Question about SanDisk Sansa m240 MP3 Player
Dead battery? does the mp3 have an automatic shut off?or can you actually have a "dead battery"?if you do have a dead battery,will that prevent me from turning it on and off? this is in relation to my previously asked question
  • Anonymous Jan 13, 2009
    Mine was getting low on battery, but not close to dead, when it suddenly went blank in the middle of playing a song, suggesting that it was dead. The song did not keep on playing, and it wouldn't turn back on.
  • 8,596 Answers
Both. It has an automatic shutoff - it can be changed in the settings menu - AND it could possibly have a dead battery. Do yourself a favor - before you ask any more questions, download a full user's manual from Sandisk's website - they are the manufacturer of your player.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 03, 2009
Charging problem
Check that your alternator is actually charging the battery. With volt meter and car running check for at least 13.5 volts at battery. If not check fuses, big red wire from alternator to battery and for actual output of alternator at bolt where big red wire attaches to alternator. Should have battery voltage with car not running and at least 13.5 when engine is idling(motor running)
Feb 06, 2016 | 1995 Geo Tracker
Tip
How to prevent samsung e2121b/e2120 from blinking and auto off problem?
hi,<br />samsung have produced a bad quality of phone model and it is e2121b and e2120 ,one of the common problem in this phone model is blinking for for a long time and auto shut off..the reason for that is the weak flash IC ( a small component in the phone in which the program is in it ) ...so how to prevent the phone from blinking and auto shut off?<br /> here is how ..<br /><br />1.prevent the battery to be totally drain ,because when it is drain it will start to automatic shut off ..<br />2.dont change your sim card or micro sd everytime <br />3.dont turn OFF the phone in the ON button ,just REMOVED the battery pack to turn on <br />4. and prevent the phone form dropping because once the flash IC is in defect status ,your phone start to blink and it will automatically shut down...<br /><br />i hope it will help you ,thanks for trusting fixya<br />
on Feb 12, 2011 | Cell Phones
Battery charger reads battery full when dead
The battery is no longer good. You will need to buy a new battery. Don't over charge your batteries. They all vary. Expensive cordless tools will come with a charger that shuts off automatic to prevent over charging. I own cheap Skill drills that has served me well. These batteries lasted over 11years. It makes no sense. They should not have lasted more than 5 yrs., even 2yrs. I make sure I never over charged them, but they should not last that long. Freaky. Your battery is dead forever, sorry. I have others just like yours waiting to be recycled.
Sep 29, 2012 | GRACO INC TrueCoat 18V Lithium Ion Battery...
My battery went dead, so i recharge it and the car starts, now my throttle doesnt work what happend?
Sounds like when the battery went dead, there was still a little power left in it, and when starting was attempted, it went completely dead. This causes the computer to automatically shut down to prevent damage to it. Starting it afterwards may require allowing it to run until it reaches operating temp (when temp gauge is in center), and then restarting one or two times. If this doesn't work, you will need a scan tool to reset pcm.
Sep 20, 2011 | 1997 Mercedes-Benz C-Class
The mp3 player wont charge. plug into computer and it shows charging but as soon as it is disconnected it shuts off and wont turn on.
Some mp3's don't expressly charge on the computer, that why when you connect it, the computer only sees it as a flash but is not actually charging it all this while and the battery is completely down. So try and get an external charger for it, the battery may be completely dead.Or probably you need to change the battery. Hope that puts a smile on your face.
Feb 04, 2010 | Samsung YP-K5 MP3 Player
Batter low shutting down
Your battery is low, therefore the player is shutting down.
Recharge the player by plugging it into your computer for 3-4 hours - make sure the hold/lock is not activated, or it will prevent proper charging.
-Tha Mp3 Doctor
Mar 18, 2009 | SanDisk Sansa e250 MP3 Player
My ipod had a low battery, so i charged i overnight as usual, when i got up the next day it said fully charged and when i unplugged it from the usb, it shut off and would not come back on. ive tried to...
I think you may just have a dead battery. The batteries on the iPod last a long time but they do go bad after years of use.
Occasionally a battery will die almost immediately without warning.
Also, use an AC wall charger to verify it's actually being charged.
USB cables work for transferring music, but are a weak source for charging. If you need a battery click here or check ebay they are fairly inexpensive to replace.
Feb 28, 2009 | Apple iPod MA446LL/A MP3 Player
Rio Carbon Screen is Frozen...
only thing you can do is let the battery go dead and hope that it will come on properly, you can also try pluggin it into usb, but your probably alreay tried that.
Sep 22, 2008 | Rio Carbon MP3 Player
My zen jukebox turns off then on and I just replaced and charged a new battery
Take out the battery. Plug it in. Does it play reliably?
Yes: That's a bad battery.
No: reset the device, and try above again.
Aug 14, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
SanDisk Sansa m240 MP3 Player Logo
74 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
