Question about John Deere 4010 Gas & Diesel Tractor Radiator
How to change thermostats in john deere 4010 diesel tractor?
blueextc3221
  • 15935 Answers
SOURCE: system creeps down even when tractor is operating.
There are 2 potential problems -
1. Leaking spool on the control valve - rebuild the vale.
2. Cylinder blow-by. Disassemble piston and replace the seals.
To test if its the cylinder - retract the cylinders all the way... remove the hoses on the blind end (non rod end) of each cylinder, and again pull the valve to the retract position.
If fluid continues to pour out of the cylinder - the piston seal is damaged, and the affected cylinder must be repaired.
To test if the valve spool is faulty - disconnect the a and b ports just after the valve. Turn on the system and check for seepage from the disconnected lines (without moving the lever).
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 19, 2009
mattofilms
  • 110 Answers
SOURCE: 2020 john deere diesel tractor with j-d 36# loader
Sounds like you need more hydraulic oil - Or like you said the transmission screen (dirty).
Where it is ??
Posted on Jul 02, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
bargainbin2
  • 123 Answers
SOURCE: I have a john deere 430 garden tractor diesel.
Sounds like the fuel pump stoped working.
Posted on Aug 26, 2009
bbreton
  • 437 Answers
SOURCE: need instructions for changing a drive belt on a John Deere LT155
I have googled LT155 and came upon john deere LT155 lawn tractor(noncurrent). It took me to John Deere's site. I put in your model number and it had several catagories. I would try the alphabetical list, go to B and look for traction belt.
Good day.
Posted on Oct 14, 2009
Deere tractor
See your JD dealer - they can provide you with any parts that you need.
Nov 04, 2013 | John Deere 4010 Gas & Diesel Tractor...
Tractor diagram
Have you tryed a website called partstree.com you should be able to fi d a diagram on there
Nov 01, 2013 | John Deere 4010 Gas & Diesel Tractor...
Remove spindle john deere 3020 tractor
Remove bolts or clamp on top of spindle. Next remove steering tie
rod. It should slide out.
Sep 26, 2012 | John Deere 3020 Gas & Diesel Tractor...
Can anyone tell me where the thermostat is on a John Deere 330 diesel lawn tractor?
follow the raid hoses to the engine should be at a bolt on neck
May 08, 2012 | John Deere Garden
John deere 4010 wiring schematic,diesel engine 24volt starter 12 volt charging systems need to rewire the starter ,voltage regulator,series/parralell switch
Call me, or email me there are so many options, I would like to know exactly what you need. Solutions are simple, I have worked on AC and DC vurrent all my life and even have some designs on youtube, and have taught seminars for Delco, Leece-Neville/Prestolite, and designs for A/P and Twin Roter. Shmburns@yahoo.com
Apr 01, 2011 | John Deere Radiator 4010 Gas And Diesel ()
TRACTOR STARTS BUT LOSES POWER AND QUITS AFTER
Check to see if you have a fuel screen built into the top of the petcock (shut off valve) in the fuel tank. This may require you to drain the tank. Inspect the screen for being clogged. This is a very common problem. I hope this helps.
Jul 09, 2010 | John Deere 4010 Gas & Diesel Tractor...
Starts good runs good on idol, but under load misses
Is it a lp,gas are diesel?...If lp are gas check timing and point are in some cases the flapper in the carberator.If Diesel it possible the flex ring is coming apart in the injection pump and stoping up the return lines at the injectors retarding the timing advance in the injector pump..very common in the 3020 4010 4020 4320 and 5020 John Deere ag tractors...
May 16, 2010 | John Deere 3010,3020 Tractor Basic...
1962 JD 4010. TRANS SHAFTS TURNING, WON'T MOVE. SUSPECT REAREND PROBLEMS. ANY IDEAS?
Try removing the the transmission shaft and you will likely find that the splines are missing from either the input or output shafts.
Dec 20, 2009 | John Deere 4020 Gas & Diesel Tractor...
John Deere 4010 Gas & Diesel Tractor Radiator Logo
114 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
