Question about Bose Lifestyle Model 5 Music Center
Bose lifestyle music center
Need manual
SOURCE: Bose lifestyle 12 music center display inop
My display has not been working for years. Replaced c17 cap wich was 33uF 63 volts on lower pcb board( only one on system) . Old cap was good so this was not the problem. Replaced c16 wich was 100uF 25 volts with a 100uF 63volts. Display works, old cap read low. Both c17, and c16 are located on the lower left hand corner of the larger pcb looking from the front of the unit. Hope this helps.
Posted on Jan 15, 2009
SOURCE: How do I connect my iPod to Bose Lifestyle V20 System
You can only Connect a iPod via a iPod dock
Apple iPod Univeral Dock
and use either
Apple Composite AV Cable or Apple Component AV Cable
based on what Output you iPod Allows.
the list of which iPod that is supported is listed on each page of the AV Cables above.
You can use a IR Blaster Cable with the iPod Dock to control the iPod also.
Posted on Feb 01, 2009
SOURCE: bose lifestyle 48 says format unsupported for audio cds
Everytime I want to play an audio cd, it says format unsupported. This is happening very often. And I have also cleaned the cds,but still there is no difference. What is the solution?
Posted on Jan 12, 2011
taran_2005
  • 10515 Answers
SOURCE: I have a bose lifestyle
I realize you stated that you had everything disconnected and then reconnected it, but everytime I see this same issue- it's typically resolved by unplugging power to the main Bose unit for 60 minutes which resets the microprocessor.
This is a common problem on this set. If this would not resolve the problem, this is an internal problem and needs repair. Be advised that repair of this set needs a tech to have the complete knowledge of Bose products and would need to have an access to the service manual. Do not ever try to get the set repaired from local shops as they tend to make the situation more worse.Either contact Bose or repair center which knows about the same such as :-
http://www.myboserepair.com/
In the past, Bose does repair the units for flat $99.00, so worth calling and checking the same with Bose.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Mar 03, 2011
  • 15 Answers
SOURCE: Bose Lifestyle 12 Music Center
I have had problems similar to this on many devices and it is usually a dud LED (light). You can technically de-solder the current LED and replace it but it's not a job for anybody without very good soldering skills.
Check to see if your system is still in warranty as this should be covered. Any electronics repair shop should be able to fix this for you.
Posted on May 08, 2011
I BOUGHT A BOSE P1 REMOTE ON EBAY BECAUSE THE BACKLIGHT WASN'T WORKING ON MINE. GOT THE IT IN PUT BATTERIES IN AND TURRNED IT ON AND IT IS FLASHING ON REPONSE. I DONT HAVE THE OWNERS MANUAL SO...
Hi Kimberly,
Here is a link to manuals Bose offers for one of many systems. In it you will find the instruction Bose Support Owner Manuals for Home theatre systems and speakers
Here is a brief from the lifestyle 50 system. Lifestyle 50 System Bose Product Support .At the site you can navigate until you find your desired hardware. Take a look.
Ah yes a video of the P1 to watch and adapt too
Bose Model P1 Personal Music Center remote
Fare. Well.
Jan 07, 2015 | Bose Televison & Video
We have a Bose Lifestyle model 5 music center and it won't go into surround sound mode. It will play a CD and all 5 speakers work. Any suggestions??
Are you sure the red and white wires plugged into the audio output on your TV because I had the same problem and learned thats where you plug them into
Nov 06, 2012 | Bose Lifestyle Model 5 Music Center
Can't power up my BOSE 1995 Lifestyle Model 5 Music Center
you might want to google the service manual for the system as i did. this will show you how to take it apart. after doing so check the solder points along the dc power jack( power adapter plug on the unit). i was having the same issue and carefully inspected all the components... i resoldered the dc power jack and viola! powers up. btw, my system is bose acoustimass 5 music center model 5 (1995). good luck!
Aug 07, 2012 | Bose LifeStyle 5 Series-III CD Shelf...
Remove cover on bose lifestyle 5 music center
It is a difficult job. There are no screws. It is lock fit type. contach any experienced service technician rather than ttry to open and brake it. Or download the service manual to it by internet.
Jun 12, 2012 | Bose LifeStyle 5 Series-III CD Shelf...
Blown power supply, what does it look like?
There's a power supply in the sub-woofer (acoustimass) module and an adapter module for the music center.
There are several different power adapters for the music center, and the different types are all depicted in the users manual here:
http://www.bose.co.uk/GB/en/images/Lifestyle%2030%20Series%20I%20Home%20Theater%20System_tcm6-4078.pdf
Hope that helps!
Feb 24, 2011 | Bose Lifestyle 30 System
Hoe to connect Bose Lifestyle 25 Home Theater System speakers to onkyo SRX-508
Do you mean TX-SR508? The following should work even if that is not the exact model.
The LS25 supports ONLY analog stereo audio input and the speakers themselves are NOT desigend to be driven by anything BUT the LS25 electronics.
If you still want to use the LS25 as speakers just run an RCA cable pair from VCR / DVR Out on the Onkyo to the AUX IN on the LS25 Music Center.
http://www.retrevo.com/support/Onkyo-TX-SR508-Receivers-manual/id/23653ag910/t/2/
http://www.retrevo.com/support/Bose-Lifestyle-25-Series-I-Home-Theater-Systems-manual/id/525ag019/t/2/
Dec 28, 2010 | Bose Lifestyle 25 System
Need to hook up bose lifestyle 5 music center to comcast cable sony braveo tv and sony dvd. was hooked up until move do not find manual
I'm in a similar situation where I am hooking up a TiVo Premiere, Panasonic Blu-Ray player, and a LG 47LH90 TV to an old Bose Lifestyle 5 Music Center. After reviewing all of my connectivity options, I've come to settle on the fact that my TiVo will connect via the "Video" input on the Music Center (via red/white RCA). The Blu-Ray player will connect to the "AUX" input on the Music Center. And I'll just have to switch between Video and AUX modes for what I'm watching at the time.
Jan 25, 2010 | Audio Players & Recorders
Need a power cord for a Bose Lifestyle Model 5 Music Center. Seriel #U288342.
that is a ac adaptor for the ls5 think it's a 12ac not dc output ,be careful. get one from bose.
Oct 09, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Bose lifestyle fault code 802
Here's what the Bose support website suggests.  Good Luck!
Messages displayed during a Music Information Update
Messages may appear on your media center display during a Music Information Update. If you see a message with instructions to call Bose, and a three-digit code such as "Error Code 802" or "Failed 172" while performing a Music Information Update, it does not necessarily mean there's something wrong with the system. Performing a media center reset and installing the update again may address the issue.
To reset your media center, follow these steps:
  1. Turn the media center off. Wait two minutes
  2. Unplug the power cord from the media center. Wait 30 seconds
  3. Reconnect the power cord
  4. Wait until "Bose Lifestyle" disappears from the screen
Note: After a reset, you will need to wait several minutes before playing stored music (3 to 20 minutes, depending on how many CDs have been stored). All other sources will be available immediately after the system powers up.
If you have any additional questions about these messages, please contactBose® Technical Support or call 1-800-278-1281.
Dec 01, 2008 | Audio Players & Recorders
Bose lifestyle model 5 music center
Bose lifestyle 5 series III does not play any CD or DVD, it keeps saying unsupported formated . Can anyone offer suggestions.
Dec 01, 2007 | Bose LifeStyle 5 Series-III CD Shelf...
Bose Lifestyle Model 5 Music Center Logo
18 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
