Question about Jandy Pool & Spa
Error code High Ref Pressure on a jandy AE 3000T-R
Fault code High Ref Pressure shows on my Jandy AE3000T-R pool heater
  • David Spradling
    David Spradling Oct 16, 2017
    check gas pressure high limit bad overheated
  • 22 Answers
SOURCE: Jandy lite 2 LG pool heater
ignition control board failure
Posted on Feb 18, 2009
  • 22 Answers
SOURCE: Jandy, Lite 2 Pool heater wont kick in
3/4 pipe line will work and will keep heater from sooting up.
SOURCE: low pressure reading on Pool Heater
I had this problem with ours last year. I replaced the water pressure switch and it began working fine. We later had a symptom that the blower would start but it would not ignite. The ignitor rod was corroded so I took it out and sanded it with some sandpaper---worked fine...until I dropped it trying to reinstall and it broke. Bought a new one and it works fine now.
Today's problem is related to the blower now.... it is always something, isn't it?!?
Posted on May 30, 2009
  • 128 Answers
SOURCE: Jandy LX250 LT Pool Heater High Limit Switch
Jump the High limit switch. If it fires the switch is bad
Posted on Aug 23, 2009
thepool
  • 78 Answers
SOURCE: jandy AE.TI AE3000T .263
The H20 sensor is the Pressure Switch. Locate the pressure switch, remove the two leads and jump them together. If the error code goes away, you need a new switch. If not, it could be a software, or other hardware issue.
Posted on Apr 22, 2010
How do i correct a "high limit switch circuit is open" code
check the fusable link for voltage on both sides if not replace also check pressure switch
May 26, 2014 | Jandy LX 400P Lo-NOx, 400,000 BTU Heater...
My Jandy Heat Pump goes into defrost mode all the time
The heat pump works almost like an air conditioner or A/C but not entirely, as a matter of fact it works a lot more like a refrigerator. Not only does it help lower down the temperature at home during the hot months, it can also operate in reverse and it can actually act as an indoor heater and provide warmer air inside the house during the chilly winter months.
Apr 07, 2013 | Jandy Air Energy Heat Pump - 100,000 Btus
Jandy ae heat pump
make sure wiring is correct for 220 volt or 115 volt and check fuses
Mar 20, 2013 | Jandy AE3000T AE-Ti Heat Pump 137K BTU
Fault Low Flo Pressure
check pressure switch and copper tube to it
Nov 04, 2012 | Jandy Air Energy Heat Pump - 100,000 Btus
Jandy AE.TI AE3000T .263 BOARD SHOW FAULT SHORTED H20 SENSOR
Jan 08, 2010 | Jandy Ae2500t 115,000 Btu Heat Pump
Digital read out....fault high ref pressure.
Verify circulating pump is on and that there are no water flow restrictions to the heat pump. Make sure all necessary valves are open or in the proper positions to allow proper water flow to the heat pump. Verify filter and skimmers are clean. Check for water level in the pool. This condition may also appear if the heat pump has not been operated for an extended period. To clear the condition, cycle the heat pump, on and off, up to 3 times. If this does not correct the problem, call for service.
Jul 25, 2009 | Jandy Ae2500t 115,000 Btu Heat Pump
Pool & Spa Logo
177 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
