Gives a error code 60.06
SOURCE: hp 4250 paper jam erro
Is it a new or refurbished fuser? Where exactly does it jam. By trays, registration or before fuser? Problem can be with various sections. Need to know more.
SOURCE: hp 4250 error code 50.3
FALSE FUSER OVERTEMP INDICATION, POWER SUPPLY THAT DRIVES THE FUSING UNIT. MODEL 8150 DOES THE SAME THING. TRY TO GET A REFUND ON THE FUSER?
SOURCE: give me the solution
SOME ONE HAS PUT ME IN FOR ABUSE REPORTS AND THAT IS UNFAIR, I USE TO SERVICE COPIERS FOR A LEAVEN AND IT IS A DIRTY JOB AND THERE ARE CERTAIN THING A NORMAL PERSON CAN DO AND THERE ARE OTHER PROBLEMS THAT CAN ONLY BE DONE BY CERITIFIED TECHNICAIN CAN DO, LIKE THE KERNAL ERROR IS A SERVICEPERSON SPECLIST CAN DO, ILLEGAL OPERATOR SEQUENCER OPERATION IS A HARD TO TROUBLESHOOT WITHOUT SERVICE MANUAL WITH THE CODES AND HOW TO FIX THE PROBLEM AND EXPLAIN TO THE CUSTOMER WHAT TO DO AND WHAT NOT TO DO SO IT WILL NOT HAPPEN AGAIN AND HAVE TO PAY FOR ANOTHER SERVICE CALL BECUASE SERVICE CALLS ARE NOT CHEAP IN ANY MARKET OR YEAR OF SERVICE AGREEMENTS.
ROD
SOURCE: `permanent storage full error` what does it mean????
The internal storage system is full. You need to run the HP Web Jetadmin software and delete unnecessary files from the EIO disk device. When done, press the select button on the printer to return it to a ready state. You should be able to print small jobs yet as long as it doesn't require any temporary (or permanent) storage on the EIO disk.
