Question about Alpine CDA9831R CD Player
What does interrupt mean on the cda 9831r
Disconnected the battery and when put back on interrupted came on the stereo and it doesnt work
5 Suggested Answers
  • 733 Answers
SOURCE: cda 9886 installed and says interrupt
verify all your wires are correct. if anything, just plug the ignition power(red) constant power(yellow) and ground(negative) and turn it on and see if it still says interrupt. If it does try to see if it has a reset button and try that. If not, try connectiong the rca's one at a time and see if it gives you the same problem with the rca's, wich would indicate a short with the rca's. If it works ok after connecting the rca's, then go to your individual speaker wires and see if you have a short with one of your speakers. Hopefully it's not the head unit itself.
Posted on Nov 06, 2009
thepot
  • 188 Answers
SOURCE: Alpine CDA-9856 interrupt message
theres a wire loose, bring your car to an audio tech and he'l sort it
Posted on Nov 09, 2009
SOURCE: iv just bought a renault clio, will my alpine
i think you have to buy a special part for that look on ebay
Posted on Mar 31, 2010
kenw392
  • 2226 Answers
SOURCE: i need a wire harness for Alpine CDA-9831R CD/MP3
Any decent car audio store should be able to sell you one. Most Alpine wire harnesses from that year should work with it.
Posted on Oct 24, 2011
How to reset interrupter lockout
Disconnect battery for the night. REMEMBER your stereo if it has an anti theft one on it will ask for your password. Most cars have that locate it on the glove compratment, look for it before you disconnect the battery otherwise you will have another problem.
By disconnecting your battery you ECU will reset it self.
Oct 02, 2016 | Cars & Trucks
My cd in my van kips saeig sefe
I take it you mean the cd player display is indicating "SAFE". This usually happens if the battery is disconnected to eather service something electrical on the vehicle or if the battery is being replaced. It's a burglar proof feature built into the player which is supposed to prevent thieves from reselling a stereo unit after stealing it by going into safe mode when it's power is interrupted thereby making the cd unit unable to be resold as it will not work. But it may be reset and placed back into serviceable mode by taking it to your dealership. They can reset the safe feature for you. Just ask them disable the feature in the player so it will not go back into "safe" if you have the battery disconnected again, but remember it will not be burglar proof anymore. Otherwise, to prevent it from going back into "safe" mode if you need to disconnect the power, then I suggest you get yourself a memory saver unit and attach the 9 volt battery and plug it into your cigarette lighter plug or the 12 volt power source on your dash before you disconnect the battery. That way, the power will not be interrupted to again set the "safe" back on.
Good Luck.
Mar 06, 2015 | Vehicle Parts & Accessories
I hav a alpine cda-w925ehi head unit an it just stopped an now says "interrupt"
Hi I believe you have an Australia model? Alpine's use what's know as an interrupt wire to hook into vehicles/phones to interrupt the audio of the deck when their is a signal sent to it. On the Alpine harness you need to search for the Pink/black striped wire which is the audio interrupt wire. Make sure that wire is insulated and not grounding out against anything or hooked up incorrectly.
-Boz
Nov 28, 2012 | Car Audio & Video
What is the
I believe that feature works with a device like a cell phone (when you have installed correctly it should allow for automatic interruption for incoming voice calls while driving, while also permitting a safe "hands free" driving exp)
May 22, 2012 | Alpine CDA-9830 CD Player
I have no harness for vehical was told the reason I have no sound is becuase the pink and black wire labeled Audio interrupt lead were does this connect 2
The install diagram indicates the Audio Interrupt wire goes to a Vehicle Phone. If you don't have one, don;t connect it to anything andmake sure you put tape over the end so it doesn't touch ground or a power source.
In cases where I don't have or cannot get a wiring harness adapter to plug directly into my vehicle wiring harness I have a trick I like to use. I don't like to cut and remove a vehicle harness socket, I may want to keep the aftermarket stereo when I sell or trade and put the original stereo back in place. Instead of removing the socket I skin back (but do not cut) the wires I need to tap into and wrap the aftermarket unit's wires around the now exposed socket wiring, then solder each one & wrap each one individually with electrical tape. This gives you a secure connection and when and if you need to permanently remove the aftermarket unit you just untape the wires, clip the fatermarket wires off one at a time very close to where they are tapped in, tape each one of them again and there you have the factory plug ready to plug back into the factory stereo.
Aug 20, 2011 | Alpine CDA-7892 CD Player
Alpine 9887 displays INTERRUPT in 1998 Honda Accord EX
i think its the wires mate.
if you wnt to try something Discconect the battery of the car. let it 10 minutes and then plug it again. if it not work
the problems are the wires.
Check on the web for the distribution of the colors and wires from ur stereo and from the car.
cheers hope that help
Apr 25, 2010 | Alpine CDA-9887 CD Player
Nov 06, 2009 | Alpine CDA-9883 CD Player
Cda 9886 installed and says interrupt
Nov 06, 2009 | Alpine CDA-9886 Car CD/ MP3 Player
Error Code H2
H2 means the thermistor is open or defective.
Try to press the copy button when h2 appears you'll see the sub 00. You dont need to replace the whole fuser unit. Try first to cancel the trouble by entering the simulation.
Try to press the # - interrupt- C- interrupt (one after the other.) then enter 14 then copy button. If it doesnt work replace the thermistor.
The last part that you'll replace is the main board but that rare. Mostly the thermistor is defective when that trouble appears. Hope it could help you a lot.
Jul 19, 2009 | Sharp AR-5316 Advanced Digital Imager...
Auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Mar 15, 2007 | Alpine CDA-7892 CD Player
Open Questions:
See all Alpine CDA9831R CD Player Questions
Alpine CDA9831R CD Player Logo
27 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
