Question about Linksys Wireless-G WRT54G Router
Router WRT54G no Power led on
Hi, my router suddenly stop working, I conected the Power supply this is the status of the lights: Power ON led is off, the DMZ led is off, WLAN is off and the internet led blinks sometimes during booting, the 4 Ethernet leds are solid on, the router seems to be turned off, but there is not response when reseting the router neither when pressing the Cisco Systems boton. If I run the dianostic from my laptop it says that there is nothing connected. I already proved the Power Supply line and the DC adaptator and it is ok, so it should be an internal problem any sugestion before to proceed opening the router? Thanks
  • Anonymous Jan 31, 2009
    Ditto
I have the same problem, only difference is Internet LED is solid ON all the time. All these 5 LED's inmediately gets ON after connecting the Power supply (no really booting?).
Any solution so far??
Posted on May 02, 2010
    Genius:
  • 1,061 Answers
HAVE YOU PRESSED THE RESET BUTTON ON REAR OF ROUTER (LEFT SIDE).IF NOT TRY THAT OR FOR MORE INFO CONTACT TECH SUPPORT AThttp://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1149562300349&pagename=Linksys%2FCommon%2FVisitorWrapperRICHARDM69
Posted on Jan 03, 2009
I have a Linksys WRT54G2 Router, It Has Worked Fine For About A Year, And Just Suddenly It Has Problems, The WLaN Light Isn't On At All, The Power Light Is Just Blinking At A Steady Rate. I Can't Access...
Please make sure that Power, Internet and Wireless Light (or LAN light if trying to connect with Ethernet cable) is there on router if you are trying to connect it wireless .
And if only Power light is there only.Please try to power cycle the router ( turn off the router from power supply wait for a minute, plug the power supply back) and then again check the light status.
Even after this if same light status is there please try to reset the router ( there will be small pinhole button on the back side of router) just press it for 15 seconds and then release it.Wait for 2 mins and check the light status again.
It will fix your problem.
Please share the results.
Dec 09, 2010 | Linksys WRT54G2 Wireless Router
Hi, my Linksys Router stopped broadcasting its signal today for some reason. It was working fine the last few days then all of a sudden it just dropped. Connecting directly to the router works but none of...
Log in to the router and check that the WPA/PSK encryption ID or passphrase is still stored. If you have reset the router it may be that the encryption passphrase has been lost and will require to be re-entered. If you cannot remember it it may be possible to obtain it from the properties/settings dialog box on one of the wifi cards on your home computers.
Oct 19, 2010 | Linksys Wireless-G WRT54G Router
My wylan light dont light up
does the router work? put tape over all the lights so you arent annoyed by one light out on an older router.
check to insure a solid connection for all cables on the back of the router and each device connected to the router.
Jun 10, 2010 | Linksys Wireless-G WRT54G Router
I check all connection, all wires and internet connection and the port leds lights do not light on, why?
If when you plug in the power you get the Post light flashes and then no lights you may need to do a hard reset of the router.
If you get no Post light flashes when you plug in the power then your router power supply is most likely the culprit.
Cheers,
Ron
Jan 18, 2010 | Linksys Wireless-G WRT54G Router
My wlan light keep going on and off on my wrt54g
Also check if the power light on your router is blinking. If it is blinking, that's an indication of hardware failure. To revive it, do a hard reset. Press and hold the power button of the router for 30 seconds then unplug the power. Wait for 30 seconds again before you plug it back in.
Oct 27, 2009 | Linksys Wireless-G WRT54G Router
LP 240 stopped working. No lights, no fans, nothing.
Please describe the status of the LED indicator. No LED would indicate a failure of the power supply. I can help you with that.
Flashing red would indicate a fan/lamp problem. Some lamps fail prematurely before the lamp hours are up.
If it is the power supply, no lights at all, I can get you running again. These units have fragile power supplies that can burn out with the slightest power surge. A UPS goes a long way to save future headaches.
Jan 16, 2009 | InFocus LP 240 Multimedia Projector
Brand new router works sometimes
the wall plug type power supply (made in China) may be likely bad.
This actually is a switch mode power supply very unlike the old and usual linear power supplies.
It is common the capacitors used in this supply are under rated and do not last very long.
The problem usually seen with dim LED lights on the unit, limited range and intermittent operation.
Try to find a replacement power supply with perhaps higher current rating.
Good luck
Jan 10, 2009 | Linksys Wireless-G WRT54G Router
WRTP54G not routing
turn the power off for 5 minutes then try.
if still pro let meknow.
Jan 05, 2009 | Linksys Wireless-G WRTP54G Router
Problem with wired connection
if it is the power suplly issue you could pick up a replacement power cord at radio shack I had the same issue with mine only I was in a rush and picked up a adjustable power supply from radio shack and taped the power tip to the router with 3m electrical tape corrected problem no more power lose. good luck hope this helps
Sep 11, 2008 | Linksys Wireless-G WRT54G Router
Wrt54g V8 Suddenly stopped working
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
May 07, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
1,469 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
