Question about Thermador C302U Electric Double Oven
Top and bottom oven doesn't warm up.
Unit is 10 years old and I never had any problems with it. Now it doesn't respond to any commands. If I push for bake-350-bake it shows 350 preheat, then 100 for 5 seconds, same as usual, but it stays to 100. The elements are not heating.
  • Lou Cook May 11, 2010
    was the unit recently self cleaned? you may have popped the high temp cut out. there are a few other things that can cause this so please send model number and we can go ffrom there
We had a repairman come and he opened the electronic control panel and hit the "reset" on it and it worked after that. hope this helps. these ovens stink.
Posted on Feb 23, 2009
I am self cleaning my wall oven. I have an error message with F 10 but the oven will not respond when I push stop.
Flip the electrical circuit switch for your oven after 5-10 minutes watch what it does when you do. After it reboots follow normal procedures should respond properly. If not push your stop button keep pushing on it for at least 15 30 seconds this should clear it. If not flip the power switch again then watch it as it reboots when you turn it back on it should respond. What has happened is you have knocked the program out of operation mode. You need to clear that is why you need to shut the off to oven then start again.
Nov 19, 2017 | Ovens
Top oven doesn't heat properly
What is the model number of the unit?
Dec 03, 2012 | Ovens
I have a caloric oven, prestige series. Don't know model. it is about 15 years old. last year the oven wouldn't heat and smelled gas. That was repaired. Now, oven ignitor comes on but oven...
The ignitor is bad again,if it (ignitor) comes on but no flame/heat its the ignotor again, what would make the ignotor go bad so fast (usually last 10-15 years) is a problem with the oven burner, so now BOTH the ignitor and burner would need to be replaced,if it is 15 years old the ignitor is readily avaliable but the burner may not be
Gene
Aug 04, 2011 | Ovens
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Replace or fix a 10 year old JTP56 GE Profile double oven
The heating element is easy to replace and you can buy it online...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Apr 20, 2010 | GE Profile JTP56 Electric Double Oven
Kenmore double oven flashing "door locked"
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Is there a reset switch for Decor Electric oven? Kids turned on self clean and read out stopped working. Unit is at least 10 years old.
You can reset the oven by shutting down the breaker for the unit for an hour or 2, if your oven is over ten years old it might not help, the board could have been fried, good luck
Jul 15, 2009 | Dacor Ovens
Error code on my oven, what does it mean?
I have a Whirlpool oven that is 10 years old or so. The oven stopped working today. The code that came up was E3 (in green) and F1 (in red). I would like to know what is wrong with the oven? Please send me a solution. Thanks
Nov 15, 2008 | Whirlpool RBS305PDS Electric Single Oven
Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Nov 14, 2007 | GE JKP45 Electric Double Oven
Warming up problem
This has nothing to do with the element. This oven should only be serviced by a qualified technician. If you were one, you would already know the solution. You need to go into diagnostic mode to determine if it is the solid state relay or the cc thermocouple. After resetting the hi-limit more than once, it will also need to be replaced.
Aug 24, 2007 | TurboChef TORNADO Electric Oven
Thermador C302U Electric Double Oven Logo
374 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
