Question about HP Photosmart C5180 All-In-One InkJet Printer
Error code Oxc18a306 on hp c5180
Keep getting error code Oxc18a306. Tried repeatedly turning off, back on. No luck.
sagarjd
  • 95 Answers
SOURCE: "Wrong Cartridges" Error HP C5180 now Failed ink system.
Please perform the following steps:
A. - Press and hold the “left arrow” key.
B. - Press the “Setup” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release the “OK” button
Display should say “Support” and display the FW rev (something like R0616R)
Now, perform the following instructions:
1. Press and release the right arrow button until the displaysays “System Configuration Menu” 2. Press and release the “OK” button.3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.5. Display should say “Hardware failure status: Clear. Press OK to clear”.6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. 11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.13. If the error is still there, or reoccurs replace the unit.
Posted on Jul 27, 2008
SOURCE: Ink System Failure HP C5180
-------solution 1---------
HP C5180
Hidden tech menu For resetting and repair, FIX UIAUX
Fixes error 0xc18a0507 error ink system fail
press <left arrow> then press <setup> button together
then press <ok>once support R0631m comes on screen
right arrow 2 times to the System configuration menu
then <ok>
then <ok> to select and ok to confirm reset error.
then <cancel> to escape ( all of witch are onscreen instructions.)
presto restart and no further error
http://www.thecomshack.com/hpc7180.htm
------------- solution 2 ----------------------------------
HP C5180 All-In-One Printer HARD RESET:
Hold down HELP + OK button and unplug printer
Hold down HELP + OK button again as you plug the printer back in.
Then power it on, if it doesn’t power on automatically.
Be Safe: keep holding the buttons until the printer turns itself off. (It took mine less than a minute.)
Now you can release the buttons and simply power it back on.
I got an error message about “improper shut down” since I unplugged it w/out powering down. After I clicked “OK” the printer was just fine and didn’t mind anymore. And now I can print.
Posted on Sep 21, 2009
rajeshpait
  • 542 Answers
SOURCE: HP C5180 photosmart keep turning off and on. Will
This is due to ON/OFF switch is having the issue. Repair/replace the switch with the help of expert engineer/service center experts will resolve your problem.
Revert back for more assistance.
Posted on Jan 29, 2010
Testimonial: "helpful thanks"
pineworks
  • 4041 Answers
SOURCE: HP C5180 PRINTER ERROR
Hi ok try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
  • 55 Answers
SOURCE: Get error oxc 18a0001, when I turn on Hp Photosmat c5180 all in o
THAT 0X ERROR IS AN INK SYTEM FAILURE IT MAY HAVE BEEN CAUSED FROM THE REFURBED CARTRIDGES... THE HP WILL WORK WITH THE REFURBS FOR A FEW TIMES BEFORE REJECTING THE CARTRIDGE OR CAUSING AN 0x ERROR. THE UNIT NEEDS TO GO THRU AN ELABORATE INK SYSTEM RESET. OR HAVE THE PRINTER REPLACED
Posted on Mar 29, 2010
How do i fix ink system has failed error code on my hp photosmart c5180 printer?
try master rest for hp C 5180
Master Reset:
Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in. . This sorted it.
Jul 26, 2014 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure
Please Try This, I am sure it is going to workout.
Resetting the All-in-One
Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Jul 30, 2008 | HP Photosmart C5180 All-In-One InkJet...
I connected my hp C5180 to my pc then printed a test page, it started to print and hasn't stopped. It just keep printing pages of code. How do I stop this???? Tried cancelling, tried turning off...
YOU NEED TO GO TO PRINTERS...AND CHANGE HOW PAGES YOU WANT TO PRINT...AND TAKE THE PAPER OUT OF PRINTER, SO IT DOESN'T USE UP ALL YOUR INK!
HOPE THIS HELPS!
Aug 31, 2011 | HP Photosmart C5180 All-In-One InkJet...
I have an HP C5180 that is showing an message Error 0xc18a0301, Ink failure. Tried the HP fix of removing cartridges, turn off/on nothing work. Any ideas
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
5. Wait 60 seconds.
Jun 30, 2009 | HP Photosmart C5180 All-In-One InkJet...
My HP Photosmaart C5180 all-in-one printer will not print
Please go to the hp online support site by clicking here and enter your model number and type the exact error message you are getting for your printer and try to follow the troubleshooting steps outlined there.
If this message is appearing on your computer, write back with your operating system and the error code if given and we'll help you to sort it out...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
Used copy ink now it wont print
see if this works, its worth a shot. not correct code but may help . Shut down your printer by pressing Simultaneously Cancel + OK + Black + Color
Apr 29, 2009 | HP Photosmart C5180 All-In-One InkJet...
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jan 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Reset the product:
5. Wait 60 seconds.
Nov 09, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 Ink System has Failed Error:0xc18a0306
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and the turn it back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartiges in the printer so that it can reset.
Oct 17, 2008 | HP Photosmart C5180 All-In-One InkJet...
C5180 All-in-One
HP doesn't list that specific error code, however www. dumpanalysis.org had a crash dump analysis listing that or a similar code. That means your printer has an internal error state. Check with the HP articles for error codes. You should try shutting it off for two minutes then rebooting to see if you can get it back online. 0xC2FF, & 0x0000C2FF are UTF 16 & 32 bit Hex codes indicating a memory overflow error (from what I could judge). If you are fortunate it will not be a permenant condition from hardware failure, otherwise your printer may need servicing.
Mar 26, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
639 people viewed this question
Seeker5211
Seeker5211
