Question about Toshiba e310 Pocket PC
Battery does not charge
My battery will not charge....I have replaced it same result
  • Len Cahoon May 27, 2007
    Does this reset the charge......went to 15% and stay there
  • 883 Answers
Look for a tiny pinhole and insert a pin while powered up to reset the device
Posted on May 27, 2007
  • Marty marty May 30, 2007
    it should reset the micro chip to factory default code settings including basic utility codes to charge the battery. look for firmware upgrade download on Toshiba website
2013 forester won’t start. Not engaging starter but gets a clicking sound. Tried noting yet
Check battery!
If voltage goes below 9 then battery needs to be charged
If headlights go very dim during crank battery needs charge
If after charge same result replace battery
Hope this helps?
Feb 22, 2017 | Cars & Trucks
Put a new alernater an still over charging
Over charging could be the result of several things including:
    Faulty Voltage Regulator
  1. A car's battery will overcharge if the voltage regulator isn't working correctly. A voltage regulator is usually part of the alternator, and is used to keep a steady flow of voltage to the battery. If the voltage regulator is defective, it will send either too little or too much charge to the battery. If it sends too much, the car battery will overcharge. The voltage regulator is easily replaceable at an easily affordable price, sometimes for as little as twenty dollars, as of 2009.
  2. Faulty Alternator
  3. Sometimes the alternator itself can be at fault. The alternator is the device that converts the mechanical power of the engine into electrical power to charge the battery. When an alternator breaks, it usually stops creating electricity for the battery, which will then eventually die. However, if the wrong alternator is placed in the car, or if the alternator is running at the wrong pace, it will create too much energy for the car battery, causing it to overcharge. The alternator is another easily replaced part.
  4. Incorrect Charger Use
  5. If a battery charger is used to charge your battery outside of your car, improper use of the charger can result in overcharging. If a battery is placed on the charger too long, it can result in overcharging, and a significant decrease in your battery's lifespan and efficiency. This is why it is important to read about your specific battery and understand how long it needs to charge to be effective. Too much charge will lead to problems.
  6. Faulty Battery Chargers
  7. Sometimes chargers can be faulty. Their settings may be wired incorrectly, or the charges labeled incorrectly. As a result, your battery may be getting overcharged, even if you are carefully monitoring your charging. This is a problem that is hard to avoid, as manufacturing mistakes can happen anywhere, anytime without warning. It is a good idea to test your charger regularly to see if it is running correctly.
  8. Heat
  9. Extreme heat in the summer can also have an adverse effect on the car battery. If the battery has been previously overcharged, extreme heat can increase the problems caused by overcharging, and exacerbate any other problems with the battery. This problem can be hard to avoid if you live in a warm climate. The only real way to ensure safety against this problem is to avoid overcharge in the first place.
Feb 27, 2011 | Ford Expedition Cars & Trucks
Battery will not charge
Either the charger or the battery is bad. Note that batteries are only good for 2 or 3 years before requiring replacement.
If the computer won't work with the battery charger and a minimally charged battery, and it's left on charge for 24 hours with no good power results, try another battery.
Aug 14, 2010 | Toshiba Satellite A100-S8111TD Notebook
Charging problem.. Wont charge battery
The instructions for installing a new alternator usually read to fully charge the battery (12.3 - 12.8 volt range). Otherwise, the alternator will be damaged when it initializes. I have seen some extreme damage result from installing a new alternator with a low-charge battery. The torque required to turn an alternator when damaged in this scenario is unbelieveable!
May 02, 2009 | Honda Accord Cars & Trucks
Battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
Aug 03, 2008 | Fujitsu Pocket Loox 410 Pocket PC
Unit fails to maintain charge
You are correct, most GPS units use a lithium ion rechargable battery, typically they loose there ability to retain a charge after about a year or so depending on use, resulting in the unit having to be always plugged in.
You probably could replace the battery on your own if you could get one, (needs to be soldered into the mainboard) however GARMIN does not sell battery's to consumers, they state that a battery can only be replaced by a garmin service tech.
Check the link below for contact info for garmin.
https://buy.garmin.com/shop/shop.do?pID=290&tab=sp340
Hope this helps
http://pchelpforanyone.blogspot.com
Mar 07, 2008 | Garmin StreetPilot c340 GPS Receiver
When should I replace my backup battery?
The back up battery should be replaced immediately upon seeing the message "Backup Battery Very Low - Your back up battery is very low or missing. Data loss may result from failure to replace the battery very soon. Consult the manufacturer's instructions for directions on replacing or charging the backup battery." Warning: It is important to note that the back up battery in the MobilePro 900 is not rechargeable, thus, to prevent data loss, it is important to change the back up battery immediately when this message is displayed.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Toshiba e310 Pocket PC Logo
96 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
