Question about Toshiba Computers & Internet
My toshia satellite C855-5214 touchpad not working but does with wireless mouse
I tried disabling/enabling touchpad by function key and also tried re-installing the driver but didn't work. then I applied windows updates and it started working.
Posted on Mar 16, 2013
5 Suggested Answers
Pyrhyc
  • 2028 Answers
SOURCE: Toshiba satellite A135-S4527
In the device manager, check to see if the drivers for the synaptic pointing device (touch pad) are installed. If they aren't then you will need to go to Toshiba's support site and download them. If they are, then unistall them and reboot. The machine will find the touch pad and reinstall the drivers. Many times when an external is used, especially for a long period os time, the drivers for the external will override or glitch the drivers for the internal. Reinstalling them should do the trick.
Posted on Jul 23, 2008
  • 4090 Answers
SOURCE: Toshiba Satellite Pro M200 touchpad - Altering the settings
remove the reference to the touchpad in the box that refers to the pointing device. select "other" and connect a USB mouse, slow it down and all should be ok
Posted on Jun 20, 2009
SOURCE: Toshiba Satellite Pro L10 - Touchpad and USB mouse not working
I need help with my Touchpad I was able to use it to click with my finger and I have pressed a button somewhere that will not alow me to do that any more I have looked in control panel and ex. to find something to that effect but I am having no luck can you help?
Thanks
Rochelle
Posted on Aug 11, 2008
  • 67 Answers
SOURCE: the touchpad mouse on my toshiba salellite does
The touchpad is most probably defective. If you have dropped your laptop the touchpad cable could have get out from its connector on the mainboard. You can get a new touchpad/palmrest on ebay. You have to remove your touchpad/palmrest as shown in the link below, steps 17 to 19 :
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
Identify the part number of your touchpad/palmrest. Search on ebay.com : Toshiba Satelitte A105 palmrest. Buy the one with the same part numer as yours.
...or have your laptop repaired by a professional.
Posted on Oct 09, 2009
How to get the Toshiba satellite c 55-A-100 mousepad working aga
On my Satellite Pro P800 one of the F - Keys shows a small mouse if I press this it cycles the touchpad mouse feature on/off. I would guess your laptop has a similar feature. When all else fails read the on line manual. I hate the mousepad and always use a wireless Logitech mouse..
Jul 22, 2014 | Toshiba Satellite Computers & Internet
My mouse pad and two click bars do not work? a wireless mouse does work though. why isnt it reading my finger across the pad when i want to use it instead of the wireless mouse?
You may have it disabled. Press and hold the "fn" key then and press the key that has a symbol for the touchpad on it. For my satellite it is the F9 key. Then give it a shot. It should work.
Mar 05, 2011 | Toshiba Satellite L500 Series Notebook
Toshiba A100 touchpad mouse not moving
Many toshibas have the facility to turn the mouse/trackpad on or off. I have seen it on the upper keys in blue text, meaning you need to hold the fn (Function) key down at the same time as the mouse enable/disable key.
Jul 25, 2010 | Toshiba Satellite A100-S8111TD Notebook
Toshia A135-S4527 that goes blank after account login
Press Ctrl+Alt+Delete, the Task manager will appear. Click File, click New Task, type explorer, OK and it should start.
Jun 20, 2010 | Toshiba Satellite A135-S4527 Notebook
The touchpad mouse on my toshiba salellite does not function even though it shows it working properly when you go into the touchpad icon. I have an external wireless mouse (usb) hooked up that works fine...
Oct 09, 2009 | Toshiba Satellite A105 Notebook
Jun 20, 2009 | Computers & Internet
Touch pad refuses to work
Try going to Toshiba's support page and re-install the driver for the touchpad. If this does not work. You may need to replace the touchpad itself.
Apr 16, 2009 | Toshiba Satellite A135-S2386 Notebook
Mouse or touchpad not working
add an external mouse/keyboard to fix the onboard fault.
check the device manager for any yellow exclamation marks. as there may be a faulty or corrupt. keyboard/mouse touchpad driver.
other option, is to add remove touchpad drivers, and re-install.
finally, you could check if the settings are correct in the bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 05, 2009 | Toshiba Satellite A105 Notebook
Touch pad possessed.
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
For extra USB ports, purchase a USB hub($15 -$20). That way you can add at least 4 USB ports to your laptop.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 19, 2008 | Toshiba Satellite A135-S4527 Notebook
Computers & Internet Logo
755 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
