Question about Pioneer AVIC-N2 Car DVD Player
Touch points off
The touch points on my N2 screen are out of calibration. Wherever I touch, the input that gets registered is about one 3/4 inch off fron where my finger touched. In other words, if I press the "G" button, the unit responds as if I pressed "H".
How can I "re-register" the touch points?
Thanks
Mike
    Champion:
  • 227 Answers
Hi, if you go to avic411.com and search the forum. There are full instructions there to show you how to re-calibrate your touchscreen. I learned from them and did my a while back, but I forgot how. I am sure it still there. You just have to look at the whole forum on the Avic N series. Good luck.
Posted on Jan 10, 2009
How to correct touch screen error
Your screen need to be re calibrated. Depending on the make/model there should be a option to do that.
Nov 17, 2011 | GPS
Its saying calibration problem on the screen
When the Reader device is started for the first time or is reset back to factory settings, the screen must be calibrated. The Reader device will display a calibration screen that requires you to touch the stylus to the center of an "X" at several points on the screen. This is to make sure the touch screen properly recognizes input.
The process requires you to touch the "X" in the following locations on the screen:
  • Top left
  • Bottom right
  • Top right
  • Center
If the screen is accidentally touched someplace other than the center of the "X" during calibration, the Reader device will display a message stating Calibration error detected. Please restart calibration process .
If this happens, please start again in the top left corner and touch the stylus to the center of each "X" as it is displayed, being careful not to touch any other part of the screen. After the sequence is completed the Reader device will display Touch Panel calibration completed . Click OK to continue to the next step in the setup process.
Dec 26, 2010 | Sony Reader Touch PRS-600
Hp pavillon tx1000 12.1 inch touch screen cursor stays at bottom left hand conrner
Clean the screen with a clean soft cotton cloth is the step #1
Step 2:
SEE FULL instruction HERE
Calibrate the touch screen
The command buttons and fields are displayed on the screen image at specific pixel points. To initiate a response, the touch screen interface needs to recognize exactly where a fingertip or pen touches the screen relative to the pixel position of the display. Each user has a slightly different hand-eye coordination response. Calibrating the touch screen allows the interface to compensate between where the program is expecting a touch and where the touch actually occurs. To calibrate the touch screen, place the tablet notebook in the desired orientation and do the following actions.
  1. Click or tap Start > Control Panel > Tablet PC Settings to open the Table PC Settings window.
  2. On the General tab, select the option to display the menus in either the Right-handed or Left-handed position.
  3. On the General tab, select the desired screen orientation from the drop-down menu, and click or tap Calibrate . Follow the instruction to touch the screen at the specified points. Repeat this calibration action for all four of the screen orientations, then click or tap Apply .
  4. On the Handwriting Recognition tab, select the Use the handwriting personalization option.
  5. At a later time, you can return to review the Go to Pen and Input Devices and Go to Input Panel Settings options to make using the touch screen to control programs and input text easier and more accurate.
Compare your version of the firmware to the latest one at HP offical site HERE
Always get the latest firmware to avoid problem.
Always keep the screen clean!
Jul 11, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
Calibrating touch screen
calibrating touch screenProblem with Pioneer AVH-P5750DVD Car DVD Player
May 20, 2010 | Pioneer AVH-P5700DVD Car DVD Player
Lanier LD435c touch screen is not registering touch in right plac
Press the yellow clear modes button then press
1 9 9 3 and the red clear/stop botton 5 times
this will open up the touch screen calibration menu
select calibrate touch screen. follow on screen directions.
Good Luck
Apr 08, 2010 | Office Equipment & Supplies
Ricoh Aficio 3025 Copier LCD Touch Screen out of Allignment
It's not in service mode, but rather in the 'self diagnostic menu'. Access it as follows:
Press "clear modes", 1 9 9 3, "clear/stop" (5 times).
** Do not try any other adjustments in this mode...only touch screen
please rate me :)
Apr 10, 2009 | Ricoh Office Equipment & Supplies
Touch Screen Calibration Wrong
Look on avi411.com forum for for similar problems and solutions.
Aug 29, 2007 | Pioneer AVIC-N2 Car DVD Player
P990i touch screen problem
I encountered the same problem but was able to fix it. Just don't know if it's just temporary. Go to tools, control panel, other, set up wizard, tap yes, tap the second button before cancel, keep on clicking to the right direction until the numbers 1, 2, 3 and 4 appears. Tap the center of each number until blinking stops, save settings. For the first few steps you may use the jog dial found on the left side of the phone if the touch screen does not follow your tappings.
Aug 24, 2007 | Sony Ericsson P990i Cellular Phone
Pioneer AVIC-N2 Car DVD Player Logo
393 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
