Question about Ariens Garden
NEED INSTRUCTION MANUAL TO ATTACH SNOWBLOWER UNIT TO ARIENS YT
I JUST PICKED UP AN ARIENS YT150H YARD TRACTOR (MODEL 936012) AND WANT TO ATTACH A ARIENS SNOWBLOWER MODEL 836011 TO IT. I SURE WOULD LIKE TO KNOW HOW TO GET A MANUAL OR SOMETHING WITH PICTURES SHOWING THE PROCEDURE. THANKS.
4 Suggested Answers
  • 49 Answers
SOURCE: Ariens Yard Tractor 935 Series - initially drives, then stops moving as it gets warm
Is it a hydrostatic tranmission? If so, sounds like the fluid might be old or not the right viscosity. Recommend changing the trans fluid, and use recommended viscosity of fluid.
Posted on Feb 06, 2009
harlan301
  • 205 Answers
SOURCE: how do I change ariens snowblower belts
on some blowers you have to remove the front auger sya in order to change the belt. it a pain. look down from the top to see if you have room to slid the belts throw, if not remove the front auger
Posted on Oct 12, 2009
  • 146 Answers
SOURCE: 609 yard machine tractor idler pulley spring broke
Here's a diagram, not a great copy, but it may help:
The spring hooks to the idler arm on the opposite end from where the pulley is mounted. The other end of the spring looks like it hooks to a raised tab on the deck, straight behind the left mower spindle. Hope this helps you, please rate my solution if so, thanks!
Posted on Jun 08, 2010
Owner's manual for craftsman YT4000 model 917.288561
Bob, Check the attached links, Craftsman Riding Mowers instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://lawnandgarden.manualsonline.com/manuals/mfg/craftsman/yt_4000.html
Craftsman 28925 YT 4000 24 HP 42 Yard Tractor Manual
Apr 05, 2016 | Craftsman Garden
How car I find the Manual 938006 for my ariens snowblower?
The owners manual won't in the repair. There is no model specif repair manual available. If needing engine repairs then you need find the repair manual the engine.
Here is google link to the various 938006 models were you can find a parts list for your blower.
Aug 17, 2014 | Garden
I have a ariens yard tractor YT 150 H model number 936012 serial number 004697 . I have replaced the pto switch and the relay and every time I engage the blades the mower cuts off. Could you please tell...
I have the same model and had the same problem. Ended up being a bad bearing in one of the deck pulleys. You can find it by disconnecting the drive belt for the blades and turning the pulley by hand. One of them is going to be a lot tighter than the other. You should probably replace both while you have it torn apart...
Oct 22, 2010 | Garden
I have an Ariens YT150H riding mower and the hydrostatic transmission seems disengaged. I have already checked the manual selector at the back on the tractor and it is in the correct position. It has been...
Make sure that when you reinstalled the rear tire, that you reinstalled the keyway into the axle. I think your wheel is probably just spinning on the axle. Otherwise, did you have to get rough with the wheel to take it off the axle??? Some of these trans have a snap ring on the inside of the unit that holds the axle in place. Hammering on the wheel can often cause the snap ring to come off internally in the trans.
I really hop you just missed putting the keyway back into the axle.
Sep 20, 2010 | Garden
We are looking for the service manual for an Ariens snowblower Model 92001. I would like to print it from the computer.
Try printing from here. You'll need a model AND serial number
http://apache.ariens.com/cgibin/ctrg0005?SESSIONID=gsw0uz210g3q1n45lcz3mtig&site=arienss
Dec 28, 2009 | Garden
Have an older tractor and snow blower attachment.
Go to sears.com and lookup in the parts listings for the tractors model number and the snowblowers model number and they will show all the attachments and brackets needed to run it. Hope This Helps Don
Nov 09, 2009 | Craftsman Garden
I have an ariens yt-12 with a 36"snowthrower att. I have no manual hence no way to get parts,like belts ect. Any info would be helpful. Thanks,Jim
if you can provide me an email address i can email you the service manual, parts manual and owners manual.
kbowley at comcast dot net
Sep 09, 2009 | Ariens Garden
Need manual
my ariens mower won't go forwards or backwards
Feb 04, 2009 | Ariens Garden
Garden Logo
266 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
