Question about Broderbund The Print Shop 20 Deluxe for PC
How do I see whats on a floppy disk
Everytime I put it in my computer nothing comes up
please help
thanx
    President:
  • 2,976 Answers
Firts-make sure it's for the type of computer that you have. If you have an IBM make sure it's IBM compatible. If you have an Apple or MAC, make sure it's for use in that system. Floppy drives don't have any type of lasers in them. They're magnetic. If you can put another floppy in the drive and see what is on it but this one shows up as blank, there's most likely nothing on it, unless it's what's called a .zip file. You will not be able to see the individual files because they're compresses. Go to windows explorer and check the dricve after you put the floppy in. If you're using a MAC, I don't know what they call their file explorer but, it's tha same process. If it's blank, if you have the serial number, you might be able to register it and download it from Broderbund. They're a reputable company, They've been around for a long time.
Posted on Jan 03, 2009
  • 818 Answers
I think that the laser of your floppy is not working, or have podwer. You must clean or exchange the unit
Sergio
Floppy disk drive is just sitting humming,i'm trying to get some photos from it to my deskop
Probably having trouble reading the disk. Try another disk to make sure the drive didn't croak. Or you may have a corrupted disk. Floppy disks are notoriously unreliable. Hopefully you can put the pix on a different disk and try again.
If all you did was "select all" nothing is gonna happen. You have to move the files by drag and drop or "copy to." Computers are sophisticated idiots. You have to tell 'em what to do.
Jan 16, 2015 | Verbatim Smartdisk Fdusb-tm2 mitsumi Model...
Can a failed bios update be recovered?
Do you have a floppy drive in this PC? From what I've found you you *may* be able to fix it, but it will more than likely require a floppy drive and a disk. Also, you would need another computer to be able to get the files prepared for the floppy disk, and that computer also would need a floppy drive.
In a nutshell, you would use the 2nd PC to make yourself a boot disk, then put the boot disk in the broke PC and turn it on. In theory, if all goes will, it will read the disk and restore the BIOS.
But you may have to change some files on the disk so it will boot to the BIOS recovery program.
If you do have a floppy drive in the dead PC, turn it on and see if the floppy drive light comes on at all. If it does, then the computer is trying to access the floppy drive, which may allow it to read a disk. You will stand a better chance of getting any recovery to work.
Mar 26, 2014 | Medion Computers & Internet
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
Why won't my computer boot?
Please check that you have nothing in your floppy drive if you have one, If the floppy drive has a disk in it remove it and this should fix your problem. Otherwise please refer to your computers manufacturer for further technical assistance. I hope this helps.
Sep 08, 2012 | HEWLETT-PACKARD Computers & Internet
My Dell optiplex 210L boots up into a menu that says floppy seek failure strike f1 to continue f2 to run utility
You took your battery out and your computer lost all memory of what components it has installed. Hit F2 to get into the System Bios Setup. Look for your Disk drives and you will see your floopy disk drive there also. You should set the Floppy to Not Installed or None. It is probably set to Auto or 1.44.
Mar 18, 2012 | Dell OptiPlex 210L PC Desktop
Just bought a teac fd-05pub usb portable diskette drive. i have a dell computer with windows vista. when i pluged it in the device was installed, however the power light comes on for a few seconds then...
The below is on the basis that the drive is visible in "Computer"...
This can be tow thing, one the drive is not receiving enough power from your USB port, try unplugging any addtional USB devices connected to the PC, if this doesn't work try a powered USB hub. Second the floppy disk is faulty or the drive itself is faulty.
Hope this helps, let me know how it goes.
Thanks
Jul 11, 2011 | Teac FD-05PUB External Floppy Drive
In short, i received an EasyCam Plus sku:98066.. it did not come with the download disk.. i have gone to that www.jascoproducts.com and downloaded it, followed the directions and all that but i still...
This could be a driver problem. Try to uninstall and install it again. Make sure to unizip the file and download the exe file.
May 11, 2010 | GE EasyCam Webcam
SCREEN GOES BLANK NOTHING COMES UP
on restart press f8 then safemode
do a virus scan
then a disk defrag
have you added anything new or changed the system
please let me know if this helped and don't forget to rate me
thanx
Jan 30, 2009 | Acer Aspire 5315 Notebook
Broderbund The Print Shop 20 Deluxe for PC Logo
236 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
