Question about White Sewing 1888 Mechanical Sewing Machine
I have an elnita 1006 .The place one would put the thread at the top is flush with the machine . how do i raise these?
I cant thread the machine as the pplace one would put the threed at the top is flush with the machine and there seems nowhere that i can raise these, no problem with threadiung the bobbin.
bargainbox
  • 1388 Answers
SOURCE: bobbin filling
The handwheel may have a pull out/push in action to disengage/engage the clutch, or it may automatically disengage when the bobbin winder is moved to the right for winding........hold a short tail of thread to get it started and you should be away.
Move the winder to the left for sewing, or push handwheel in, according to the mechanism.
Posted on Jun 01, 2008
louislevel_2
  • 374 Answers
SOURCE: Threading bobbin on White sewing machine
hi!
trouble threading well! particularly this not the same on your actual machine but same process is made just watch how does it work and surely you have solve your problem and learn something new.on internet explorer type the address www.youtube.com then on you tube search type "sewing machine" then there a lot of shown for threading and more.enjoy watching while you learn.have a nice day and don't forget to rate me,thank's
Posted on Apr 09, 2009
  • 47 Answers
SOURCE: How to Thread the bobbin on my sewing machine
Visit us at www.ifixmachine.com to avail for a new manual for only $10.00
Posted on Jul 24, 2009
  • 4 Answers
SOURCE: Top thread won't catch the bobbin thread
First check the upper and lower tension adjustments according to link below and then check the knob (bobbin case) that makes the bobbin tension which lies inside the shuttle if it is too loose. Restricted it with the sheet metals around it so that it shouldn't move so freely up and down or back and forward. Be careful it should move freely a little but not too much.
http://www.wikihow.com/Adjust-the-Tension-on-a-Sewing-Machine
@ytac...
Posted on Feb 24, 2010
  • 1116 Answers
SOURCE: I have a WHITE 3300 EMBROIDERY MACHINE and the
Refer to your machine for cleaning the bobbin area.
You will need to clean this area often as lint and thread snips can build up can cause the bobbin feed to malfunction.
If this continues after you have cleaned the machine, the timing may need to be adjusted by a sewing machine tech.
Posted on Mar 18, 2010
My Elnita 245i is squeaking when it goes forward, but not in reverse. Ive oiled inside the needle mechanism and bobbin case areas. No change. It is also breaking top thread after 6 inches
If your machine is mechanical (not computerized), it could very well benefit from a good cleaning and oiling, including the internal mechanical movement. Squeaking could be the feed dogs but could be a multitude of places.
When threading the machine, be sure to ALWAYS raise the presser foot. The fact that the top thread is breaking about 6 inches into the sewing indicates that the thread is catching somewhere. Sometimes, it catches on the thread notch on the thread spool. Other possibilities is that the thread is looped around something, ie the spool pin, a thread guide... Remove the thread entirely from the machine and rethread from the beginning.
Elna Elnita 244 245 Sewing Machine Threading Diagram
This may help you if you decide to try to oil your mechanical machine:
Wheel on right side that controls the needle up and down is very tight...
Feb 07, 2017 | Sewing Machines
I have an old Elnita 130 sewing machine with no manual. How to I thread it? It appears to work but shows signs that I did not thread it correctly.
elna make elinta machine and a 140 is the same threading as a 130
try entering the sites as most I go to require an account ( free) to procedure to read or down load and that process would be better for you
I went google and typed in--user manual for elinta sewing machine model 130-- and the sites show 130, 140 and more so select a site and go from there
thee is also a www.youtube.com>watch that runs for 1.29 and shows how to thread an old elna sewing machine
you might pick up a clue from that film
Dec 16, 2016 | Elna Sewing Machines
How do I thread a elnita 200 sewing machine?
Perhaps this will help:
Elna Elnita 225 Sewing Machine Threading Diagram
HINT: Be sure to raise the presser foot BEFORE threading the upper thread. It releases the upper tension disk so the thread will seat properly. Do this every time the upper is threaded.
Jan 06, 2016 | Sewing Machines
Thread an Elnita Top 300 Sewing Machine
I am NOT familiar with your machine, BUT..... many machines have a threading diagram decal on the INSIDE of the head cover on the left [needle] end of the upper body!
Jan 09, 2015 | Sewing Machines
How to guide thread on kenmore 158.13201
Most machines are very, very similar, therefore, no matter what brand you own, there's basically the same steps to follow: 1. Place good quality thread on spool pin, back right-hand side of machine and raise presser foot UP. 2.Pull thread taut from spool.Make sure silver take-up lever raised to highest position. 3. Guide thread under first tension disc. 4. Hold thread taut, guiding thread into next tension disc. When you get to the take-up leaver (silver lever on right side of machine that has a hole at the top--hold thread taut guiding it from right to left through hole, bring thread down left side of it, and put thread into tension bracket, hold thread taut! Put thread in back of needle into another small bracket and pull thread towards you. Time to thread needle: put thread front to back into eye of needle. Put thread under presser foot and pull under the center of it a good 6".Lower presser foot on scrap of fabric to test. Turn hand wheel toward you to lower needle into fabric scrap. Use foot (or knee depending on machine) to start machine. Do not pull or push fabric but gently guide it. Jimmy Place fabric scrap under needle. Low
Apr 04, 2012 | Kenmore Sewing Machines
I have mislaid the instructions for my Elnita 140. In particular, I need to find the instructions for threading, including the little bobbin that goes underneath!
This is a machine made under licence for Elna back in the 80's I believe. So should be a bobbin inside a bobbin case mounted vertically. Try this link for threading up, it should be very similar.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Elna_Sewing_machine_threading/Elna_225_threading_diagram.htm
Many machines have this bobbin case design and they all work much the same way, you need to place the bobbin into the bobbin case with it turning the right direction, click the thread into the tension spring on the outside of the bobbin case then latch it into the rotary hook of the machine, usually there is a little latch on the bobbin case that holds it in.
Top thread is usually fairly obvious, from the spool through an eyelet, through the take up lever, through a tension device, then down to the needle.
Always thread up with the pressure foot raised as this opens up the tension device and allows the thread to seat in correctly.
You can probably buy a manual for your machine from either sewusa.com or www.sewingpartsonline.com or "sewing machine relics" websites. Or just search ebay, there are several vendors who sell pdf copies of different manuals there.
I hope this helps you get sewing with your Elnita, four thumbs up if so.
Aug 21, 2011 | Sewing Machines
How do you thread an Elnita 140 sewing machine that is really old but can still work?
It's easy! Start from the thread holder at the top and go left - hook it under the hook which is behind the round disc that the bobbin winds around, then forward down thru the tension, then under the straight metal bit that's below and slightly to the left of the tension, then up into the hook (slide it behind and then slide forward into the hook), then back down and flip it into the small hook (which is just under the 'straight metal bit' mentioned above) and thru the needle! :-) Hope that helps. The machine might be an oldie but it's a goodie! cheers Lynda
Apr 02, 2010 | White Sewing 1888 Mechanical Sewing...
White Sewing 1888 Mechanical Sewing Machine Logo
88 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
