Question about Air Tools & Compressors
Where can I find individual orings for my Ramsond RMM3 flooring nailer
I don't need the whole kit ,just individual orings
3 Suggested Answers
  • 1388 Answers
SOURCE: i have a T31 pinner and the top valve is broke
I have been buying Bostitch t31 parts on ebay. Rebuild kit usually about $22 - 39 depending on how luckey you are at bidding. Keep searching on Ebay for other parts for this gun as parts are not available at Bostitch.com any longer. The oring kit for the N60 is available at amazon.com. the part number is ORK1, cost under $20. You can also find bargains on ebay. When installing orings us silicone grease. It is available at lowes in the plumbing department. It looks like vaseling. It is used for lubricating orings in faucets. Good luck on your repair project.
Posted on Mar 04, 2009
rufedog
SOURCE: which orings do i need to rebuild the piston on a makita an451 roofing nailer
If you go to your local
makita tools dealer or
makita.com they should list a complete re-build kit for your model nailer
Posted on Nov 29, 2011
It double nails quite a lot
Time for an oring kit and also replace the trigger valve. These nailers have some vinyl /gold colored orings that fail. If you buy a kit, , make sure that the vinyl orings in the kit are still usable. If you have a source for buna orings, use them instead. Good luck.
Oct 20, 2014 | Dewalt D51850 Heavy Duty 20 Degree Full...
When you pull the trigger air comes out near the trigger and no nail is fired.
The problem that you describe indicates that the orings within the trigger failed. You could replace the orings if you have a source for very small rings (2mm x 1.5 for the firing pin inside the trigger valve) or just replace the whole trigger assembly (under $10). Lube all orings with white grease or silicone paste lube (remove head and lube head valve assembly). Good luck
Oct 11, 2012 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Will not nail anymore, what could it be ?
Dewalt nailers have some vinyl orings that fail. Usually found within the trigger valve, headvalve, and between the cylinder and cylinder spacer (white plastic piece). Oring kit sold by dewalt will contain most of the orings needed. The kit may not have orings for the trigger. You will at need two orings (2mm x 1.5mm) for the trigger valve stem or just replace the valve. Use white grease or silicone paste lube on all the orings. Good luck.
Aug 26, 2012 | Dewalt D51850 Heavy Duty 20 Degree Full...
Nail gun leaking air at trigger
Worn orings always results in leaks/low power. On some nailers, better to replace whole trigger valve as seperate orings (very small) are hard to find and usually not in repair kit. Low power is usually worn driver oring. Easy test, remove nails and point nailer up then down again. If the driver seems to move up and down within the cylinder, time to replace oring/s. Look for repair/tune up kit that contains all the orings in the gun.
Jun 10, 2012 | Tools & Hardware - Others
Bostitch N80SB won't reset after firing
Most likely just needs piston oring. Remove nails from the gun and point nose of gun up then down again. If the piston travels up and down in the cylinder, replace the oring. The piston returns to top with air pressure and needs good snug piston oring and good lower bumper (if bumper is cracked or missing pieces ~ replace ). Be sure to lube the orings in the headvalve with silicone paste or white grease. Part # ORK11 oring kit will reseal the gun. Good luck with your repair.
Jun 02, 2012 | Stanley Air Tools & Compressors
I have an air leak, where can I purchase a gasket set for my framing nailer
Best place for parts is www.toolpartsdirect.com. They do not sell a gasket kit. The parts are listed individually. oring kits are available on ebay for about 20.dollars. Use key search "hitachi oring kit". If you have question about your leak and specific cause of leak post again with exact area of leak. Good luck with your repair
May 30, 2011 | Hitachi 3 - 1/4" Framing Strip Nailer
Air leaks out where nail comes out , dewalt air hammer
Dewalt nailers have some orings made of vinyl in critical sealing areas that failed due to oil/water in the supply air. One indication of failed cylinder seal orings is leak out of nose. You could replace the individual orings or order oring kit #610773.01 from dewalt service center or on line at www.toolpartsdirect.com. Second option is to take gun to a fastener outlet that also repairs the popular brands of nailers and ask them to match orings with better viton type seals instead of vinyl. If you are handyman type, pull parts out of gun and take worn orings (and parts) to bearing dealer and they will measure your seals and sell you some oring lube. Good holiday
Nov 28, 2010 | Dewalt D51844 Framing Nailer
How do i change the o rings on bostitch MIII hardwood nailer?
after you buy the o ring kit, then remove the cap screws. remove all the orings from the firing valve and cylinder, then replace cap and screws,, very important please grease the new orings before trying to put gun back together, you can get a schematic and o ring kit from toolpartsdirect.com
Nov 22, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
DeWalt51321 roofer.The driver won't retract all
You need to check the piston oring for damage. If the driver slides through the cylinder without much resistance this is part of the problem, if not all of the problem. Check the cylinder for scarring on the inside where the driver travels. If you see long scratches the cylinder needs to be honed out or replaced plus the driver oring replaced. You also need to check the two o-rings at the bottom section of the cylinder. These will be in grooves on the cylinder which will have holes behind one of them. If these are weak they will not be sealing off the air well enough to return the driver. Air goes through these holes on the down stroke then it seals so the pressure built up in the lower chamber will force the driver back up. To replace the driver o-ring and the 2 lower cylinder orings would be about $5. You may want to try this before getting the o-ring kit. An o-ring kit is $42. If you cannot locate the problem individually you may want to replace all the o-rings in the kit. This should solve your problem as long as there is no scarring in the cylinder. Any questions please post back
Nov 04, 2009 | Dewalt D51321 3/4" 1 3/4" Heavy Duty Coil...
I have a T31 pinner and the top valve is broke and an N60 15 gauge nailer that needs oring
Mar 02, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
125 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
