Beko w765s front loader wont spin I have a beko wma 765s with a peculiar problem. The cycle runs through as normal and the drum rotates at the appropriate times, that is until it reaches the spin cycle. Everything starts off ok, it increases in speed up to, i would say 800rpm for a few minutes, then stops as if the power as been turned of (but it hasnt and the front display remains lit), then just as the drum is about to stop rotating it burst back up to full revs, not gently, but all at once, which makes the belt scream and the machine bounce!! It then spins for about 30 seconds and does it all over again, and again until the time runs out, without ever reaching top speed of 1200 or 1600 (cycle dependant) I replaced the carbon brushes as the old ones kept sticking in and were pitted but it made no difference. When the motor is spinning, it is very smooth and quiet, with no noticable spaking on the comm, until it suddenly sets off at full speed which makes the motor spark, belt scream, machine jump, and me **** myself!! someone please help. The machine drains as normal and the pump has no problems.
  • Washing Mach... Master
  • 744 Answers
Hi if your beko w765s washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Posted on Feb 14, 2015
  • 15,935 Answers
It appears your main controller board or motor controller board has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Beko WMA 765s drum not turning. What would the possible cause be? And how do I get the door to open to retrieve my washing so I can work on it?
sounds like the motor has quit. take off rear panel and check for bad wires and to see if the belt is good or bad. it may be broken
Oct 07, 2014 | Washing Machines
LG front loader washer squeaks when drum is rotated manually
Possibly front boot seal give it a spry with sillicon spray.
Apr 27, 2014 | LG WM1814CW Front Load Washer
BEKO WM5100W , DRUM NOT SPINNING DURING WASH CYCLE
It could be carbon brushes or electronic fault.
Do you have ability to check carbon brushes?
Feel free to ask if you dont know how to do it.
Apr 07, 2013 | Beko Washing Machines
Hi, my Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer, won't rinse and I have to manually turn dial to spin, any ideas please?
Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 26, 2013 | Beko Washing Machines
MY BEKO 765s washing machine, has stopped working mid load, on the display it is flashing iL but its smaller, it has also gone onto pause, and wont go on to start, also on flashing on 1200. This was a...
Hi if your beko 765s washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Dec 31, 2010 | Televison & Video
We have a Frigidaire FWTB59RGSO front load washer. The fast spin cycle is not working properly. The shocks on the bottom were replaced because they were broke. The problem has not gone away. It is...
I have a front loader washer # fwtb59rgso and it wont spin or agatate, everything else works fine. feels like normal drag on the drum when I try to rotate it. Any ideas what could be wrong?
Nov 28, 2009 | Frigidaire Washing Machines
Beko WMA 765 s - water will not drain from machine
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Good Luck!!!
May 06, 2009 | Washing Machines
Aug 20, 2008 | Washing Machines
Washing Machines Logo
155 people viewed this question
Top Washing Machines Experts
