Question about Canon PIXMA MP495 InkJet Printer
Desaturated colours After replacing the colour cartridge the photo prints were good for a couple of days then became very desaturated. I have cleaned the nozzles but to no avail. Any help appreciated!
SOURCE: Some colours not printing
are you taking ink out while you are doing the cleaning.
Posted on Aug 14, 2007
Mykel_N
  • 315 Answers
SOURCE: Muddy, unsaturated prints
Have a look at this article:
http://shutterbug.com/techniques/digital_darkroom/0412edp_output/
It might help.
Mike
Posted on May 13, 2009
57 varieties
  • 1653 Answers
SOURCE: All colours and black print faded. Black is a
ANSER #1
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
tanks.
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Posted on Sep 30, 2009
  • 10406 Answers
SOURCE: Printing colour is wrong, colours come out pink.
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Posted on Mar 09, 2011
Geekman
  • 32281 Answers
SOURCE: Canon pixma mp530 not printing
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Posted on Jun 15, 2011
R230 epson color
The cartridge head may have gotten clogged. Take the cartridge out and clean the head with a damp cloth and print a couple of pages to set this right.
Also, print a test page to make sure the ink hasn't dried up. If it has, you will have to get a new cartridge.
Aug 12, 2014 | Epson STYLUS R230 InkJet Photo Printer
Why am I missing colors on prints
Could be the print job you send to the printer is set up to print in black and white.
Or the cartridges are full and the nozzles from the printhead are blocked.
Run a cleaning cycle on the printer. If some colour appears continue till all colours are back for all nozzles.
If you did not use he printer for a long time, remove the cartridges one by one and put a drop of cleaning fluid in the pipes in the cartridge holder (where the ink goes in) tun replace the cartridge and print one or two full sized colour photos, till all colours are back.
Jul 26, 2014 | Kodak ESP 7250 All-in-One Printer
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
Colour ink failing
Remove the ink cartridges and clean the sensor below them.
Possibly ink on the blocking the sensor from reading the poper ink level.
After that put the cartridges back in and then go to printers on your PC and right-click the printer on the screen and try to locate a cleaning process or if you have software installed for the printer, run it through there.
Do it a few times if need be and then check the ink level.
Head cleaning it's normally called.
If it doesn't work, then the printer might simply need replacing.
Jul 23, 2009 | Epson Stylus 830U InkJet Photo Printer
MAGENTA NOT PRINTING
The other week I had the black print head clog up, requiring daily nozzle deep cleaning [a normal 'ocassional' maintenance function]. Thought I needed a new Print head, so anything worth a try.
I loaded up an old black cartridge [I load all my own......always have] with Isopropyl Alcohol and ran deep clean on that cartridge a couple of times, then repeat printed [6 times] a page full of the number 8 in about half inch character size, to get the alcohol through the nozzles. then Deep cleaned again 3 times, to wash it through the print head.
I reloaded the normal ink filled cartridge and ran the '8' page again till I got good black output. It has now been working without problem, daily, for over a week. Clearly if it's a Magenta only problem, the cleaning as described above would be a bit different, as the magenta is one of 4 colour cartridges.
My printer does quite a lot of work, and was bought at least a couple of years ago, being used daily for alpha numeric and photo printing work. This was the first difficulty I experienced with it.
Hope the above might help.Ken
May 21, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Printing photos
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
Apr 08, 2008 | HP DeskJet F380 All-In-One Printer
Printing
Likely your purge unit needs cleaning...
Make sure by printing out a test page from printer (not from computer).
If test page is good, you have a software issue. If test page is bad, you need to clean your head and/or purge unit.
Oct 20, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Colour faded
Hi Desperate for help I had a similar trouble with my printer it turned out that when I bought a replacement ink tank they gave me a photo quality cartridge and you can't mix them you need all photo quality or all plain cartridges check for that hope this helps
Jan 12, 2007 | Canon PIXMA MP760 All-In-One InkJet...
Canon PIXMA MP495 InkJet Printer Logo
18 people viewed this question
old marine
old marine
