Question about Plumbing
Utilitech -.33 submersible pump motor runs but discharge fails on occcasion?
The sump Pump operates correctly most of the time but on occasion the motor runs but the water is not being discharged. The float is free and seems to turn on and off correctly.
  • 104 Answers
SOURCE: ive got a shallow jet
Just curious, why do yo9ur run water from a tank to a pit?
Where is the pressure switch located? At the pump I presume? What will increase the pressure? If you are pumping to an open pit, you will never build up any pressure? What is supposed to restrict the pump to create pressure?
You need a restriction to create pressure to turn off the pump. Is there a float valve like in your toilet in the pit? If not this would be required
Good Luck
Posted on Mar 19, 2009
  • 969 Answers
SOURCE: Pump noy pumping water
If it is a FLOTEC pump, 3/4 hp P/N: FP4122 or 1/2hp P/N: FP4112 you can get parts at: 1-800-365-6832, see flotecwater website.
Posted on Apr 30, 2009
  • 7 Answers
SOURCE: Appropriate size inverter for sump pumps
First...you need to find the amperage on the pump...your inverter is rated for 6.25 Amps...(750/120)...you will need an inverter bigger then the pump..I would suggest at least 1.5 times the size of the pump..bear in mind,..the inverter wasnt designed to start motors...so oversizing is needed..
Hope this helps
Posted on May 07, 2009
digritz
  • 530 Answers
SOURCE: sump pump not pumping water properly
If your pump is turning then something is stopping the water from being removed. If you can see the pump check to see if the water is becoming turbulent when the pump kicks on? If the water doesn't appear to move or is moving only a little then either the pump impeller is damaged or the screen that keeps debris from entering the pump is clogged.
If it's never been cleaned it is most likely just a clogged filter screen. Clean it and it should work fine. If however the screen is clear then it is either a blocked line or a bad pump. And yes a pump can still run and not pump, if the impeller is bad.
Posted on May 22, 2009
protek480
  • 1723 Answers
SOURCE: MY DISCHARGE WATER FROM MY SUMP PUMP SMELLS LIKE
It's very old, stagnate water full of bacteria. Poor some Clorox in the sump and let it sit a while. Not the whole bottle, a few cups.
Posted on Jul 04, 2009
Impeller runs, no water comes out. Removed output hose, air is blowing out when removed from sump.
Remove bottom cover, check for clogged intake holes, and make sure the impeller is solidly attached to the shaft. Can you see the water in the sump? Is the sump full of sand at the bottom?
Jun 28, 2015 | Utilitech 1/2-HP Cast-Iron 83 GPM...
Sump pump does not go on all the time have to shake pipe to get it going so water doesn't overflow
There should be a float switch in the pit, sounds like its getting stuck and when you shake it it activates. Check the switch, the rod, etc.
Mar 01, 2015 | Utilitech 0.33-HP Thermoplastic...
Looking for a new motor for a utilitech pro 0313836 submersible pump
Most submersible pump motors are interchangeable.
A 230 V motor will run cheaper. Be sure to get the correct HP motor.
Oct 05, 2014 | Utilitech 1-1/2-HP 18-GPM 3-Wire 230-Volt...
Motor runs but does not pump water
Is there water over the pump housing? Is intake on the bottom clear of debris? This may sound stupid, but is hose frozen or blocked?
Mar 28, 2014 | Utilitech 0.33-HP Thermoplastic...
Utilitech pro submersible pump has good electrical connection but pump won't start
There is a starting capacitor on the motor pump, check this out if faulty then replace it.
Dec 28, 2013 | Utilitech Plumbing
Utilitech sump pump
See if there is power. If so the level switch might be stuck off. If that is OK then the pump motor has probably failed.
Nov 20, 2013 | Plumbing
Active Pump Will not shut off.
shutoff float/switch is stuck.. replace the pump.
Nov 07, 2009 | Little Giant Submersible Sump Pump, 1/4 Hp
Hope this helps
May 05, 2009 | Black & Decker Husky 750w Power Inverter
Sump pump drain
Storm sewer or rain water run off area. In other words , almost anywhere where it won't come back in.
Mar 12, 2009 | Genius Wayne Submersible Sump Pump With ...
Plumbing Logo
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
