Want to know how to set my LG dvd/hdd player to multi region
LG - HDD/DVD Recorder Reciever LH-RH9695IA. How do I set it to multi region?
    Novelist:
  • 146 Answers
IF there is a code for it you will have to check on some of the sites that have region hacks for DVD players. Not all players have the capability of changing them to region free. I looked to see if your model was listed on a couple of the sites that have directions, info and or firmware updates to change region settings on various makes and models of players, and I didn't find yours listed anywhere. It may use methods from other LG models, but you have to do a little research, some google searches and a little trial and error. Keep in mind that applying these hacks can render your unit inoperable and not recoverable. You might want to look into getting an inexpensive player from Phillips, Durabrand, Apex or one of several other manufacturers that are easy to find codes for and simple to change region coding, and in alot of cases cost less than 50 USD. Phillips are the easiest to get codes for and they are reasonably priced in most department stores like Target and Walmart or at Best Buy and Circuit City. Durabrand are Walmart brand players that cost 25 or 30 dollars and they are easy to do as well.
Hope this helps
Cheers
Posted on Jan 03, 2009
LG DVB-T HDD/DVD RECORDER MODEL RH2T160 REGION CODES
hi,
try the following to make ur dvd playre region free.
p { margin-bottom: 0.21cm; }
1.Power ON
2.Eject Tray in DVD Mode
3.Press "0" seven times
4.Enter "0" as New Region Code
5.Press Enter
ur player will become region free
ok
Dec 27, 2010 | LG RH177 DVD Recorder/HDD Recorder
LG RH387 HDD DVD Player wil not play Disc's from other Regions.
1. Go to http://hk.lge.com/support/support_lgeservice.jsp
2. Go to "Product Support"
3. On the left panel, find "Device Driver", then "DVD Player/Recorder".
4. Download the "RH3xx.iso" from the linked page.
5. Burnt ISO to a CD (must be burnt as an image, use free software such as ImgBurn http://www.imgburn.com/)
6. Load CD onto the LG player
7. You will be prompted to choose a new region code - go with 0 for region-free
Jan 12, 2009 | LG RH1999H DVD Recorder/HDD Recorder
Can I make my LG RH4820W HDD/DVD recorder multi region?
1 Power on the DVD recorder
2 Press "open"
3 Press "0000000" on the remote control slowly
4 Congratulations' will display on the screen if setup was successful.
5 Press "enter", then finish
Nov 19, 2008 | LG RH-4820 DVD Recorder
Need to play region 1 DVD in region 2
I just got a RH387H in Hong Kong, region 3, but the above method doesn't work, this model has slightly different icon, no "lock" icon, I tried in other similar location but no effect, hopefully someone will provide a method.
ipw
Jun 28, 2008 | LG RH1999H DVD Recorder/HDD Recorder
hi
try a search on your dvd here check for region codes dvd
riz.
May 31, 2008 | LG RH177 DVD Recorder/HDD Recorder
Playing region 1 DVDs in LG DR165 receroder
go to dvd set up then scroll dow to lock then push 0 seven times
Jan 23, 2008 | LG RH177 DVD Recorder/HDD Recorder
SAMSUNG HR733 DVD RECORDER WILL NOT PLAY ANY REGION DISCS AT ALL
On page 45 of the user manual it says this:
Both the HDD & DVD RECORDER and the discs are coded
by region. These regional codes must match in order for the
disc to play. If the codes do not match, the disc will not play.
The Region Number for this HDD & DVD RECORDER is
described on the rear panel of the HDD & DVD RECORDER
If you changed the region codes on your player it will not work. They should be set back to 1 or whatever your model says on the back of the unit.
If this unit was purchased outside the United States, it may not work in the United States.
Here is a copy of the manual if you need it:
http://downloadcenter.samsung.com/content/UM/200506/20050618115856781_HR720-00758C-XAC-Eng_0519.pdf
Dec 08, 2007 | Samsung DVD-HR720 DVD Recorder
Televison & Video Logo
251 people viewed this question
Top Televison & Video Experts
Electro Med Services...
