Code 39
Aug 07, 2008 | Intermec EasyCoder 3400 Thermal Label...
Zebra S4M Thermal Label Printer Logo
20 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
