Question about HP Officejet 5780 Printer
I AM TRYING TO SCAN TO THE COMPUTER BUT I CAN'T THIS IS MY FIRST TIME THAT I USE THE SCANNER AND I DON'T HAVE THE MANUAL, COULD YOU PLEASE HELP ME
  • lemmondrop23 Jan 06, 2009
    When i press the "Start Scan" button i get a message saying PLEASE REFER TO DEVICE DOCUMENTATION TO TROUBLESHOOT. I don't have to manual and can't figure out how to make it work.
  • butkis Jan 16, 2009
    Mine says "No Scan Options" and refers me to manual to troubleshoot it. I do no have a manual. Any suggestions?
When I press the Staart Scan button or Scan to button, I get a message saying please refer to device documentation to troubleshoot. I don't have a manual .What do I do?
Posted on Feb 23, 2009
You need to have "Scan" on your printer.
Insert what you want scanned where you would photo-copy and push "scan". Follow your prompts on screen.
Posted on Jan 03, 2009
3 Suggested Answers
secretgeek50
  • 57 Answers
SOURCE: Scanner hp 1315
Hi -
I don't have a Mac, so not entirely exact on your solution. But, I do have a suggestion to try -
if you use a scanner, you probably have a photo editing software of some kind (like Photo Shop, Paint Shop Pro, etc etc). Within that program, there is an option to obtain the image from a scanner. You should be able to use that function instead. I know that with my WinXP, I could import from the scanner in Paint Shop Pro MUCH easier than trying to use the actual HP buttons on the 1315.
Please note that the 1315 will also only scan flat items well. If it is 3D, like jewelry or oddly shaped objects, you'll only get fuzzy-edged pictures. The 1315 has no depth perception, no matter what setting combination you use. Not HP's finest moment, for sure. I had this printer for a month or two before I was fed up, and went back to a separate printer and scanner! : /
Posted on Jun 12, 2008
Semi-Driver
  • 434 Answers
SOURCE: Trying to figure out how to work my scanner. The
You did not indicate your operating system
HP OfficeJet 4580 No Scan Options Vista
HP OfficeJet 4580 No Scan Options XP
Most common problem, not having the full-featured software installed for your model and OS.
Posted on Jan 14, 2010
I can print to my DCP-330C printer but I don't seem to be able to scan from printer to my computer. My grandfather passed away & I need to scan photos onto my computer so that we can do the photo...
Please check the scanner driver of DCP-330P on your computer. It may has not installed yet. A new printer usually equipped with necessary drivers. Please install it on computer and seek for scanner after installation and follow further info on your screen. You can also use scanner and copied sheet from printer.
May 08, 2011 | Brother DCP-330C All-In-One InkJet Printer
I have entered a few frequencies into my scanner and now i am trying to get them to scan. I press the scan button and it will scan a channel one at a time, but i would liek for it to scan all the...
Your BC72XLT SCAN feature samples one frequency/channel at a time, but it should only stop on active frequencies. If it's stopping on inactive frequencies you may need to adjust the squelch. For more details on programming and operating your scanner you can download and print the factory manual, at no cost, here:
http://www.uniden.com/pdf/BC72XLTom.pdf
Bill B.
Listening in since the 60's
Apr 20, 2011 | Uniden BC72XLT Handheld Scanner
How do I use the scanner on my printer? I push the scanner button and nothing happens.
You have to configure the scanner utility in the printers software that is installed in your computer in order to use the scan button and send the command from the printer to the computer.
This is completely different then using the scan option by accessing it in your computer and sending the signal to scan from computer to printer.
Lets try using the computer to printer option first as its easier.
Go to "start" on the bottom left side of your computer screen
Slide up to programs and locate your Canon Pixma software and open it.
Choose the "Scan" option and hit "ok". Then just follow the prompts.
If its the first time using the scanner option, the software may ask you to confirm your choices for the default when choosing picture or documents. In general the software already has the default choices that are best for your machine in these areas. So just leave them alone and confirm them to continue on and use your scanner.
If this does not work for you or other issues come up while trying these instructions please clarify them and I will help you until able to scan right now.
Sep 27, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Scanner says sorry an unknown error occured The scanner seems to reconize it is connected to the computer, but it will not complete the scan
You don´t give enough information in order to allow us to help you (How are you trying to scan? What exactly happens? What OS is installed in your computer? Which software/driver did you install? Does your printer otherwise works?)
Start by reading these HP FAQs to see if you can solve the problem (2 are meant for Vista systems and one for XP). Post again if you still can't scan.
Sep 02, 2009 | HP Photosmart C4280 All-in-One InkJet...
Once you turn the scanner on, select scan document, the page(s) will scan, go to the file designated, then when you try scanning again it says that the scanner is busy. Pressing the ok button then says...
this could be down to the scanner connection not being set properly go to the scanner settings check that the port or connection is set to usb if connected directly to computer or if you are using parrallel port set to this the reason you are getting a hang is the document is being saved and then trying to connect to computer or printer and it cant communicate so the docs go no where by turning off you reset it again... good luck A
Jun 10, 2009 | HP Office Equipment & Supplies
Code error ffff:0024
While I am trying to scan the images, I am getting the error Code[ffff:0024] & I am unable to scan anything from Epson 1500 model. While I switch on the scanner, it sounds lot from the scanner for continuous 2 minutes. I couldn't get scanned anything ... please
give me the solution.
Mar 30, 2009 | Acer Scan to Web 3300U Flatbed Scanner
Trying to scan, al it does is bring up Muvee
Scan directly through your scanner:
Control Panel / Scanners and Cameras
Right Click Your Scanner: Click Get Pictures using Scanner Wizard
Mar 02, 2009 | Canon PIXMA MP470 All-in-One Printer
Getting error code Code[ffff:0024]while scanning
while i am trying to scan the images .. i am getting the error code like Code[ffff:0024] while warming up the scanner, besides a sound from the scanner making it power off (light inside the scanner goes off ) so that i could not get scanned anything ... what will be the reason ? please suggest me the trouble shoot kaarthik
Apr 14, 2007 | Acer Scan to Web 3300U Flatbed Scanner
Help w/ scanner
You should have the manual for the scanner and the CD.Study the manual with care. Make sure the software is loaded into the computer. You can scan from this or another program such as a photo editor. Be aware that any scan into the computer will be an image file[ JPEG/BMP] and only only be seen as a photographic image in an editor Word processor will not reveal it unless you deploy an character recognition programs - but that's another story
Apr 11, 2007 | Canon Pixma MP500 All-In-One InkJet...
Open Questions:
See all HP Officejet 5780 Printer Questions
HP Officejet 5780 Printer Logo
133 people viewed this question
Seeker5211
Seeker5211
