Question about Hitachi 53UWX10B 53" Rear Projection Television
Full mode only
I cannot change the aspect to anything but Full in setup. Aspect button doesn't work either in setup HDTV and SDTV are only options
  • h2omandon Jan 05, 2009
    Thanks Yorty! I was able to change the picture to "normal" using the cable box. I still cannot change it through the TV but that is OK. I am not sure how it will affect DVD's yet.
If you have a cable box, it may be set up for the full aspect. I just got a hd box for my 53" Hitachi and also notice the aspect dose not change using the remote. The guy installing the box was pushing so many buttons during set up I have no idea how to change without calling them. Hope this helps.
Posted on Jan 04, 2009
How do I change to 4:3 aspect setting on sony kdl40ex500
If the WIDE button on the remote control isn't changing the aspect ratios here is what I can tell you:
Normal is not available when you are watching a 720p, 1080i or 1080p source.
If 4:3 Default is set to anything but Off, the Wide Mode setting changes only for the current channel. When you change channels (or inputs), Wide Mode is automatically replaced with the 4:3 Default setting for 4:3 sources. To retain the current Wide Mode setting as channels and inputs are changed, set 4:3 Default to Off.
4:3 Default is not available if Auto Wide is set to Off.
The owner's manual can be found here: https://docs.sony.com/release/KDL32FA600-EX301-EX400-EX401-EX500-EX501.pdf
If you still can't get the aspect ratio to properly work you may need to do a power reset or perform a factory reset: https://us.en.kb.sony.com/app/answers/detail/a_id/38403/c/65,66/p/61659,62766,63066/ Just make sure to note any special picture or sound settings you may have made.
Aug 22, 2014 | Sony BRAVIA KDL40EX500 40-inch Class...
Tv not full screen
Check the aspect ratio of the input signal. If it is recorded wide, there is no hope.
Jun 29, 2013 | Emerson Televison & Video
Picture does not cover the full screen
Press the FORMAT button on control to cycle through the aspect modes. This lets you choose the aspect depending on the format of the received signal and your preference.
http://service.us.panasonic.com/OPERMANPDF/TCP42G15.PDF
May 05, 2011 | Panasonic TC-P50G15 50 in. Plasma HDTV
I just hooked up my 37" insignia and am not gettting full screen
Your tv is likely in a different aspect mode (it will probably have 4:3 which is standard for tv, 16:9 which is widescreen). The remote should have an aspect button. Try pressing that at see if the results are what you are looking for.
Sep 29, 2009 | Insignia 37" LCD Flat-Panel HDTV
Occasionaly a wide screen dvd plays only in full screen
The aspect ratio on your DVD player is not set correctly. Look for a SETUP button on the remote control, there should be something like "QUICK SETUP" or something similar on the setup menu, if not then go to the menu that has the aspect ratio settings listed. Change your aspect ratio to 16:9 WIDESCREEN, and this should solve your problem. Your aspect ratio is 4:3 which is for a regular TV, if the images (especially people) look real skinny and tall on your TV then your aspect ratio is not properly set. Good luck to you!
Jul 30, 2009 | Oppo Digital DV-981HD DVD Player
Blue vertical line at reght side of screen
This is normal. Depending on what you have connected to it the lines could be white, black and white specs, or green. Just mode will show the entire picture event the parts that aren't supposed to be seen. I would not recommend that setting. Full is the best mode if you want to see the entire picture in the correct ratio.
Apr 24, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Can,t get full screen view on TV. Manual says use the WIDE button, but I don't have such on my controller.
The buttom might be labled aspect or wide mode or view mode. If you cant find it you can change the aspect ratio of cable and sat boxs to match the tv
Jan 10, 2009 | Televison & Video
Panasonic TV 50 inch plasma
Dear RyanVa21;
Try changing the picture size with your set's remote, press the aspect ratio button. The remote must be the original Panasonic remote.
Please let me know if that did it.
Thanks!
Richard
Nov 08, 2007 | Panasonic TH-50PX75U Plasma HDTV
Aspect Function Not Working
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made. For example: A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected. Some Dish Network boxes have Size buttons on their remotes and also in their main menu. It's difficult to determine the repair without knowing the types of the peripherals. Hope this helps.
Sep 09, 2007 | Panasonic PT-52LCX65 44" HDTV
Aspect Ratio not responding/always in "Full" mode
Normally, when I see this problem in the customer's home, I find the main culprit to be the cable box. The remote for the cable box may have a button on it to change the format or picture size. You may have to go into the menu of the cable box to change the format setting. Hope this helps.
Apr 22, 2007 | Panasonic TH-42PWD8UK 42 in. EDTV-Ready...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
64 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
