Question about Toshiba TheaterWide 62HM84 62" Rear Projection HDTV-Ready Television
Toshiba 62hm84 No Screen display, powers up, then shuts down
The green light flashes, then the red. Tv then powers down and restarts. Still no display, no sound. If it was just the lamp, you should be able to hear sound from the channels right? What can it be. Some say it might be the ballast. What does the ballast do? And will just changing the lamp work? Why does it powe down after a few tries and repeats itself? Please help. Thanks
C-Dog
  • 84 Answers
SOURCE: ballast
yes, at www.tritronicsinc.com. They are in Maryland and are a Toshiba authorized parts distributor.
C-Dog
Posted on Feb 11, 2008
  • 304 Answers
SOURCE: DLP 5063WX. Sound but no picture. Screen Black.
Is the Lamp ok? Go to the rear of the set and turn on the set with your remote while looking at the vent slats. If you can see a bright light through the vent slats then your Lamp is working. If the lamp is on and you have sound and no pix, then the Digital bd is in what we call "Video Mute" and will have to be replaced. Also make sure that the Lamp Door is installed and the screws are tight.
Posted on Jul 16, 2009
SOURCE: Just replaced the lamp on my Toshiba 62HMX84.
I have a 62HM84 Toshiba TV. I lost picture on my TV in the past i have bought the lamps and i just put it on and the picture comes on. This time when i replaced the lamp nothing happens no picture. It tries 8 times to turn on, but nothing happens. Can you help me with is what is the problem.
Posted on Dec 22, 2009
axeist
SOURCE: 52HM84 Toshiba DLP with apparent failed lamp (replaced ballast)
I found R3 on the original board to be open, along with reading an open on CR1, D5 and D6. All the other transistors and the transformer check out. The only thing I have to do now is find out the specs of the diodes. The replacement board also had CR1, D5 and D6 open (R3 was OK). There had been some threads on various locations where remanufactured boards had bad components (the transistors were changed but not some of the other components).
Posted on Jan 18, 2010
SOURCE: My Toshiba 62HM84 won't start. I replaced the bulb
I HAD THE PROBLEM OF BULB NOT TURNING ON. SOME PEOPLE SUGGESTED TO GET THE BULB CHECKED WHICH WAS ALRIGHT, SOME SUGGESTED TO CHANGE THE BALLAST WHICH WAS SMART BUT THERE WAS NO WAY TO CHECK IT OTHER THAN PUTTING A NEW ONE AND TESTING IT. I CALLED THE TECHNICIAN AND HE CHANGED IT BUT STILL NO PICTURE AND SAME CODE OF BULB NOT WORKING. THEN HE CHECKED FUSE ON POWER SUPPLY RIGHT NEXT TO WIRES BRINGING POWER SUPPLY TO BALLAST BUT IT SEEMED OK. HE DECIDED TO CHANGE IT TO SEE IF THIS FIXES THE PROBLEM AND WE CHANGED IT. WE TURNED ON THE TV AND WALLAH. SUGGESTION IS TO CHECK EVERYTHING BEFORE SPENDING MONEY ON NEW BALLAST OR BULB. 2 CENTS OF ADVICE, IT IS SOMETIMES WORTH TO BRING SOMEBODY WHO KNOWS WHAT HE/SHE IS DOING.
Posted on Dec 19, 2010
Older-model Toshiba TV shuts off by itself
There is a large sand filled resistor on the main board close to where the power cord attaches that cracks. This will stop power until it cools enough to make the connection then heats up rapidly to open it again. It may be worth the trouble if you're handy with a soldering gun and can get the back off the TV. If not then I'd consider getting a flat screen.
Aug 21, 2014 | Televison & Video
Toshiba 62hm84 dlp
Sounds as though the system may have overheated. Do you regularly check the filters and clean them? An airduster can also help to blow dust out of hard to reach places.
Apr 14, 2014 | Office Equipment & Supplies
62hmx95, blinking light, powers on then off
Examine in order the lamp, the ballast, the fans.
Apr 29, 2012 | Toshiba 62HMX95 62" HDTV
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Immediately Shuts off with blinking light codes
I suggest doing a google search using the tv model # and brand.
I have learned myself that different big screen tvs seem to each have their own common problems. I have read before of power supply issues that cause what your describing.
Mar 11, 2009 | Samsung HL-R5078W 50" HDTV
Tv swithches off and on.
You have a lamp failure. Replace the lamp. Reset the system ( On the remote hold the "menu" and "volume" buttons down until the system screen appears) and you should be ok assuming that the power circuits for the lamp are ok.
Aug 24, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Error message
My plasma display the "error message condition 1" and red flashing light start blinking and TV screen shut down. Who can halp me to fix the problem??
Jul 03, 2008 | Fujitsu Plasmavision PDS-4221 42 in....
SCreen turns red then shuts off
The 46H84 has 3 CRTs instead of a lamp. Red, Green and Blue. Your red CRT is shorting out shutting down the set.Here is how you test that theory. Remove the speaker grille, there will be an access panel behind the grille remove that and you will see the CRTs red is usually on the left. hit the power momentarally to locate which tube is red. then power down and unplug the power cord. Carefully remove the tubes Circuit board. ( you may have to carefully slice the glob of silicone applied at the factory to get the circuit board off) Once you have the circuit board off the Red CRT make sure it isnt touching anything and try powering up the set. If the set stays on and the other 2 CRTs light up. That tells you the RED crt is shorted and thats whats shutting your set down. Let me know if I can assist you further.
Mar 25, 2008 | Toshiba 46H84 46" Rear Projection...
Toshiba 52Hmx94
How many times does it blink?
I replaced the ballast in my 62HM84 and it fixed it. The problem was TV would not turn On, Red light solid green light blinked 9 times then TV would try to restart. At first I thought it might of been the bulb, so I replaced it, same results. Next I replaced the ballast which is pretty easy, just take pictures before you remove the light engine so you can go back to the picture to verify the connections when reinstalling.
Dec 25, 2007 | Toshiba 52HM95 52" HDTV Projection...
Toshiba TheaterWide 62HM84 62" Rear Projection HDTV-Ready Television Logo
124 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
