Question about IBM ThinkVision Computers & Internet
Ibm 6734-lb1 power supply diagram - ThinkVision IBM Computers & Internet
2 Suggested Answers
SOURCE: need a service manual for an IBM 6734-HB0 Monitor
MY IBM monitor is very dark screen even in setup menu at the start
Posted on Jul 24, 2011
Moniteur thinkvion 6734-ab0
i had the same trouble i changed 2 capacitors on the power supply board a 470uf at 25 volts and a 1000uf capacitor 25 volts.look for any capacitor where the top is bulged and replace them. my monitor works great again.
Jun 22, 2012 | IBM ThinkVision L170 17" LCD Monitor
How can i fix the continous on & off blinking of my ibm l170p monitor
If your monitor is blinking or flickering increase the refresh rate.
Apr 07, 2012 | IBM ThinkVision L170p 17" LCD Monitor
I have a type 6734-LB1 17" Lenovo ThinkVision
where will i get to install the software/drivers of IBM 6734-L-B-1 for listening Music
Sep 30, 2011 | IBM L170M (Black) 17 in. Flat Panel LCD...
Monitor IBM thinkvision 6734-ACO 17", turn OFF
Sounds to me your high voltage powersupply is out. To repair open monitor and remove high voltage powersupply. Inspect the caps on the board. Look for the ends of the caps to be mushroomed out. Replace these caps, usally 470 uf caps. Replace with 25volt caps. Might also be some 100uf caps as well. This is a common problem with all LCD monitors.
Jul 22, 2011 | IBM Computers & Internet
Hello, My IBM Server Power Supply 24R2731 is not working; I need a squematic diagram of to repair it. Thanks Oscar Torres
if nobody finds the schematic, start looking for bulging or leaking electrolytic capacitors...it's usually them.
Feb 27, 2011 | IBM 24R2731 835Watt Power Supply
I have an image with the flashlight, but no backlighting on my IBM 6734 lcd monitor
The inverter module is bad or the back light behind the LCD screen has stopped working, I would suggest an estimate if you decide to have it repaired.
Jan 22, 2011 | IBM ThinkVision L170 17" LCD Monitor
I just wanna know the power supply requirements. WATTAGE?
the bigger the hard drive the more you add to a computer eg:slave disk more ram external hard drive the bigger the wattage required to make a computer boot up quicker you might get a heavy duty PSU with 600+wattage
hope this helps
Oct 05, 2010 | MSI MS-6734-10 (-6734-010) Motherboard
Board will not boot.power supply changed
The power supply and motherboard have a connection (4pin) that communicate to each other. Without this connection, the board will not boot and the power supply will not come on.
The power supply can be fooled by jumping certain pins, but the motherboard must be connected.
Please consult your motherboard manual for the location of this connector.
Visit this site for more clarification please.
http://www.pcguide.com/ref/power/sup/partsMotherboard-c.html
Sep 27, 2010 | MSI MS-6734-10 (-6734-010) Motherboard
Need a service manual for an IBM 6734-HB0 Monitor
Jan 26, 2010 | Computers & Internet
LCD flat panel monitor blinks logo over and over
Sounds like the LCD monitor is not getting a proper input signal. Check your cables between the computer and monitor. Replace them if need. Also check the pins and make sure that none are bent or disfigured.
Try a replacment monitor from a family member or friend. If their monitor works ok.....then your due for a replacment. The are very little user servicable parts inside.
Jan 23, 2009 | IBM ThinkVision L170 17" LCD Monitor
Computers & Internet Logo
46 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
