Question about Refrigerators
GE GSS201ETAWW refridgerator fridge temp set to max cool, it only gets down to 40
  • 9 Answers
SOURCE: Fridge does not cool below 40 degrees
This is a common problem and a design fault...
Posted on Sep 06, 2008
SOURCE: GE Profile Side by Side is getting too cold on the fridge side.
I have a GE refrigerator with the same problem of my food freezing in the refrigerator. I spoke to an appliance part person and they sold me a temperature sensor for 20 bucks. They said it would be located in the control panel, but I took the control panel off and can't find the sensor. I'm now looking on yahoo answers to find out where the sensor is located.
Posted on Mar 01, 2009
  • 1169 Answers
SOURCE: GE Monogram Built-in Refrigerator Side keeps freezing
Sounds like a faulty thermostat. Try replacing it with a known good one and retest.
Posted on Apr 20, 2009
SOURCE: cannot get the fridge to start cooling
If the panel temperature reads 0 F 0 F it is in the "DEMO" mode. This is normal if you purchase a floor model. To bring it back to normal mode press ENERGY SAVER & ADJUST FREEZER together for 3 to 5 seconds until it beeps. Then unplug the referidgerator for at least 30 seconds. Then plug it bck in. That will reset the stupid computer and get it back to normal operation.
Did you think this was helpful? Yes No
Posted on Apr 24, 2009
localwonder
  • 6784 Answers
SOURCE: Freezer works fridge not cooling on a Danby Designer fridge
HI, you will need to inspect the compressor to make sure it is cycling in intervals. if the compressor is not cycling, this will confirm compressor failure. The evaporator fan blows cold air into the freezer and from there it vents into the refrigerator. Occasionally the vents between the freezer and refrigerator can become clogged with ice, food or other debris. In most refrigerators the cold control for the refrigerator opens and closes these vents. That mechanism may become inoperative resulting in the vents becoming stuck open or closed.
Inspect the vents to determine what is preventing the free flow of air. An overcrowded refrigerator or freezer may be the cause. In other cases the vents may need to be cleaned or ice melted away. To remove a build up of ice, use a hair dryer set to "low". Using a higher setting may damage the freezer. CAUTION: Do not let melting ice drip onto the hair dryer. In some models, the vent is located under the temperature control console. The housing either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring. A freezer vent control may also have to be removed to access the vent. In some freezer-on-top models, it may be necessary to remove the floor of the freezer to inspect for obstructions.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Another inspection point will be the door seals. This is a easy way for the cold air to escape from your unit as well. thsi will cause the temperature to rise. The seal should make smooth continuous contact with the refrigerator case. When the seal does not seal completely, warm air enters the appliance. This results in more frequently compressor operation and possibly the inability of the appliance to maintain proper temperature. To test the seal, use the dollar bill test. Place a a dollar bill or a piece of paper between the seal and the refrigerator and close the door. Now pull the paper out. You should feel tension as you pull. Retest along the entire door seal. Replace the seal if the test was unsuccessful.
Next will be the door switch. The interior light in most refrigerators, and the fan in some, is controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Be sure to confirm evaporator fan function as well. if the fan is defective, it will prevent proper cooling as well.
This will conclude the most common issue with a under preforming unit. I would advise to check all the above and, if the unit continues to not cool after all the above adjustments are made, i will recommend replacing the cold control device and thermostat.
Posted on Jul 30, 2009
Model no. pfs23kshss ge profile refridgerator left door does not match up flush on the outside with the right door. we can feel the cold air escapifridge temp was 62 degrees and freezer at 10 degrees
Gotta stop the air loss by fixing the hinges and/or replacing the door gasket. Freezer should be around zero degrees and fridge around 40 or less.
Jun 28, 2015 | GE Refrigerators
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
My GE profile side by side refrigerator's temperature is not staying where I put it. It keeps popping to 31 degrees when I set it for 37 degrees. My food is freezing !!
It may need to defrost. Shut it off for 4-5 hours to let any accumulated ice to defrost and see what happens.
There also is a control that directs more cooling to the refridgerator or the freezer compartment. It may need to be readjusted. It will take 24 hours to stabilize.
Oct 20, 2009 | Refrigerators
My Ge Monogram Refrigerator required maintenance cleaning on the condenser, typical with this type of built-in system. blew out the dust and cleaned it. the freezer is working fine but the refrigerator...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 18, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
What is the purpose of two temperature control nobs when there is a single compressor in my samsung 280 lts fridge
1.If this is only a fridge the one knob will be for the min and the other for the max.
max. : As soon as you switch the fridge on it will cool down the fridge to max cool down temp. example -2deg.
min. : As soon as the fridge reaches the max cool down temp and it had switch the compressor off, the fridge will start to warm up slowly, by the time it reaches the min allowed warming up temp, it will switch the compressor back on and do the cycle all over again.
2. If it is a fridge/freezer setup, the one knob will be for the fidge and the other for the freezer. If the temp in the freezer is fine a fan is activated and blows all the cool air to the fridge and controls the temp. by activating the fan.
Sep 06, 2009 | Refrigerators
Refrigator not cooling properly, freezer works fine
I'll assume you don't have much food/items in the freezer section. Because you have the fridge set on the max cooling setting and the freezer set higher than the mid setting, it could be that you have frozen the cold air passage from the freezer to the fridge.
If you can, 1) remove all contents that would spoil; 2) turn off the fridge 3) open both doors and allow the fridge to manually thaw out completely (this will speed up the opening of the cold air exchange passage between the freezer and fridge, which is likely blocked and frozen solid. Have plenty of towels handy to soak up the water from the defrosting process,
After a FULL day of being left off and doors open to thaw out, check for any further thawing and dripping water inside, if present wait another 8 hours (you really want to get it thawed out the first time!) When that's done, reset BOTH temperature controls to the factory mid-point setting (5?) as marked on your control knobs.
The key to having a refridgerator run properly is to allow for it to run at the factory settings for at least 24 hours BEFORE you adjust the controls higher and/or lower for each section. Adjust it up or down in ONLY 1 setting increments so as to not cause ice build-up and freezing of the internal air exchange passages.
Also, as you've relegated this fridge as a garage "beer & backup" unit, make sure to keep the freezer as full as possible to make it run as efficiently as possible. You can freeze jugs of water and pack it with cheap thrift store bread to help it run correctly. An empty freezer has to work harder to keep just air at freezing temps. As such, it will pass much colder air into the fridge, and cause these types of freeze ups. By the way, turning up the temp controls only makes it worse and just results in a total "freeze up" inside the cabinet panels that you can't easily see or get at to rectify, hence the reason to shut it off and let it fully defrost.
When you're done, you should have your fridge back in action working like it should, but remember, don't rush temperature adjustments, even thou we all want those frosty beverages, it'll take a couple of days to achieve the desired "chill" you're likely used to getting when it was your primary fridge.
Hope this helps and Best Regards! Semper Fi!
Aug 03, 2009 | GE Profile PSW26P Stainless Steel Side by...
the dampener door in the fresh food is more then likely broke . allowing air in to the fresh food.
Jun 06, 2017 | GE PSS25NGNBB Side by Side Refrigerator
Fridge seems to require max cold temp control
did you check to be sure the the compressor cooling fan is operational? if this is bad it will cause a problem similar to your condition. another thing if this checks ok is that your temp control could be getting weak, ( it has small springs connected to the contacts) and may need replacing. the fact that it will get to 0f tells me that compressor and freon system should be fine.
you mentioned the warm area on the side of your door is a anti moisture feature. if this area is abnormally hot it would indicate a bad condenser fan motor which is the compressor cooling fan.
If you have any further questions let me know thanks Peyton
Feb 23, 2009 | GE GSS20IETCC 20.0 Cu. Ft. Side-By-Side...
My ge side by side not cooling, freezer act like fridge
Sounds as tho your compressor is bad if it is still under warrenty take it to the place of purchase.
Nov 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Fridge: PSS26SGPA SS Model
CallMe-
Your "freezer" and "refridgerator" temps are not jumping back to 14 and 44 respectively. When you change temps, they both wait 3-5 seconds before they revert back to a temp reading, not a temp setting.
Does your "freezer" make any loud or thumping noises? If not, do you hear a quiet whisper when both compartment doors are closed?
Solutions could be :
1. Servicing the coolant (might have a small leak)
2. Checking the seal on your freezer compartment (black rubber that meets the metal frame)
3. Your internal cooling fan is not operating and needs replacing (but I think your temps would be significantly higher).
Best of luck.
Jul 28, 2008 | Refrigerators
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
