Question about Kenmore 22812 Bagged Canister Vacuum
Can you tell me if Powermate Power Brush attachments are all the same for all the Sears Powermate Cannister vacuums.  That is, would one power brush attachment on a Model 116.56512690 fit one that is Model 116-22512202?  Are the connecting ports all the same size?Thanks for your help.
  • 3 Answers
I think your confusing model #s ,as the 116. 22512202 is the canister model number and the model number of the powerbrush attch would be 116.52512202,but to answer your ? no it depends on which wand your useing that determans which one you can use
there 3 types of wands 1 telescoping which comes only on progressive models 2 a 2 piece with wire connected and a 2 piece
wire not connected,hope this helps,les
Posted on Mar 05, 2009
When vacuuming carpet with the electric power brush it will ocassionly , go to zero suction mode and shut off the brush. I have tried to cause it to happen by playing with the joint areas ( handle to tube...
You gave a good start to giving us good information to help you with solving this problem-- But I need a little more information:
It sounds like you have the Electric Motor driven Power nozzle/ Floor attachment-- am I correct? (Not the type that has a little vacuum motor down at the floor attachment-- Not one that depends upon air flowing thru the unit to power the brush, -- am I correct?)
You can control the motor with a switch at the handle-- correct?
So here is the question: - when you say "the electric power brush -- goes to zero suction" -- what tells you that it 'went to zero suction'?-- the little red flag on the vacuum?-- or what?
I am suspecting something might be caught up in the floor wand-- or at the power nozzle itself-- or even in the flexible hose. Do you know how to take the hose off, and place the hand-held end, in the opening in the Miele Vacuum? Can you do that, and clear out the hose first-- and then the hose with the want connected?
If they are all clear-- we may need to open the floor plate on the floor nozzle, and check for something caught in the air passageway--
Tell us more
Mack B
Dec 28, 2010 | Miele Blue Moon Bagged Canister Vacuum
Need to replace powerhead belt in sears canister vac - cannot get head apart - plz advise
If you press on either side of the raised top light cover it will come off. Then you will be able to see the light bulb and two screw heads. Remove the two screws and the top cover of the power brush will lift off and you will be able to access the belt. You can find this belt you need here:
Sears Powermate Canister Belts
Nov 15, 2009 | Vacuums
Need Hoover cannister vacuum floor brush & filter bags
Hello, if you GOOgle Hoover you will be able to find your nearest Hoover center, they will then be able to help you with parts and bags. We did this last year and it was emensely helpful. Hope this helps.
Nov 04, 2009 | Vacuums
Wish to remove bottom ofpowerhead-Kenmore Progressive 11629912990
I have a whispertone vacuum, different model #, but maybe instructions will be the same. Turns out I didn't need a new belt, just clean out the crud and reset overload protector. The instructions in the manual tell you to remove the light cover and bulb first. To do this, press in and lift both sides. Push in and turn bulb counterclockwise to remove. (you need to do this because the next step involves turning the unit over). This takes you to
Step 2. Unscrew the cover screws ( on either side of bulb).
Step 3. Turn unit over. To remove cover, insert screwdriver at cover tabs on both sides and twist to release tabs.
Step. 4 Turn unit right side up. Press handle release pedal and lower the swivel. Tilt cover forward from back until front snaps free.
Step 5. Carefully insert and twist screwdriver at each brush support to free brush from base.
Step 6. Remove worn belt.
Step 7. Slide brush supports off to check and clean brush support areas.
To replace belt: slide washers and brush supports onto brush assembly.
Install new belt over motor drive, then over brush sprocket.
Snap brush supports into place on base. Be sure brush supports are not upside down.
Line up front of cover and base. Rest cover on front edge of base. Tilt cover to back. Press cover firmly until side tabs snap into place. Replace cover screws, light bulb and light cover.
Mar 11, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
The belt in the PowerMate won't run
If the motor on the floor attachment runs, it could just be a worn belt - it can be replaced. Also check the switch to turn the attachment on, and the electrical connections in the hose and wand from the vacum all the way to the attachment. An electrical meter could be used to check for power at the motor in the attachment also - just be careful. Here's the instruction book, in case it's of use.
Please rate if this helps :)
Feb 15, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore Model 116 PowerMate Jr stopped working
If the roller brush is not spinning freely once you remove it from the Power Mate Jr., then I have discovered the solution! There are end caps at each end of the roller brush. They seem to be permanently attached, but they are not. There is an axle inside the roller that is permanently attached to one of the caps. Take two pairs of pliers, and grab each end cap with a pair of pliers. Then pull hard to take them off. Once they are off, you will find that there is a big glob of hair wrapped around the axle inside. Remove the hair. Then reassemble the brush by putting the end caps back on. Make sure, when you put the caps back, that they are aligned so that they will fit back into the slots on the Power Mate Jr. You have to push hard to get the caps back on, maybe tapping one of them with pliers.
Oct 01, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
Need new power brush
Get the number off the power head, it should be on the bottom, then go to, click on the parts link, put in the complete model number, a parts list will come up and you can order your part.
Jan 28, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Brush does not spin
definetley the belt if its the cannister vac like mine there is 2 screws on the bottom towards the back wheels take em out. on the side u have to pry open gently on the back side as well the top should come off and you should see a w plastic shroud around the roller there is a clip latch take the shroud off theres the belt
if not cannister vac on underneath the cover should have 4 or 5 little screws take em out under cover is the belt
hope that helps. gl
Dec 29, 2007 | Vacuums
Hoover Vacuum
Our Hoover upright vacuum cleaner makes a very loud noise when it is running. What causes this?
Jun 28, 2006 | Hoover S3614 Vacuum
Kenmore 22812 Bagged Canister Vacuum Logo
315 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
