Question about Aiwa NSXAJ70 Mini System Dual Cassette Shelf System
AIWA CD Problems
I have an AIWA NSX 5200 and an AIWA NSX V-50 mini system. Both have defective CD players - CD's not recognized and don't play, constant cycling, repeated open/close, etc. I've read about a class action law suit and recall but both seem to be distant past. The class action lawsuit site is not longer accessible. I don't think I'm alone in having this problem. These units have decent sound. Is there any way to get the CD player fixed? My email to the regional center listed by AIWA at sales@tekniton.com was returned as undeliverable. These systems still sound good when I plug in my iPod but it would be nioce to have the CD working again. Any suggestions, recommendations, or leads greatly appreciated.
Thanks very much!
Sounds like the lasers need a POT (potentiometer) adjustment. Tools you will need are a multimeter with Ohms (preferably digital) either a #1 or #00 and #2 philips screwdriver. You will need access to the bottom of the laser. On the units I've worked on the POT faces the back of the unit. It will look like a philips head screw in a square metal casing. You should not need to completely remove the CD tray assembly but you can if you wish though I recommend removing the tray bezel Look for two legs on the side of the POT casing that go to the laser PCB. Measure the resistance across the two legs for an initial reading. On mine it was exactly 1kOhm. Now take the #1 or #00 philip screwdriver and adjust the screw to lower the resistance. POT screws are typically EXTREMELY sensitive so 1/16 of a turn can make a big difference. Start by lowering it by about 20-25%. So if the initial reading was 1kOhm aim for 750-800Ohms and test. You should use several disks for testing. If your unit is capable of CD-R/RW playback then have those available as they are generally more difficult to read. If you have playback gradually increase the resistance 5-10% until the disk is no longer readable or struggles to read. Now lower the resistance again 5-10% and retest. If all works well reassemble and enjoy. It is necessary NOT to lower the resistance too much as it will shorten the life of the laser and if too low could damage the disks. If you must go lower than 25-30% the laser is not worth salvaging. Typically 10-15% is all that is required. If you need more detail I recommend doing a search for 'xbox POT adjustment' as the procedure is essentially the same for all lasers and some xbox sites have good pictures so you can see what your doing before you dive in. Total repair time per unit will be 1/2 - 1hr, mostly spent in all the testing. Hope this helps. Good luck
Posted on Jan 29, 2009
Aiwa NSX-A888 Stereo System CD Player
Cleaner disks are a waste. You're better off cleaning the lens with a cotton swab and rubbing alcohol
Apr 14, 2013 | Aiwa NSX-A888 CD Shelf System
I have a nsx-a508 unit,the 2nd tape deck got stuck i was able to open it but now neither deck plays and the cd player did work when this happened originally but does not work now ,the lights all come...
I think I can help you with the tape part, but as for the CD, that's a whole different story.
First, you should reset the unit by holding down the stop button (clear), and then pressing the power button. Everything stored in memory after purchase is cleared, including the radio stations, clock, etc.
Check if deck 1 is now playing.
I had a similar problem with my AIWA NSX-AJ310, and after some digging up, I realised that the belts were busted. They're not hard to replace though, unless you don't trust yourself to replace them. If you don't, let a qualified technician see about that for you.
The CD player in my system has retired also, so, we're in the same boat as with regard to that issue!!
Hope my solution was helpful!!
JaHa
Jun 21, 2011 | Aiwa NSX-A505 CD Shelf System
Aiwa nsx-999 display and cd changer problems
I had a similar problem with my NSX-999. For CD, u need to clean the laser or buy a new cd-laser pickup KSS-210A.
For dim display, replace capacitor C107 and C108 in the mainboard if u know how or take to a repair shop and ask them to replace those two capacitors. It soled my problem
Dec 06, 2009 | Aiwa Audio Players & Recorders
The CD player won't recognize CD's.
Most of those CDs they sell are just a gimmick, nothing can replace a good hand cleaning with a cue-tip done by taking the whole thing apart. Take it to the local technician to get it cleaned properly first and foremost, or do it yourself if you feel safe enough taking all this apart and cleaning a tiny fragile little lens with a cue-tip and windex yourself. If a good hand cleaning like that does not work, then it means the reader head itself is defective and need to be replaced. If this is the case, don't bother. A cheap head will go for around 200$ usually and sometimes more, and at the price you get a new complete system it will be better buying a whole new sound system.
Jul 07, 2009 | Aiwa Audio Players & Recorders
AIWA NSX-2700 Alarm
On the remote hold shift and press timer button.
It should go off.
Hope this works for you
Kurt
Dec 27, 2008 | Aiwa NSX-2700 Shelf System
The cd plyer on the aiwa nsx 330 does not recognize cd's.
I can guide you to solve problem in Aiwa NSX-330 but please post problem here as you wrote it in subject area and its incomplete there.
Thank you.
Nov 25, 2008 | Audio Players & Recorders
Aiwa nsx k570
i need the circuit diagram for the CD player in NSX K 570 Aiwa 3 CD changer music system . I am Located in mumbai colaba. 9819890987
Mar 18, 2008 | Audio Players & Recorders
I have an aiwa nsx 5200 mini system the cd player broke
Soooooooo many people have complained about this system not reading discs properly, yet the solution is incredibly simple. All you need to do is calibrate the lens, and you can do this without even opening the stereo! Here's how:
With the stereo all unplugged, turn it around so the back is facing you.
Now use a flashlight and, looking through the grating on the back, approximate where you think the cd lens mechanism would be. You should see 2 8-pin connector wires side by side (one red and one white) and to their right a small black circle screw type thing.
Using a screw driver, turn the screw thing about 1/10 of a revolution clockwise.
Plug in, and test with a clean cd. If nothing happened, repeat the procedure turning the screw thing in tiny increments (don't over do it.) Eventually, the cd player should recognise the cd. Keep fine tuning and testing until you've found the "sweet spot" where it recognizes and plays cds optimally.
Overall, you should NOT have to turn any more than a full revolution, and even half a revolution is pushing it. What you are really doing by turning this screw is fine tuning the "data reading point" of the laser. Too close and it will focus on the area between the cd and the lens, causing failure to recognize the disc. Too far and it will focus past the data perhaps recognizing the disc but not being able to read it. I believe the major problem with these players is that as they settle in, the area between the lens and cd changes. This would cause a gradual degrading in performance until the player finally failed to recognise any data at all (which is exactly how mine went personally.) There isnt a problem with the quality of the lens itself, therefore it is very fixable!
I have heard that all 3cd Aiwa Mini-systems share this problem so, as long as the calibration tuning screw is exposed through the grating on the back, this fix should work for any of the Aiwa mini-systems with this particular problem. If the screw isnt exposed, it is still possible to get at by opening and dismantling the player. (Unfortunately, i did not originally notice that the screw was accesible through the grating, so i went about pulling the entire system apart and wasting hours of my life. You can thank me later for saving you this tedious trouble as you're listening to cds on your newly fixed player ;-) )
If this doesn't work, or doesn't fix the problem completely, try cleaning the lens. You can do this by either by using a cd lens cleaner (looks like a cd with a brush built into it) or opening up the stereo and using a soft cloth on the lens. You may also want to try putting the screw back to its starting point and using the same procedure but turning the screw counter-clockwise. (I personally had to turn clockwise but who knows, maybe your player settled in differently.)
As for the mechanism itself, i have no idea. I did notice, however, that the lifting mechanism sometimes picks the cd up off-centered causing failure to play. You can semi-fix this by holding the stereo at an angle while it picks up the cd or placing it off-centered in the tray. Its annoying, but it works :)
Feb 19, 2008 | Audio Players & Recorders
CD-R Playback Issue
check the laser eye of your player clean or replace.
Aug 28, 2007 | Aiwa NSX-A115 Shelf System
Aiwa NSXAJ70 Mini System Dual Cassette Shelf System Logo
445 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
