Question about Encore The Print Shop 23 Deluxe Full Version for PC
Print shop 23 only prints one copy when I select multiple copies
5 Suggested Answers
  • 28 Answers
SOURCE: Cannot load JPG files
is your programme a text only prog? are u frying to load graphics using a text transfer button? try the insert button instead of the import button then choose picture.
Posted on Apr 26, 2009
  • 34 Answers
SOURCE: I am trying to print several pages through Print
make sure you check the set up page of the printer. let me know
Posted on Oct 04, 2009
SOURCE: My system is windows vista 64 bit. Print shop
you have to go to the help section or help tab at the top of your printshop window, on your printshop program...and then click technical support , and it will give you options...click on the option of troubleshooting and it will take you to the broderbund direct online troubleshooting page, and click on the appropriate option for windows vista 64bit, and it will walk you through step by step; which involves going into your printer port settings under control panel section of your computer, and just follow the online directions...I just did it and my newsletter on printshop 23 deluxe is now saving without problems!
Posted on May 02, 2010
SOURCE: I am currently using both
Printshop 23 won't save to broderbund pdf creator or pdf complete creator. Either a Printer is not activated error 30 or cannot communicate with printer.
I have used Printshop for years......have had no problems with printshop until this new Printshop 23 version for windows 7.
Have uninstalled and reinstalled everything at least 3 times. When I go to the "help" button there is no technical support button. Any ideas out there?
Posted on May 21, 2011
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
When I print a one page document, tray 1 prints on multiple papers at a time. 1 page prints on 5 pages.
If you don't have a manual, you can find one here
My guess is either on the printer or the driver. Skimming the manual, it doesn't seem that you can set the default number of pages printed per sent print job on the printer, but that is something I would look into. This is a nice office printer, perhaps the printer is set to print multiple copies of everything it is sent. You could determine if it is the printer or driver/computer by printing to it from another computer.
If it is the computer, go into the control panel and select the properties for this printer. In there, check if the number of copies is improperly set to 5. This would happen for every print job sent from this system.
Does it print 5 copies of documents sent from different programs (i.e. Web Page, Word, Excel)? Quite possibly, one time you set it to print 5 copies and that application retained that as default. In that application, rather than clicking "print" click "printer setup" and look through the settings to see if it is requesting multiple copies.
I am 95% sure one of these three solutions will solve your problem.
May 05, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Multiple copies not printing
Its a problem with Vista with the print spooler. Try the following.
  1. Click start then Control Panel.
  2. Double Click Printers
  3. Right click the Brother and select Properties
  4. Click on the Advanced Tab
  5. Select print directly to Printer, then Apply
This should do the Trick, If it doesnt let me know, I know of another fiix
Thanks!
Jim
Jul 01, 2010 | Brother MFC-7340 All-In-One Laser Printer
Unable to store job at printer, printer not configured to collate
Problem -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
Error “Unable to store Job at Printer”
Reason “Printer not configured to collate”
Solution “Install an EIO hard disk”
Usually when trying to print a multi page document.
Solution 1. Start > Control Panel > Printers
2. Locate the printer > Right Click > Properties.
3. Device Settings > Mopier Mode > Set to Disabled.
4. Apply OK
Feb 25, 2009 | HP LaserJet 2300L Printer
Getting more copies at once
In almost any windows application there is a command in the FILE dropdown menu that is labeled "Print..." It's usually right above "Print Preview". To print multiple copies click "File" then click "Print..." and you will get the following Windowa63a80c.jpg Just select the number of copies you want by clicking the up/down arrows where it says "Number of copies"
Dec 19, 2008 | Office Equipment & Supplies
My hp 1320 prints multiple copies instead of one copy
Go to "printers and faxes."
Right click on your printer and select "Printing preferences."
Select "Advanced" tab
Double click "paper output"
If "Copy count=2" then change to 1 and apply
IF IT ALREADY IS SET TO 1 THEN:
Set "copy count=2" then APPLY
Repeat the above and now set "copy count=1"
The process of setting and resetting the copy count fixed my issues.
Dec 03, 2008 | HP LaserJet 1320 Printer
Hp LaserJet 1320 will not print multiple copies
This problem is caused by Mopier Mode being enabled by default. The idea of Mopier Mode is to minimise computer and network traffic by sending only 1 copy to a printer equiped with suitable internal memory. That stored copy is then used to produce the multiple copies. Most HP Laserjets do not have suitable internal memory and so only the one copy sent by the computer gets printed. To disable Mopier Mode:
Click Start
Click Devices and Printers
Right click your Laserjet Printer
Select Printer Properties
Click the Device Settings Tab
Scroll down to the bottom
If necessary, expand Installable Options
Click on Mopier Mode
Select Disable in the selection box that appears
Click Apply
You will now get multiple copies.
Nov 20, 2008 | HP LaserJet 1320 Printer
Can't print multiple copies
On your Brother's drop- down menu, left click on PRINTING PREFERENCES . On the BASIC tab, choose the number of prints in the COPIES box, then left click on APPLY. If that does not work, go into PROPERTIES, left click on the SECURITY tab, and check that you have authorization to run multiple prints. Also, check your PRINT SPOOLING mode to make sure it is activated, and check authorizations in OFFICE 2007- it may be set to restrict multiple color pints.
Aug 29, 2008 | Brother MFC 420CN All-In-One InkJet...
HP 4650N Will not print more than one copy of a job
make sure when printing it has all checked off in the page range box instead of pages
Aug 28, 2007 | HP LaserJet 4650n Printer
Encore The Print Shop 23 Deluxe Full Version for PC  Logo
112 people viewed this question
Top Encore Computers & Internet Experts
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
